Leveling Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by AveryM, Nov 14, 2017.
  1. Nov 14, 2017 at 3:02 PM
    AveryM
    AveryM [OP] Well-Known Member
    Avery
    Central, Louisiana
    White 1997 4wd Tacoma
    31x10.5 BFG all-terrains Complete Sound system
    I just got a 97 tacoma 4x4 and i obviously want to do the typical teenage BS by lifting it and stuff, i measured from the middle of the fenderwell the ground all the way around and the truck sits at 3 feet all the way around. completely level, i dont see any leveling kit or billies, how could it be level? maybe the rear is sagging down making it level? but i want to do a 3" leveling kit and 3" blocks and put 285/70r17's on it. and i'm just trying to figure it out.
  2. Nov 14, 2017 at 4:39 PM
    Poups
    Poups Well-Known Member
    Christian
    Calgary Alberta, Canada
    2000 Tacoma 4x4
    Bilstein 5100
    There must be a spacer on the front? My 2000 4x4 with front billies set at 1st notch and newer stock leafs measures the same. With 31 inch tires. 3 feet all around. I would use a ebach/toytec lift spring lift in the front and aal in the rear.
