leveling kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scottd1975, May 19, 2025.
  1. May 19, 2025 at 10:21 AM
    scottd1975
    scottd1975 [OP] Well-Known Member
    scott
    2023 Tacoma TRD Sport
    Ok i know what the name implies just wondering what part of the truck its leveling? I don't notice the front being nose up or down. How much of a difference does it make?
    Tocamo likes this.
  2. May 19, 2025 at 10:33 AM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Typically a leveling kit would be to raise the front equal to the rear. With a 23 sport I'd imagine your truck stock is still slightly higher in the rear?
  3. May 19, 2025 at 10:34 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    A leveling kit is generally a spacer for the front suspension to bring the front up to remove the rake difference to the rear.
    Typically the leaf packs sag so fast and easy you lose that rake regardless. Now if you have a leveling kit and your leaf pack sags you now end up with a front high vehicle. Which looks bad handles bad. It's just all around bad.
    Trucks should always have rake unless you never intend on putting anything beyond groceries in the bed. The rule of thumb would be for every inch you lift the front you should lift the rear to match. Having around 1-2" of rake from front to rear when unloaded.
    71tattooguy likes this.
  4. May 19, 2025 at 12:57 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    leave it stock
    Burns and scottd1975[OP] like this.
  5. May 19, 2025 at 1:07 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Lifting the front 1" levels the truck. Doing a 2/1" lift levels the truck. > 3/2" excetera....
    If you can budget it, use something like a Bilstein 5100 to lift the front 1-2", instead of a spacer lift.
    if your doing a 2/1" lift, you can get away with a 1" block in the rear. If you plan on putting a lot of weight in the rear, use an add a leaf (AAL), instead of the block. Most people don't agree with going with a 2" block in the rear, and I agree with them.
    yoeltimeisup likes this.
