leveling my 2013 tacoma prerunner
Discussion in 'Suspension' started by KhaiNguyen, Aug 5, 2013.
  1. Aug 5, 2013 at 6:28 PM
    KhaiNguyen
    KhaiNguyen [OP] Well-Known Member
    hey guys i notice that most trucks the front is always lower then the rear and im planning on just getting the top plated level kit off ebay just for like 50 bucks but i was wondering how many inches will level it out? 1.5"-2"?? thank you and i will be going with bigger tires later also maybe just to a 265/75/16 :) sorry for being a noob i just got into the truck life :p
  2. Aug 5, 2013 at 6:30 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    It should say on the kit how much it wil raise it.
  3. Aug 5, 2013 at 6:43 PM
    KhaiNguyen
    yeah it does but im wondering how much do i need to lift the front so it would line up with the back haha
  4. Aug 5, 2013 at 7:11 PM
    BLOODYMARY
    BLOODYMARY Well-Known Member
    Keith
    Tulsa, OK
    2012 Tacoma Double
    AFE Exhaust, AFE Panel Filter
    I went with Daystar Comfort Ride 3" Leveling Lift Kit for $279 and love it.
    I also upgraded to 265/75/16s
  5. Aug 5, 2013 at 7:13 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    The measuring tape is your best friend at this point... measure the hub to fender in front and hub to fender in the rear. there are no 100% similarities with tacomas in respect to height differences but rather ranges.
    Most people go anywhere between 1.75-2.5 to get level. Also, some go level without a load, and some go with a little rake, so when they do have a load they will be level and not nose high..
  6. Aug 5, 2013 at 7:15 PM
    Traction120
    Traction120 "Not all those who wander are lost"
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
  7. Aug 5, 2013 at 7:23 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    this right hurr.
    If you haul anything heavy you'll probably need to lift the rear too. level trucks sag pretty bad under loads.
  8. Aug 5, 2013 at 8:40 PM
    KhaiNguyen
    Nope not gonna have much loads that's y I got a short bed ;) but ima do some towing tho
  9. Aug 5, 2013 at 10:38 PM
    KhaiNguyen
    So do u guys think ill be better off with a 1.75 or 2.25 lift in the front? Planning on just slapping on a too plate spacer since I don't do no off roading haha
  10. Aug 5, 2013 at 10:53 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Someone mentioned using a tape measure on you present setup, measure, then make a decision....it is your truck we can't see/touch it....
  11. Aug 6, 2013 at 6:09 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    $30000 truck and you plan on 'slapping' on a $50 spacer from of all places eBay? Do your truck some favors. Get some Bilstein 5100's and set them in the middle setting and you'll thank us later. If you value your truck put some value into your truck.
  12. Aug 7, 2013 at 10:26 AM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    agreed but to each his own
