Leveling to stop rubbing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by primer, Jan 15, 2011.
  1. Jan 15, 2011 at 5:42 PM
    primer
    primer [OP] Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    2006 TRD Off Road with 45K
    A few months ago I got new wheels and tires. Went with Revos 265/75/16. They were only available locally in a 10ply E rated tire. I'm convinced that the 10ply tire has a slightly larger diameter though I've not been able to find that documented for sure. I've been happy overall - but despite some trimming I still rub a bit. From what I've read most people report no rubbing with this tire size.
    I'm thinking of putting Bilstein 5100s on the front to raise it a bit. My suspension is stock front and back - never did the rear leaf TSB. I definitely don't want to raise the front above the back so I'm thinking of setting the 5100s at .85. I don't think I need much to stop the rubbing.
    This thread was helpful:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/27231-bilstein-settings.html
    But I can't tell for sure. I want to lift enough to stop the rubbing. I want a slight rake to level ride.
    Suggestions appreciated.
    TL
  2. Jan 16, 2011 at 8:09 PM
    primer
    T
    OK
    Bump...
  3. Jan 16, 2011 at 8:16 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Your idea sounds like it will work just fine for what you want. Wheels with 4.5" backspacing will help too if you dont have those already.
  4. Jan 16, 2011 at 8:37 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Measure you fender heights and see if you'll sit level if you add .85". You can also get the TSB or an AAL and set the bilsteins at 1.75 or 2.5.. or still at .85.
  5. Jan 17, 2011 at 4:00 PM
    primer
    T
    OK
    Thanks all.
    I have Ivan Stewarts - not sure what the backspacing is anymore.
    TL
  6. Jan 17, 2011 at 4:01 PM
    primer
    T
    OK
    Measure from floor to the bottom of the fender opening - is that correct?
    Thanks
    TL
  7. Jan 17, 2011 at 4:19 PM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    yeah, with the tape measure going next to the center wheel cap basically
  8. Jan 17, 2011 at 5:27 PM
    primer
    T
    OK
    Looks like the IS are 4.5".
  9. Jan 17, 2011 at 6:23 PM
    primer
    T
    OK
    Left Front, 34 3/4, Left Rear 36 3/4
    Right Front 35 1/4, Right Rear 37 1/4
    Looks like 1.75 might be fine. Shouldn't be nose high.
