Leveling kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dylan209, Dec 25, 2019.
  1. Dec 25, 2019 at 5:02 PM
    dylan209
    dylan209 [OP] Member
    Toyota
    Quick question, probably heard alot. Dont hate. So I got a Pro Comp 65205k leveling kit for my 2019 sr5 4x4 for Christmas. The guy at 4 Wheel Parts said this was correct but the information on it says 2005 - 2011 tacoma. Is it still usable on a 2019? Is it the same bolt patterns for the front spacer or is it completely wrong..
  2. Dec 25, 2019 at 5:04 PM
    Truc577
    Truc577 Well-Known Member
    Curt
    NOMO
    2005 TRD OR 4x MT, 2020 TRD OR 4x AT
    High output valve stem caps 2020: Bilstien 6112/5100 Mobtown sliders RRW RR-5 Bronze wheels 2005: 2018 frame and full suspension 2017 Dark Anthracite wheels ARB front bumper
    Same
    I have one on my 05’ that I originally ordered for my 17’.
    Welcome!
    whatstcp likes this.
  3. Dec 25, 2019 at 5:06 PM
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
  4. Dec 25, 2019 at 5:11 PM
    Bishop84
    Bishop84 Well-Known Member
    It's usable, but the problem is the 05-15 models sat 1" lower, so when you level a 16+ with a 2nd gen kit, it sits high in the front.
    So 3" front, 1" rear will have a reverse rake. But this was a standard level with the 2nd gen tacomas.
    Ideally, you want 2-1/4" front and 1" rear.
    Also, if you do a leveling kit on a 4x4 model, it will need a ECGS bushing on the axle, as the lift puts strain on the cv axle causing an annoying vibration.
    Lastly, most leveling kits come with a diff drop spacer, do not install this.
    Truc577 likes this.
  5. Dec 25, 2019 at 5:17 PM
    Truc577
    Curt
    NOMO
    Excellent correct advice right there!
  6. Dec 25, 2019 at 5:20 PM
    dylan209
    Toyota
    Thank you for the info! Im relieved now.
  7. Dec 25, 2019 at 5:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    whatstcp, Hobbs and GreyBaldTaco like this.
  8. Jan 31, 2020 at 5:45 PM
    keygrip
    keygrip Well-Known Member
    Greg
    Catskill Mountains, NY
    2020 Tacoma TRD offroad, DCLB, magnetic grey metallic
    2" Fox 2.5 performance elite dsc front lift, 33" KM3 (summer),265/75 r16 KO2s (winter), led bed lights, remote start, vhf/uhf radio, trailer brake controller, Jericho mid rise cap, US Offroad winch cradle, Warn Zeon 10k winch, Martin Offroad roof rack, Deaver stage 2 leafs, u bolt flip, Duro bumps front/rear, Overland Tailor tune, Cali-raised trail rock sliders, Cali-raised full skid plates, SPC UCAs.
    Why not install the diff drop spacer? I'm curious and new to Tacomas. Thanks
  9. Jan 31, 2020 at 6:13 PM
    keygrip
    Greg
    I'm asking why to Bishop84.
  10. Jan 31, 2020 at 6:19 PM
    Bishop84
    It has no "Pro" only cons. I have installed many leveling kits and we used to always use the front diff drops, until the 16's came out. I put the diff drop with the leveling kit and we were surpised to see the diff vibes right away.
    The strain on the front axles didn't change with the diff drop, and many leveling kit manufacturers started to add instructions to NOT install the diff drops on the offroad models.
    Next it lowers the impact point of the differential, and if you bottom the skid plate out, it rams the front diff into the oil pan.
    Lastly, it rotates the diff rather than entirely droping it, meaning the pinion is pointed at a poor angle. This hasn't resulted in any failures that I've seen, but can't be good for driveline vibrations.
    No diff drop has ever stopped the axle vibration from lifting, so it's basically a waste of money and time.
