Leveling with bilstein 5100 and OME springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cxyooj96, Oct 13, 2019.
  1. Oct 13, 2019 at 7:38 PM
    Cxyooj96
    Cxyooj96 [OP] Member
    Alex
    2001 green tacoma extra cab
    Leveling kit
    Hey guys need some help here, I just completed my leveling lift yesterday putting 5100 shocks with OME coils. I was told to let the clip set at the lowest setting on the shock and let the coil do the lift but only gave me a 2" lift I was looking more towards 2.5-3" lift. The back is with a 2" aal. Did I do it correctly or can anyone give me suggestions or tip?
  2. Oct 13, 2019 at 9:53 PM
    Narty
    Narty Well-Known Member
    Orange County
    1998 Black Tacoma ext cab 4x4 A/T
    OME nitrochargers, Dakars+AAL, JBA UCA 285/75/16 Nitto Ridge Grapplers on TRD baja "beadlocks" Flippac
    which ome coil? also isn't lift kind of relative depending on saggy your suspension was beforehand? I'll let someone else speak to that. I didn't measure beforehand, but after bilstein 5100 and the ome 881, i'm pretty sure i got around 2 inches of lift as well.
    Cxyooj96[OP] likes this.
  3. Oct 13, 2019 at 9:56 PM
    Cxyooj96
    Alex
    Leveling kit
    I have the 881 ome coils on with the 5100 bilstein. I just not sure if I did it correctly or not.
  4. Oct 13, 2019 at 9:57 PM
    Cxyooj96
    Alex
    Leveling kit
    I have the 881 ome coils wasnt sure if I did it correctly, if you can help me that will be great thanks
  5. Oct 14, 2019 at 1:22 AM
    kikomonster671
    kikomonster671 Active Member
    Frank
    GUAM
    2001 4wd tacoma single cab
    In progress
    I had my bilstein set at .67 with ome 881 coils and gave me the same height as the spacer lift I removed
    Mines a single cab also
