Leveling with 5100s versus Eibachs with 5100s
Discussion in 'Suspension' started by spiceman, Dec 9, 2009.
  1. Dec 9, 2009 at 10:42 PM
    spiceman
    spiceman [OP] Well-Known Member
    Hawaii
    '07 4x4 DC OR, Desert Sand Mica
    Window Tint, Sockmonkey bed decals, Eibach 1.6" coils, 5100s front (set @ .85) / rear
    I have an '07 DC 4x4 OR and I was thinking of leveling the front to rear. Currently the rear is 2" higher. From the wheel center, rear 22.5" and front 20.5". What would be the advantages or disadvangtes of using Eibach coils with 5100s on all for corners with the fronts set at zero, or just four 5100s with the fronts set at .85 or 1.75? The rear is stock (no TSB). Would I be able to get the alignment in specs with OEM UCAs? And would I need a Diff drop kit? Thanks in advance.
  2. Dec 10, 2009 at 5:30 AM
    bucksnort06
    bucksnort06 Well-Known Member
    pete
    cape cod
    09 TRD
    4 leaf TSB, 5100's all four, eibach 1.6" coils, ARE cx cap, yakima racks, weathertech floor mats/rain guard/hood guard.
    I was just in the same situation as you as I wanted to level out my truck after TSB.. I went ahead and bought 5100s planning on setting them at 1.75.. I then decided that I would most likely get a better ride if I set these 5100s at 0" and leveled the truck with the eibach coils.. I have both at my house now just waiting to get installed.. I did alot of reading on this site amd some people say the 5100s at 1.75, or 2.5" can make ur front end alot stiffer.. Hopefully someone thats has done these will chime in..
  3. Dec 10, 2009 at 5:35 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    5100 with eibach's can only be set at 0.85" max as the spring adds 1.6" with the billy's set at 0. the higher u raise the front the more you are compressing your springs making the ride rougher. I have 5100 at 0.85" with eibach's and the ride is just wonderful, no stiffer than stock and could even but a bit smoother.
    you will have no issues with alignment as long as the front stays under 2.5-3inches. camber seems to be the real issue with alignment over 3"
  4. Dec 10, 2009 at 5:58 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    I have the Eibachs on my stock trd billys. They made the truck ride and handle a lot better but I only got about 1 inch of lift. Could be a limitation of using the stock shocks not sure. :confused:
  5. Dec 10, 2009 at 6:16 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Yeah that extra .85 from the 5100's would help alot...
  6. Dec 10, 2009 at 8:15 AM
    atmotocrosser
    atmotocrosser Well-Known Member
    Greg
    Conroe, TX
    I had the dealer install 5100s at all four corners when they did the TSB on the rear springs. I have the fronts set at 1.75 with no harsh riding issues or problems putting it within factory allignment specs using the stock UCAs. :cool:
  7. Dec 10, 2009 at 7:21 PM
    spiceman
    Hawaii
    Thanks!
    If I went with the Eibachs and Billys I would set the Billys at zero for 1.6" of lift with the Springs. If I went with just the Billys I would set them at .85 to keep from making the stock springs too harsh with all the pre-load. If I get 1.6" out of the Eibachs it would be close to level. I was wandering of the advantages and disadvantages between these two options.
  8. Dec 10, 2009 at 7:23 PM
    spiceman
    Hawaii
    Do you know why you only got 1" from the Eibachs? They claim 1.6", which would be a nice level with the current 2" of rake?
  9. Dec 11, 2009 at 6:00 AM
    Burns
    17 DCSB Off-Road
    No idea man I was kinda puzzled about this myself. :confused:I am putting in the 1/4 inch top spacer this weekend (to correct the taco lean) and I will take new measurements.
  10. Dec 11, 2009 at 9:24 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I did eibach springs, 5100's set at 0", and the Toytec top plate spacers for an extra 3/4" of lift. It lifted the front right at 2.5".
    It lifts the truck essentially the same as eibachs and 5100's set at 0.85" but I didn't want to preload the springs. I wanted the springs as flexy as possible for trail wheeling.
  11. Oct 29, 2012 at 7:17 PM
    SMSmithy
    SMSmithy Liberty Or Death
    Sam
    New Hampshire
    2016 TRD Off Road
    Black Painted Grill
    I have 5100 all around and have the fronts set at 1.75. stock springs . The ride is softer in my opinion... and it looks bad ass too!
  12. Oct 29, 2012 at 7:28 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    IMO the eibachs were pretty firm, look at OME 884 maybe?
