leveling kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brandanstringer, Sep 11, 2014.
  1. Sep 11, 2014 at 5:53 PM
    Brandanstringer
    Brandanstringer [OP] New Member
    Brandan
    north palm beach, fl
    13 double cab 4x4 limited
    Has anyone put a leveling kit on their tacoma? I have a 2013 double cab long bed limited with 18" wheels. I'm looking to raise the front end and get some bigger tires....any suggestions are greatly appreciated!
  2. Sep 11, 2014 at 5:57 PM
    TaylorU
    TaylorU KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
  3. Sep 11, 2014 at 6:02 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The most popular leveling kit is the adjustable bilstein 5100. You can use the factory spring or replace it with an aftermarket.
  4. Sep 12, 2014 at 3:56 AM
    Brandanstringer
    Brandan
  5. Sep 12, 2014 at 7:22 AM
    TaylorU
    Taylor
    Flagstaff, Arizona
    Basically it boils down to budget and application. If you're the average weekend off roader and don't have $1500+ to spend, the 5100 route is certainly the way to go from everything I've read here on TW.
  6. Sep 12, 2014 at 12:49 PM
    Swampeast
    Swampeast mud member
    Missouri
    2013 DC Off-Road
    Wet Okole TRD seat covers, SnugTop Super Sport, Bilsteins 5100 front 1.75, Bilstein 5100 rear, 1/2" Toytec AAL, Swaybar relocate kit, differential drop, ND4's fog light anytime, Relentless Fabrication brackets with Rigid Industries D2 with AirOnBoard center switch 923B, rear view mirror relocate bracket, N-Fab front light bar
    I put Bilstein 5100 on the front set at 1.75 with my factory springs. I put Bilstein 5100 on the rear with a 1/2" Toytec AAL. I pull trailers and have a camper shell on my vehicle thus I put the AAL on.
    Measure from the center of the hub to the fender to get you height differences. This will let you know how much you want to go up in front to level.
    I did not want my vehicle level.
    My truck is an 2013 Off-Road and stock it was 20.25" front and 21.5" rear (without shell). Now it is 22" front and 23" rear. I put the camper shell on and my truck did not lower any.
    You can see the front is now 1.75" higher just as set on the Bilsteins. If I did nothing to the rear of the vehicle, the front would be .5" higher than the rear. If your vehicle is like mine, you would use the next lower setting on the Bilsteins to be level.
    My vehicle rides and handles great. Hope this will help some.
  7. Sep 12, 2014 at 12:59 PM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    I vote for the Toytec Boss coil overs. Super ride. Easy to install. Once I found out that a spacer was basically a more difficult install, I just ponied up the monies for the good stuff. So far I'm extremely satisfied. Tire choice is also going to play a HUGE roll in how it handles and feels.
  8. Sep 12, 2014 at 1:04 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Lifts of this sort will not help you fit larger tires. You can put the same sized tires on a stock truck then you can a lifted truck and they will both bottom out the same because your not changing the geometry of the suspension. All you do with this kind of lift is put more pre load on the truck which = less downtravel and also = a crappy ride on rough roads compared to stock IMO.
  9. Sep 12, 2014 at 1:10 PM
    pittsnogled
    pittsnogled I like turtles
    kirk
    South Carolina
    2014TRDsport
    5100's all around with OME 884 at 0. Weathertechs, Carhartt seat covers. BFG KO2's 265/70/17. T4R SEMA wheels. 18% tint on front windows. General Springs HD 4 leaf pack, Leer 100 XR shell.
    I just got mine finished yesterday. did 5100's all around with the fronts set at 0 and OME 883 coils
    I cant compare the ride against anything but the stock setup but it rides nice got a great alignment and im very happy.
    brought the front up 1 and 1/4" and still have about a half inch of rake.
  10. Sep 16, 2014 at 5:14 AM
    Brandanstringer
    Brandan
    thanks for all the information, I still have about 20000 miles left on my original tires so I have a little time before i do anything so i will keep watching the boards for similar subjects.
