Leveling
Discussion in 'Suspension' started by mkerros, Nov 7, 2008.
  1. Nov 7, 2008 at 9:29 PM
    mkerros
    mkerros [OP] Well-Known Member
    jacksonville florida
    06 d/cab long bed
    Would you guys recomend leveling with hockey pucks untill i can afford a full leveling kit. Thanks for the help and any advice in how to do it would be great.
  2. Nov 7, 2008 at 10:23 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Would I recommend it.......no.....hell no!! Do I encourage it? Yeeeesss!!
    And please.....PLEASE.......post some pics.
    :rofl::rofl:
  3. Nov 7, 2008 at 10:30 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    hahhah
  4. Nov 7, 2008 at 10:31 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    seriously though, thats some money invested in your truck... don't go cheap on parts...
  5. Nov 7, 2008 at 11:05 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I'd say save your money and do it right the first time.
  6. Nov 7, 2008 at 11:10 PM
    mkerros
    06 d/cab long bed
    Ok thanks for the info. Well as soon as I get my cammera working ill post some pics.
  7. Nov 8, 2008 at 6:38 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    No. hah
  8. Nov 8, 2008 at 7:17 AM
    muliefever
    muliefever Muliefever
    Tillamook, Oregon
    14' DCSB TRD
    5100's, 887', CB, 265's, FM Deltaflow
    in the old days peeps used to use hockey pucks as " Body Lifts" Not suspension lifts... Do not even try it!
  9. Nov 8, 2008 at 8:07 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    Hockey Puck Lift
    The basic is simple, lift the body with hockey puck. The use of hockey puck is feared by many, they say the puck are fragile and can break in cold weather. But in my opinion, hockey puck are made for playing on the ice, so the are made to be tough when frozen.
    I did a hockey puck lift on my first samurai, I used the truck for 4 months in the winter and nothing happened to the hockey puck. A friend of mine used hockey puck for lifting his Blazer two years ago, and the hockey puck are still there doing their job.
    The only failure I had with hockey puck was not caused by the puck themselves. My exhaust pipe brooke loose, and the end of my exhaust pipe went right in front of the puck under the tail gate on the driver side. After 2 weeks of heavy heat the puck melted on the outside, but the middle of the puck stayed intact, supporting the body.
    The best height is 2 inch. 3inch can be reach, but the steering wheel will need to be adjusted, the fuel filler hose will need to be extended, your shifter hole in the body will need to be opened bigger and your transfer case lever will be very low. So 2inch of body lift is a good lift, and all those PITA won't have to be done.
    The best way to hockey puck lifting is:
    1- Go buy the number of puck you need (20 for me), some length of 4inch PVC pipe, some flexible epoxy (plumber epoxy) and longer screw for you body bolts.
    2- Sand one side and the exterior of each puck, for better adhesion.
    3- Cut the 4inch pipe on section of the height of 2 hockey puck (or 3 pucks if you want a 3inch lift..)
    4- Put epoxy around one puck, slide it in the pipe you just cut, put epoxy in the pipe wall and on puck inside the pipe and put the second puck in the pipe. This way both puck will be protected inside the pipe, and the pipe give en extra strength to the pucks.
    5- When the epoxy dried, drill a hole just smaller then the size of the body bolts.
    6- Put the puck under your body and secure you body with the longer bolts you bought.
    Here is an example of puking, the puck if well done. But the body is rotten to death.
    source
  10. Nov 8, 2008 at 10:34 PM
    mkerros
    06 d/cab long bed
    well ive decided agains doing this and am going to wait tell i can afford to do it right. Just trying to figure out now what size tires to go with. Im really not looking to lift it any just want to level it out. One of the guys I work with leveled his truck out and it looks really nice. So if any of you can give me any help on tire sizes would be greatly appreciated.
