Leveling truck with 5100's, will 295/55-20s fit?
Discussion in 'Wheels & Tires' started by Rock501, Aug 25, 2012.
Will they fit?
Poll closed Sep 24, 2012.
  1. Yes
    1 vote(s)
    5.3%
  2. No
    6 vote(s)
    31.6%
  3. Pie
    12 vote(s)
    63.2%
  1. Aug 25, 2012 at 6:53 PM
    Rock501
    Rock501 [OP] Well-Known Member
    Stafford, Texas
    07 PreRunner, TX edition with factory 20's
    Hey guys, this next weekend I plan on buying a set of Bilstein 5100's to put on the front of my truck to set at the #3 setting (1.75" of lift if im not mistaken) to level my truck.
    Im a little different in what kind of tires I can choose from because I have 20" wheels. This being said, its kind of hard to find insightful advice from people because most guys don't run 20" wheels. I would love to be able to fit a set of 295/50-20 Nitto Trail Grappler M/T tires on after I level my Tacoma. But if I cannot, I will just have to settle for something else.
    Its not a 4wd truck so this is just for looks. My question is, can I fit the tires on the truck with the modifications i plan on doing to get the look i want.
    Thanks guys
  2. Aug 25, 2012 at 6:59 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    What size tire you running now?
  3. Aug 25, 2012 at 7:16 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    They are 31.61x11.61 tires they should fit with front mud flaps removed and minor triming.
  4. Aug 25, 2012 at 7:20 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    What is the backspacing and width of the wheels? Going to be close.....
  5. Aug 25, 2012 at 7:22 PM
    Rock501
    Stafford, Texas
    265/50-20's
    They are street tires. Something the lady had on the truck before I bought it. Just a low profile street tire that's all. A 30 second glance and I could tell I could put a little bit bigger tire as is (something about another inch in diameter) but Id like to go with my plan.
  6. Aug 25, 2012 at 7:25 PM
    TexasTacoma37
    Just saw you have the factory 20s. I would definately test fit the tires.
  7. Aug 25, 2012 at 9:04 PM
    Rock501
    Stafford, Texas
    Specification..... Sidewall .... Radius ... Diameter .....Circumference...... Revs/Mile
    295/55-20....... 6.4in........ . 16.4in .... 32.8in .......103.0in .............. 615
    how close do you think it might be? I dont mind taking off my mud flaps.
  8. Aug 26, 2012 at 5:59 AM
    Large
    Large Red
    I ran 305/50/20 & rubbed a lot on 2.5" of lift and 5" back spacing.
  9. Aug 26, 2012 at 8:37 AM
    Rock501
    Stafford, Texas
    are you sure you got the tire size right? I didn't think they made a 305/50-20, I know they make a 305/55-20, and that tire is 33.2 inches so I can understand where you may have rubbing there.
  10. Aug 26, 2012 at 9:52 AM
    Large
    Large Red
    certain
  11. Aug 26, 2012 at 9:57 AM
    Large
    Large Red
    Just realized you were in stafford, If I had the tires still I'd let you put them on, flex & stuff but I only have the wheels now.
  12. Aug 26, 2012 at 10:42 AM
    Rock501
    Stafford, Texas
    oh you have the Terra Grapplers A/T!?
    I may wind up having to go with those, but Im trying to get the Trail Grapplers M/T to fit. The smallest they come in for a 20" wheel is 295/55.
    If i cant get that to fit ill wind up going with the Terra Grappler A/Ts like you have there.
    Hows the ride on those 20s?
    That would be fun :p
    Here is another member with 20" KMC Rockstars on 295/55R20 Nitto Trail Grapplers M/T
    hes got the look im going for but I dont know what he had to do to his truck to get them under there.
    ETA: found it, hes got a 3" toytec lift on with Light Racing UCAs
  13. Aug 26, 2012 at 1:13 PM
    Large
    Large Red
    Ride was good, no complaints, huge foot print & good in the sand.
  14. Aug 26, 2012 at 1:14 PM
    Large
    Large Red
    Plus those particular wheels only weighed 26 lbs for the set.
  15. Aug 26, 2012 at 2:14 PM
    Rock501
    Stafford, Texas
    I know, 26 lbs is pretty nice compared to most others. I really want this set up under my truck.
    ...just thinking here, since im getting these 5100's next week to lvl my truck.... What If i just set them to 2.5" to fit the tires on? Would that be tall enough? What would I have to do to the rear to make it lvl?
  16. Aug 26, 2012 at 5:46 PM
    Large
    Large Red
    Cheapest way would be blocks, best way would be a leaf pack, best bang for the buck would be an add-a-lead.
  17. Aug 26, 2012 at 7:41 PM
    Rock501
    Stafford, Texas
    i think ill do 5100's at 2.5" and a pair of 1.5" AALs in the rear.
    that should get a 295/55-20 under my truck with at the very most, minor trimming.
  18. Aug 26, 2012 at 9:02 PM
    Large
    Large Red
    You will still rub just not as much as 1.75, Do some plastic trimming & cab mount chop and you'll be good.
  19. Aug 28, 2012 at 3:57 PM
    Rock501
    Stafford, Texas
    you really think a cab mount chop would be all that necessary? i mean, they are only 11.6 inch wide. Ill give you yes they are almost 33" tall but Ive seen others run that big of tire on a 2.5" lift.
