Leveling tacoma with tundra springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Indy, Aug 18, 2014.
  1. Aug 18, 2014 at 2:25 PM
    Indy
    Indy [OP] Master of all I survey.
    Howdy all, I've been reading on this but have been coming up with mixed info regarding the install.
    I have a 2k taco that started with more rake than I like, but have put a heavier bumper and winch on the front so it has become more pronounced. I don't want to lift the truck or go larger than the 31" tires it has on it, just level the front out. And do so without dropping another grand on a lift kit to get it done.
    So I'm thinking the 1st gen tundra's on the front will do so, and I've read of them being used for that purpose. But I keep coming across using either only the springs because the struts won't work. The springs themselves not fitting. The strut/spring assembly being bolted in with no mods whatsoever, and using the springs/struts from the tundra but having to swap the taco top plate over.
    Anyone know for sure which is actually correct?
    The truck has about 100k on the odometer so I'm guessing the shocks/struts are due for replacement anyway. I don't want to do the work to replace the struts alone knowing I'll just have better dampening on my over-raked truck.
  2. Aug 18, 2014 at 2:28 PM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    Use the struts and springs from the Tundra and use the top plates from a Taco or 4runner. It works very good. I rode that for maybe a year before I sold my Tacoma. I found the higher mileage you got on the Tundra, the better the springs felt on the Taco once transplanted. I got maybe 1-1.5" of lift in the front. No aftermarket bumper or anything though.
  3. Aug 19, 2014 at 10:56 AM
    Indy
    That's what I needed to know, thanks.
  4. Jan 11, 2015 at 2:47 PM
    danthemanx07
    danthemanx07 Well-Known Member
    Daniel
    New Bern, NC
    Did this idea ever follow through?? Thinking about doing this as well for a cheap, rake-cure solution.
  5. Jan 11, 2015 at 4:13 PM
    4thone04
    4thone04 Well-Known Member
    jcl
    west END of hwy2
    new at 155,000
    You can also get the 1999 4runner front springs. I got about the same lift and spring lb as the tundra. I got them from rock auto for 50.00 shipped.
  6. Mar 24, 2015 at 7:53 PM
    danthemanx07
    Daniel
    New Bern, NC
    How much lift did you get with those springs?
