Leveling Kit woes...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tjpratt, Apr 18, 2018.
  1. Apr 20, 2018 at 7:06 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Bottoming out could just be the weak stock billies...to be honest it really doesn't take much to blow through them. I did it a few times before I swapped them out.
  2. Apr 20, 2018 at 7:09 AM
    tjpratt
    tjpratt [OP] Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
    I don't have billies. The limited comes with the same shocks as the SR5's :(
  3. Apr 20, 2018 at 7:11 AM
    Doggman
    Alabama
    2017 TRD OR MT
    Oh right right, probably even worse then. How hard are you hitting these speed bumps? I wouldn't expect it to bottom out at reasonable speeds but if you rolling into it at speed it wouldn't surprise me, lol
  4. Apr 20, 2018 at 7:12 AM
    tjpratt
    Travis
    Aurora, Colorado
    Anything over like 15mph
    Argo98 likes this.
  5. Apr 20, 2018 at 7:17 AM
    Doggman
    Alabama
    2017 TRD OR MT
    Yeah, I'd say that's just asking too much of stock shocks. It may be worth noting that it's not the end of the world to get into the bumps on occasion. Truck isn't going to fall apart but it is stressing stuff a bit. The remedy is upgraded suspension for sure though. Anything from Bilstein 5100s up to Kings would probably do the trick.
  6. Apr 20, 2018 at 7:19 AM
    tjpratt
    Travis
    Aurora, Colorado
    I guess that's the question tho. Should I just throw some upgraded Bilsteins in there? Or Kings? OR just rip out the leveling kit and go front coilovers and AAL and shocks in the rear.
  7. Apr 20, 2018 at 7:24 AM
    Doggman
    Alabama
    2017 TRD OR MT
    There's no reason to keep the leveling kit on and upgrade to bilsteins/kings etc. The bilsteins/kings/etc will allow you to lift without the leveling kit. So you can get back to the same height even with removing the leveling kit and that's exactly what the best path forward is. You will need UCA's at that height though. You could leave the block (rear portion of leveling kit) out back if you didn't want to do an AAL/leaf pack but I would recommend an AAL over a block. They aren't too pricey.
  8. Apr 20, 2018 at 7:47 AM
    tjpratt
    Travis
    Aurora, Colorado
    Thanks a ton man. You've been very helpful.
    I think AAL sounds like a better solution in the rear, but I'm just afraid of it being too stiff. idk. I'll look in to new shocks / coilovers. prices and options.
    Argo98 likes this.
  9. Apr 20, 2018 at 9:31 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    I’ve had mine for about 4-5 months now, 6k miles later and I’ve had no issues at all. Granted I only lifted 1” to avoid this too. You could try a diff drop if you end up getting it to see if that helps. I want to lift more but don’t want to deal with the bushing now. Maybe when I upgrade I’ll swap it out while I’m under there.
    Doublenickel[QUOTED] likes this.
  10. Apr 20, 2018 at 9:45 AM
    MikeyD.25
    MikeyD.25 Well-Known Member
    Thanks for your service! Stay safe out there...all of you!!!
    Argo98 and tjpratt[QUOTED][OP] like this.
  11. Apr 20, 2018 at 8:26 PM
    tjpratt
    Travis
    Aurora, Colorado
    This is the reply I got from Kings:
    "3" lift is the limit of the factory suspension and is not recommended. Our OEM performance coilovers add approximately 1.5" of lift in the front and that is where the best ride will be. Should you decide to go with a 6" lift company which supplies new suspension components, IE Drop down brackets or new sub frame, to properly raise the vehicle height we can build custom shocks to fit the new longer dimensions."
    I need more than 1.5". And I don't want a 6" drop down bracket lift. I thought they could provide me a stand alone coilover/front Shock/back package. Then I could add some UCA's in the front and an AAL in the rear. That email made it sound like they don't offer a stand alone coilover/shock package that lifts over 1.5"
  12. Apr 20, 2018 at 8:41 PM
    alimjr
    alimjr Well-Known Member
    Almar
    Southern California
    2018 Magnetic Grey Tacoma TRD Sport
    -TRD Pro Grill -TRD Shift Knob -OEM Side Steps -BakFlip MX4 -FN FX Pro Wheels -Toyo OpenCountry AT2 265/70/17
    What kit are you using and where did you get it from? Thanks
  13. Apr 20, 2018 at 9:35 PM
    Rustytaco71
    2018 4Runner
    Just 5100’s all around, 1” block in the rear. I got it from Headstrong Off-Road.
    alimjr[QUOTED] likes this.
  14. Apr 20, 2018 at 9:51 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    I would honestly pick a route for lifting the vehicle and stick to it. Putting performance coil-overs on and then adding spacers is not a good idea.
    IMO you should just get a decent set of springs and shocks for the fronts and a decent set of rear shocks and a new leaf pack in the rear if you are loading the bed a bunch. 1.5" looks great and you won't run into issues with staking lifts. Is there a reason you want more than a 1-2" lift?
    Also, don't think you need to spend 3-4k to get a good setup. Kings, Bilstein 8112, ADS, are great, but overkill for the majority of people on here and are in no way the only way to go.
    Get the best you can afford.
  15. Apr 20, 2018 at 9:53 PM
    #35
    JWFortin
    JWFortin Well-Known Member
    Jer
    Southern Ontario, Canada
    '17 Blazing Blue Double Cab Off-Road
    Every ME-SO mod but Bro Pro tails and 3rd brake - SCS SR8's with 255/85R16 ST Maxx - Prinsu Rack with Cali raised 42" slim light bar - TRD Pro grill - SDHQ dual behind the grille light mount with 2x 32" light bars - Cali Raised low profile ditch mounts with Cali pods - BakFlip MX4 Tonneau - WARN Semi-Hidden winch mount bumper - Bilstein 5100's all around with OME 887's - Anytime front/rear camera - Matte black EGR in-channel window visors - Matte Black Nox-Lux Overlay/Tailgate inserts - Interior Blackout kit (incl. black Highlander door handles and Sienna mirror control knob)/Blue door sill/glove box inserts Still wanting: Pelfreybilt or Mobtown Off-Road rear bumper
    I'm curious, did you get new UCA's as well?
  16. Apr 20, 2018 at 10:07 PM
    #36
    Rustytaco71
    2018 4Runner
    Nope, at 1” of lift all around you don’t need them.
  17. Apr 21, 2018 at 7:36 AM
    #37
    Doggman
    Alabama
    2017 TRD OR MT
    What they say isn't wrong but their coilovers are adjustable up to 3" lift. It's not recommended (by them) and ride will be a bit stiffer. This is the route most people go though and it's the best way to get 3" of lift if you have to have it.
  18. Apr 21, 2018 at 7:45 AM
    #38
    tjpratt
    Travis
    Aurora, Colorado
    I feel like I'm getting pushed in to a 6" drop bracket. I guess its that or push those kings to 3".
  19. Apr 21, 2018 at 7:49 AM
    #39
    Doggman
    Alabama
    2017 TRD OR MT
    Yeah, just depends where you're at on how much lift you need.
    If it absolutely has to be 3"+ then yeah you are stuck with maxing out coilovers or going drop bracket. I personally would still go maxed coilovers over drop bracket every day of the week.
    I'd urge you to consider coilovers set at more like 2-2.5" of lift. That's the sweet spot that a lot of people go for. Most reports say it still rides pretty good at those heights.
    tjpratt[QUOTED][OP] likes this.
  20. Apr 22, 2018 at 11:54 PM
    #40
    tjpratt
    Travis
    Aurora, Colorado
    Has anyone used this kit? This is at the top of my list right now.
    2nd on my list is honestly putting some better shocks on all 4 corners and the Dakar Medium Spring set in the rear.
