Leveling spacers vs shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thetacofort, Jun 13, 2020.
  1. Jun 13, 2020 at 2:21 PM
    thetacofort
    thetacofort [OP] New Member
    2010 brown Tacoma prerunner
    hey I come on here because I've been looking constantly online for for an answer to my question.
    I have a 2010 tacoma prerunner 2wd that is my daily driver. I drive 98% on road with some light off roading. I'm looking to change the look of my truck by leveling it out. as I don't have the money for a full blown suspension lift I know that I have two options, either purchase leveling spacers or extended travel shocks that will achieve the same thing. I want to keep the ride as smooth as possible, along with trying to keep from damaging the suspension as much as possible. I am wanting yall's feedback on what experience y'all have with these two options and which one might better meet my needs?
  2. Jun 13, 2020 at 2:54 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If you’re just gonna level. The front probably only needs to come up about 1” put a 1/2” spacer on top of the coil over and call it day. Won’t make a difference in ride quality. You’ll be fine.
  3. Jun 13, 2020 at 4:39 PM
    bordinco90
    bordinco90 Well-Known Member
    SW Louisiana
    2008 Desert Sand Mica Tacoma Prerunner DCSB
    18 inch Black rims with 265/65/18 AT tires. Bilstein 5100 shocks. Black Halo Headlights and Black LED taillights. Window Tint. Black Aftermarket Grille.
    I put a set of Bilstein 5100's on the front and set them to .85. It gives my truck a slight rake and a more aggressive stance.
    Naveronski likes this.
  4. Jun 13, 2020 at 5:54 PM
    thetacofort
    with the 5100 should I get a new spring or use the stock spring?
  5. Jun 13, 2020 at 6:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Use the stock springs. You should be fine.
    I wouldn’t do any more lift than you need, unless you are planning on doing the ECGS Bushing.
    I wouldn’t do any more than 1.5” with out the bushing.
    I’m stock, With no lift and I should do the bushing.
    If you do new springs, most go with OME, and set to 5100 to “0” lift.
    The spring do the lift in that setup.
  6. Jun 13, 2020 at 8:11 PM
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    Install 3rd gen suspension. They're cheap and it'll give you a 1in lift in the front and keep rear the same. If you also have 2+1 leaf and want to swap it out for a newer 3+1 leaf, that'll give your rear a 0.5in lift.
    taco_rhyno likes this.
  7. Jun 14, 2020 at 5:16 AM
    Icarus II
    Icarus II Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    OP said they have a Prerunner. Does the ECGS even apply?
  8. Jun 14, 2020 at 5:41 AM
    centurion
    centurion Well-Known Member
    Northern New Jersey
    2006 Tacoma TRD Sport,double cab, 4X4, auto, speedway blue
    Air-Raid air filter, de-badged,custom grill,hood and tailgate struts
    Good call! I don't think it does... but mines a 4x4
  9. Jun 14, 2020 at 10:46 AM
    TnShooter
    Deogee
    STOCK
    No, it doesn’t. Missed that.Sorry
  10. Jun 14, 2020 at 11:07 AM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    This is a good way forward, lots of take offs on Craigslist, gives 1 inch lift. Only buy a complete/assembled set as shops will charge you $60ish to reassemble with your existing springs/tophats.
  11. Jun 14, 2020 at 2:14 PM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    Nothing to be sorry for.
    TnShooter[QUOTED] likes this.
  12. Jun 14, 2020 at 3:37 PM
    Goosie0080
    Goosie0080 Well-Known Member
    North East
    07 Tacoma Access Cab 4x4 base
    Always go with the shocks.
