Leveling kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kennyray, Jul 15, 2023.
  1. Jul 15, 2023 at 12:52 PM
    Kennyray
    Kennyray [OP] Member
    2022 tacoma
    I just installed a 2” rough country leveling kit. Per kit measurement had my rear just over 2” higher. Now that the leveling kit is on, the front is 1-1/4” higher than the rear!?!? I haven’t had the alignment done yet scheduled for Monday morning. Will that possibly bring the front down or am I gonna have it raise the rear…definitely don’t want anything that even sort of resembles a Carolina squat lol
  2. Jul 15, 2023 at 12:54 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Welcome!
    I don’t think you’ll have any adjustments in a spacer lift,,, is what it is
    Kennyray[OP] likes this.
  3. Jul 15, 2023 at 12:59 PM
    Kennyray
    2022 tacoma
  4. Jul 15, 2023 at 1:01 PM
    Kennyray
    2022 tacoma
    Yeah I don’t either, but this is the first one I have installed myself. Usually have them put on and alignment done all at once. Looks like a block in the rear is my only choice
  5. Jul 15, 2023 at 1:04 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Careful not to stretch the rear brake lines and check driveshaft/pinion angles.
    BigEasy and Stevie17 like this.
  6. Jul 15, 2023 at 1:38 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    Can you not adjust the front struts up a notch? I just put some bilstein 5100's on and the rear didn't have any thing to make it level just the front. Shop that put mine on said out of all the levels and lifts he's done Rough country never include instructions, it's all a guessing game. :thumbsup:
  7. Jul 15, 2023 at 2:36 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    The Bilsteins are adjustable, but the OE spring perches are not, a spacer lift is simply that,,, adding a spacer on top of the OE non-adjustable spring combo.
  8. Jul 15, 2023 at 2:38 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Yeah….you have to lift the rear if you want it to be level.
    I used to have the same rough country kit. I had to install a 1” block in the rear in order to make it level because my truck had the Carolina squat after I installed the rough country level kit. It looked terrible until I lifted the rear.
    Stevie17 likes this.
  9. Jul 16, 2023 at 5:56 AM
    Kennyray
    2022 tacoma
    Did the block kit cause any issues with the drive shaft or anything else
  10. Jul 16, 2023 at 6:03 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I put a 1.5" block for the back (2.5"front) and have had no issues with anything. I did install the carrier bearing spacer. (swaybar spacer - front) but that was it.
    My truck was only 1.5" higher in back. Did the 2.5/1.5 to leave a 1/2" rake
  11. Jul 16, 2023 at 8:48 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    What happens when you load Rig Up? Ass Sag. Never understood the level look.
  12. Jul 16, 2023 at 10:30 AM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    While running a 1" rear block I found the rear started to settle over time, and settled even worse with any meaningful weight in the back, so despite it being termed a level kit in practice it definitely wasn't going to stay that way long term. I just replaced the leaf packs with a 1.5" lift set, and now the ride is both better quality and the rear sits slightly higher than the front for normal driving (so under load it should be near level). Based on my experience, I would aim to have the rear sit higher than the front with the expectation the rear will sink down over time and with payload which will then level the truck out.
