Leveling Kits/Spacers Opinion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by daniel batista, Feb 9, 2021.
  1. Feb 9, 2021 at 12:26 PM
    daniel batista
    daniel batista [OP] Member
    Daniel
    2021 Toyota Tacoma SR5 2WD
    I've heard so many different opinions about spacers. I have a brand new 2021 Tacoma and people have told me to either stay away from spacers or that it's not all that bad. I just purchased new tires 265/75/r16 and I wanted a 2" lift on front and 1" on back.
    Can anyone give me their opinion and/or recommend a specific brand if I were to use spacers.?
  2. Feb 9, 2021 at 2:09 PM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    My buddy has a spacer lift. He strictly did it for the looks only. If that's what you are going for, you'd be fine. Are all spacer lifts the same? I would think so. Just buy a reputable brand.
    tektaco84, 71tattooguy and whatstcp like this.
  3. Feb 9, 2021 at 2:13 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    You could ease your mind and get eibach kit or Bilstein 5100’s would be fine for daily driver weekend warrior fun IMO. Went down that route at first and replaced spacers immediately after learning about lifts.
    Good Luck OP
    Aqualoon likes this.
  4. Feb 10, 2021 at 8:30 PM
    j0shxp
    j0shxp Active Member
    OKC, OK
    2021 Tacoma TRD Sport
    Floor mats count? It’s a work in progress.....
    I just installed a 2”/1” spacer lift a few weekends ago. I was mostly going for looks. The extent of my off-roading will be camping and MTB trails so I didn’t feel I needed to go full suspension lift. That being said, I will eventually go with a Bilstein or Eibach kit.
    I went with the Supreme Suspensions kit. It included the diff drop, sway bar relo bracket and shims for the rear blocks.
    https://supremesuspensions.com/coll...ders-and-shims-4wd-4x4?variant=21410646687824
    71tattooguy likes this.
  5. Mar 12, 2021 at 5:37 AM
    turkeycreek29010
    turkeycreek29010 Well-Known Member
    Chuck
    Bishopville, SC
    2021 TRD Offroad
    TRD Lift, MKW Offroad M205 Bronze 17 x8.5 wheels, 265/70r17 General Grabber ATX, Hikari LED Headlight Bulbs, Diode Dynamics SS3 Max Amber Fog lights, Tyger Rollup Bed Cover, OEM Bed Mat, Havoc OffRoad HS2 steps
    I'm considering doing do the same on my 2021 OR. I have been researching and see the needle bearing issue popup a lot. Is this still the case on 2021 models? Would this need to be addressed also with a 2in spacer level?
  6. Mar 12, 2021 at 6:04 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Spacer up front will most likely get you nose high. Needle bearing issue happens for some and some not. Every truck is different. I have bearing on hand if and when it goes.
    Good luck
  7. Mar 12, 2021 at 6:15 AM
    turkeycreek29010
    Chuck
    Bishopville, SC
    2021 TRD Offroad
    Going back and forth between 1.5" and 2" spacer in the front and 1" block in the rear. I just want touch more height. I'll go ahead and get the esgs bushing then when I order everything. I rather take care of it up front rather than dealing with it later. I have a Tundra before this with 3/2 level. Apparently just a Tacoma issue.
    71tattooguy[QUOTED] likes this.
  8. Mar 12, 2021 at 8:35 AM
    Gigan
    Gigan Well-Known Member
    Inland Empire
    2021 AG TRD Sport LB
    I have a Sport that I lifted for looks and due to my height. (6’8”) I did care for the floating after hitting road bumps so I went with the Eibach kit. It made the ride better for me by a lot. I heard the spacer/block lift does not change the ride quality. Since I wanted the change I forked over the money for the suspension lift and I’ve been happy. If I liked the ride I had I probably would have did a spacer/block lift. I’ve also heard the spacer/block lift is harder on your truck though not sure how factual this is.
    Dso101 likes this.
  9. Mar 12, 2021 at 8:51 AM
    Dso101
    Dso101 Well-Known Member
    David
    Bay Area
    2020 Toyota Tacoma TRD Sport
    I'm thinking of getting the Eibach kit as well. Which snap ring did you set it at? According to Eibach, they said the top 2 snap rings will raise it 2.5"+ but may cause degradation of ride quality. I do plan on getting some armor in the later future and trying to think if I should set the suspension now to accommodate that or change it accordingly after the armor is installed. Any photos? Thanks!
  10. Mar 12, 2021 at 8:57 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
