Leveling Kit
Discussion in 'Wheels & Tires' started by Mugambo, Sep 23, 2011.
  1. Sep 23, 2011 at 4:12 PM
    Mugambo
    Mugambo [OP] Well-Known Member
    Todd
    Reno, Nevada
    07 Access Cab
    Leveling Kit
    I apologize if this has already been covered.
    I have a 2007 Taco with a Toyota leveling kit. I believe it is 2.75" on the front and 1" on the back???
    I was wondering what the largest size tire I can run on my truck with that leveling kit is? I hate the space that I have in the fenders now.
    Also with a larger size tire does it throw the speedometer off so drastically that one should get it calibrated for those new tires?
    If I could get some help I would really appreciate it, thanks.
  2. Sep 23, 2011 at 4:20 PM
    Mugambo
    Todd
    Reno, Nevada
    07 Access Cab
    Leveling Kit
    I don't mind having to trim, I really would just like a larger tire on my truck. Does that mean I need to go with a larger lift then the leveling kit?
  3. Sep 23, 2011 at 4:37 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    The largest tire size you can run with trimming is 285/75/R16
    But you will also need new wheels with a 4.5 BS or if running OEM wheels they will require wheel spacers to clear the UCA.
  4. Sep 23, 2011 at 4:40 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    fixed ;)
  5. Sep 23, 2011 at 4:41 PM
    Mugambo
    Todd
    Reno, Nevada
    07 Access Cab
    Leveling Kit
    Ok sweet!! I was planning on going with new wheels too so thank you both very much that's what I needed to know.
    I have one other question though. With those larger tires is the change in the speedometer so drastic that one should get it calibrated for those tires?
  6. Sep 23, 2011 at 4:45 PM
    CGtaco
    CGtaco Well-Known Member
    Phillip
    07 Tacoma TRD 4x4
    Fog light Mod Total Chaos UCA's Front Icons Rear Icon / res
    I have the same leveling kit on my 07 right now. I went from the stock 265/70-16 to toyo mt 265/75-16. No rubbing on the UCA but on the Lower I DID. No one has ever stated this.
