Leveling kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dtay4197, Nov 6, 2015.
  1. Nov 6, 2015 at 8:54 PM
    dtay4197
    dtay4197 [OP] Well-Known Member
    Dustin
    silver 2007 trd offroad
    2.5 bilstiens, colormorph retrofit halos and fogs, urd maf cal, Urd tcai, 20x12 mo962, 33x12.50x20 iron man mts
    Recently ordered a set of 3" Coil spring spacers for my 07 trd off-road not thinking muvh about it I got to reading and the description says DOES NOT fit trd off-road models? Does anyone know why this might be?
  2. Nov 6, 2015 at 8:57 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Assuming it'll ride harsh as hell, idk why it won't fit off-road, sport, or base model 6 lug
  3. Nov 6, 2015 at 9:02 PM
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    The spacers should fit the TRD Off-Road models. There is no difference in models other than the progressive coil in the coilover assembly on the Off-Road. Make sure you adjust your front bump stops accordingly to compensate for the spacers, or you may snap a strut.
    Justus likes this.
  4. Nov 6, 2015 at 9:03 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Link to the product? Not exactly sure why it wouldn't fit, but who knows. You're not going to like the spacers, but that's a whole other story :oops:
    Justus and Arailt like this.
  5. Nov 6, 2015 at 9:03 PM
    dtay4197
    Dustin
    Having a mechanic who had done multiple of them hopefully he will know how to do that
  6. Nov 6, 2015 at 9:07 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Yikes. Return to sender.
  7. Nov 6, 2015 at 9:07 PM
    dtay4197
    Dustin
    Spacers are hopefully just temporary beginning of next year I'm planning on bilstein 5100ss. Just curious why I won't like them im 100% new to the front end lifting lol
  8. Nov 6, 2015 at 9:10 PM
    ZachPrerunner
    Southeast TN
    Whenever I had my spacers, the ride was extremely rough. Plus, they made my truck sit nose high. You can try them out, but I wouldn't pay a shop to put them on. To me, it would be worth the wait for the 5100's.
  9. Nov 6, 2015 at 9:13 PM
    dtay4197
    Dustin
    Was planning on 5100s all the way around and AAL in rear and completely forget blocks and spacers
  10. Nov 6, 2015 at 9:14 PM
    dtay4197
    Dustin
    Supreme Suspensions - Tacoma Lift Kit 3" Front Suspension Lift CNC Machined T6 Aircraft Billet Strut Spacers (Black) Easy Install Toyota Tacoma Leveling Kit PRO https://www.amazon.com/dp/B00HV2KF7I/ref=cm_sw_r_awd_kFypwb8SNCHCW
  11. Nov 6, 2015 at 9:17 PM
    ZachPrerunner
    Southeast TN
    I am running 5100's all around with a one inch block in the back. My current leafs are shot, so I didn't want to spend $125+ on an AAL when I could get a block for $60. I'm currently deciding on whether I want to upgrade to some Dakars or wait for the Toyota recall that "should" be coming up within the next year. You'll like the 5100's as long as you don't max them out! :thumbsup:
  12. Nov 6, 2015 at 9:19 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
  13. Nov 6, 2015 at 9:19 PM
    dtay4197
    Dustin
    Yeah would be pointless in aal now that I think of it. Until toyota resolves the leaf spring issues that is.
  14. Nov 6, 2015 at 9:20 PM
    dtay4197
    Dustin
    Fill me in.
  15. Nov 6, 2015 at 9:21 PM
    ZachPrerunner
    Southeast TN
    Yeah, those spacers may create some alignment problems. Considering they are advertising for a full 3 inches in lift, your UCA's might not like that too much.
  16. Nov 6, 2015 at 9:21 PM
    Kieran
    Kieran Friendly Neighbourhood Canadian
    Toronto
    09 Access Cab V6 TRD OffRoad
    None yet.
    oh another $65 lift on a $xyz dollar truck... ditch the spacers and save up to get the 5100s, coils and AAL... take it from a lot of people on here you won't be disappointed...
    spacer lifts are like stuffing with a rolled up tube sock... she will find out you have stock suspension...
  17. Nov 6, 2015 at 9:23 PM
    dtay4197
    Dustin
    Found a kit with 5100s all the way around and new UCA's for around 650 should I just wait for tax season to come around and do it that way?
  18. Nov 6, 2015 at 9:23 PM
    ZachPrerunner
    Southeast TN
    If you'd actually read the thread, you'd understand his plan. :frusty:
    dtay4197[OP] likes this.
  19. Nov 6, 2015 at 9:25 PM
    ZachPrerunner
    Southeast TN
    To be honest with you, I wouldn't even fool with that spacer kit. You're going to spend a lot of time and work for something that might cause you a lot of headache. I would wait it out and install something that would be worth your time. I did the same thing and ended up regretting the spacer kit. The 5100's are worth the wait over those spacers.
  20. Nov 6, 2015 at 9:26 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Uhh yeah let's not ruin your ride and waste your time. Do it right the 1st time. I would suggest saving for something better quality.
