leveling kits and tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by armstrong, Nov 20, 2011.
  1. Nov 20, 2011 at 7:01 PM
    armstrong
    armstrong [OP] Member
    PA
    04 Toyota Tacoma
    3'' lift
    will a 3'' front 2'' rear leveling kit allow 285/7516?? on a 04 xtra cab
  2. Nov 20, 2011 at 7:02 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Welcome to TW. You will need wheel spacers, and to trim some fender well plastic and possibly chop your cab mounts. This is one of the most commonly asked questions on this site. You might try a search next time.
  3. Nov 21, 2011 at 12:02 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    do some searching man. Also you will need to either do the boot slide mod or just get some new aftermarket CVs to prevent them from tearing.
  4. Nov 21, 2011 at 3:45 PM
    armstrong
    PA
    04 Toyota Tacoma
    3'' lift
    i ordered some 285/75r16 pro comp xtremes and some 6by8 pro comp wheels with 4'' backspacing from 4 wheel parts or something like that, the guy said it would work with 3'' leveling kit, i also bought a diff drop only thing i should have to worry bout is a lil bit of trimming right???
  5. Nov 21, 2011 at 4:37 PM
    KPT
    09 Prerunner
    You will need new upper control arms to get your alignment in spec. Also I'd recommend against leveling kits.
  6. Nov 21, 2011 at 4:44 PM
    TG8
    TG8 Well-Known Member
    Trey
    Laredo, Texas
    2011 Tacoma Trd Sport 4x4
    STOCK STOCK STOCK SUCK STOCK STOCK WeatherTech Floor Mats All-Weather throughout the truck Smittybilt Bull bar with Hella 500 Series Halogen Driving Lamp (2)
    Leveling kits bad
    new Coil overs good
  7. Nov 21, 2011 at 6:37 PM
    armstrong
    PA
    04 Toyota Tacoma
    3'' lift
    y are leveling kits no good?
  8. Nov 21, 2011 at 6:37 PM
    KPT
    09 Prerunner
  9. Nov 21, 2011 at 8:29 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Even with a 3" lift and trimming of the pinch weld (no cab mount, thats only 2nd gens) The 285s will still rub on the frame when you get close to full lock.
    I havent have problems with my axles after 20k+ miles and my alignment was okay only the caster was off a little bit.
  10. Nov 23, 2011 at 12:58 PM
    TG8
    Trey
    Laredo, Texas
    If your looking to off roading I would highly recommend putting some new coil overs. Makes the ride a lot more comfortable co's Brands are intended for offroad uses
    If your looking for looks and maybe very minimal off roading get a spacer lift i have friends that have spacers and one time my friend hit a pot whole and the spacer broke in half with I only having one month of use
