Leveling kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Grndean6, Aug 24, 2019.
  1. Aug 24, 2019 at 9:13 PM
    Grndean6
    Grndean6 [OP] New Member
    Aj Amorim
    2019 Tacoma trd 4x4 offroad
    3" front 2" back with swaybar relo
    We installed a 3"front and 2"back with the 1/2" swaybar relocated. We have checked all the bolts to make there tight. But there is a clunk sound in the front when we go over a 8"curb. What could have caused this?
  2. Aug 24, 2019 at 9:18 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    What front shocks are you using, they may be overextending. Or do one of the upper control arms hit a coil?
    t0nyvalenzuela likes this.
  3. Aug 24, 2019 at 9:20 PM
    Grndean6
    Aj Amorim
    How do we check for that
  4. Aug 24, 2019 at 9:29 PM
    Grndean6
    Aj Amorim
    We watched a few videos but they were all for a 6" lift . those included a differential drop with C Arms.
  5. Aug 24, 2019 at 9:31 PM
    Techsan
    Techsan Well-Known Member
    South Texas
    2017 BBPDC
    Depends on how fast you were going when you hit the curb.
    OnHartung'sRoad likes this.
  6. Aug 24, 2019 at 10:18 PM
    OnHartung'sRoad
    We really have to know what you got to be able to help, otherwise its just something making noise.
    What type of lift is it? Spacers?
    What is your suspension? If your shocks are OEM, or even 5100’s, at 3” you are overextending them.
    Did you put in new coils and control arms? They may be hitting.
    Skid plate or other hardware? Some had bumping noises from those too.
  7. Aug 24, 2019 at 10:44 PM
    TacoPharm
    TacoPharm Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
    Most likely the upper control arms contacting the spring when the wheels come down, same thing happened to me when I put my kit on without changing the upper control arms. To check you can either jack up the front end of the truck until the wheels are off the ground, look at the upper control arms and see if they are touching the spring. If they are you need to purchase some. You will also see the paint/powder coating getting worn on the outer edge of the contact point.
    Once I changed UCAs, the clunk went away, and the ride improved drastically
    OnHartung'sRoad, VaToy and grubburg like this.
  8. Aug 25, 2019 at 3:49 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    You have a front skid, the trd aluminum and some others won't fit right without spacers or it will hit and make noise. Diff drop lowers the arms close to the skid and will hit. And is it when going up compressing the suspension or down extending it that you get the noise
  9. Aug 25, 2019 at 4:54 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Guessing it's the stock shocks over-extending, if you just used a spacer up front.
  10. Aug 25, 2019 at 9:29 AM
    OnHartung'sRoad
    Maybe its the mall cop wapping his baton on the side of his truck telling him to stop driving on the sidewalks and off the curbs? :notsure:
    OP: JK- but we really dont know enough about your suspension to help much.
    black_angus1 likes this.
  11. Aug 25, 2019 at 9:36 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    I work on my suspension a lot. Taking shit apart putting it back together. Changing ride height on my 5100s. Replacing ball joints. I put shit together right and sometimes I even use a torque wrench. (I'm a professional mechanic btw) and my suspension still makes noise every once in a while. I've never had anything break on me and when I inspect for play or loose nuts or bolts I find everything is good. Probably nothing to worry about, but if you have stock UCAs the ball joint is probably being maxed out.
