leveling kit
Discussion in 'Suspension' started by toot123, Nov 8, 2018.
  1. Nov 8, 2018 at 4:08 PM
    toot123
    toot123 [OP] New Member
    2017 toyota trd sport 4x4 4door
    leveling kit front 2 inches--rear 1 inch
    I have a 2017 Toyota trd sport 4x4 4 door .I put a lift kit on it 2 inches front and 1 inch in rear just wanted level it up a bit .now I have a vibration in the front it feels like I am running over a rumpule strip but not that hard.I had the truck alined . when I go between 25 to 35 mph I can really feel it.when I put truck in 4 wheel drive it stops. Toyota garage said it might be a small gear in axle but they checked it and said it wasn't.they said someone makes a replacement gear to take out the play in axle if that's the problem.Just wondered if anyone has heard or had that problem
  2. Nov 8, 2018 at 4:16 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
  3. Nov 11, 2018 at 9:22 AM
    270wsm
    270wsm Well-Known Member
    AZ
    did you install the spacer block in rear ,did you install block with high side facing to rear and front shorter end facing forward if install backwards it can cause vibe
