Leveling/Lift setup
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jtwarburton1991, Jul 17, 2018.
  1. Jul 31, 2018 at 6:34 AM
    #41
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    Before these I had on 265/70/17 that were load range D. These are indeed load range E. I saw threads on here stating that with the 33’s I should run 40 psi, which is what I’m currently set at. With my 265/70’s for the last 5,000 miles I was running around 42-44 psi, and the traction was much better. I would also think that these tires are just bad in the rain, however other than a difference in size, they are exactly the same tire.
  2. Jul 31, 2018 at 6:38 AM
    #42
    BOSS-DS2
    Sam
    Texas
    I think ultimately like you said it’s due to the tire compound being much harder. The ride quality is about the same I would say but perhaps when cornering or under excessive braking I might be getting very minute amounts of wheel hop which is attributing to the loss of traction.
  3. Jul 31, 2018 at 8:18 AM
    #43
    Jrazzle
    Jrazzle Well-Known Member
    Denver, CO
    no. your truck is too light for load range e tires and the tires are not developing enough traction. it is not wheel hop. do a chalk test. when you do the test, you can set your pressures so the full tread area is in contact with the ground.
    https://www.youtube.com/watch?v=ojGsavK0Uwc
    BOSS-DS2[QUOTED] likes this.
  4. Jul 31, 2018 at 8:23 AM
    #44
    BOSS-DS2
    Sam
    Texas
    Okay thank you. Will do it this weekend if I have time off from work.
  5. Jul 31, 2018 at 8:38 AM
    #45
    Hutch587
    Hutch587 Member
    Shawn
    Central Florida
    2018 SR5 MGM
    16x8 0mm offset Helo wheels
    I bought a 2018 on July 2 of this year. Unfortunately over the past few days I have spoken to every dealership within 75 miles of me and they’ve all said “we used to lift the 2018 for our customers but due to the sensors in the grill, we are no longer allowed to, for safety reasons”. Yes, I know the system can be turned off, but I guess I’ll wait until my warranty expires or Toyota addresses this issues and launches a recalibration for the sensors once a lift is installed.
