leveling/life question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SoCalTbird, Jun 24, 2017.
  1. Jun 24, 2017 at 8:46 AM
    SoCalTbird
    SoCalTbird [OP] Well-Known Member
    South OC
    06 PreRunner DCSB 05 AC 4X4
    Has anybody lifted/leveled the front and left the rear alone? i have been reading a bunch of threads about front&rear. I know you're supposed to to the 2 together. The reason i ask is in past I had a ranger that I installed "lifted" Ibeams and shocks and left the rear alone. It actually drove better with the rear end slightly "pre-loaded" like that. Just wondering if the same holds true for these tacoso_O thanks in advance for the input:thumbsup:
  2. Jun 24, 2017 at 8:56 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    I did a spacer in the front only and ran it like that for several years until I found Tacoma world:taco:. If you don't want to spend a few grand and want a stiff ride then do it. Otherwise save your money and buy some ADS or King coilovers. If you do any kind of off roading I would stay away from a spacer kit.
  3. Jun 24, 2017 at 8:58 AM
    Tacoturtle
    Tacoturtle Well-Known Member
    Trey
    Athens, Ga
    2015 red dcsb sport
    I have done my front with 5100s and OME 884s, and now that it's settled I'm deciding what to do with my rear. Currently, I'm about 1.5 inches higher in the front.
    I haven't really noticed much difference in the ride quality, but my OEM only had about 40k on them. I would say the front end feels a little stiffer, which is good to me because I thought it felt a bit "squishy" before.
    SoCalTbird[OP] likes this.
  4. Jun 24, 2017 at 8:58 AM
    SoCalTbird
    South OC
    i was looking more into the 5100's and maybe some OME springs down the road, wouldn't do spacers, can't really justify 1K on suspension for the couple of mex trips i have
    desertrunner24 likes this.
  5. Jun 24, 2017 at 9:02 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    5100 or 6112 are your best bet on a budget. Lots of people run them and I haven't heard anything bad about them
  6. Jun 24, 2017 at 9:15 AM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    I did Bilstein 5100'S on the front only. Rear Leaf springs were replaced under the recall by Toyota.
