levelling a Toytec ULK
Discussion in 'Suspension' started by Thesilversurfer, Jun 28, 2011.
  1. Jun 28, 2011 at 7:45 PM
    Thesilversurfer
    Thesilversurfer [OP] Member
    Rich
    Calgary, Alberta, Canada
    2017 TRD Long Box
    Toytec ultimate lift kit SPA UCA's Pro Comp Rims Dakar rear springs Centre bearing drop Bilstein 5100's BF Goodrich TA's Leer topper TRD Panel filter
    HI
    Today I had a Toyota dealer fit a complete Toytec Ultimate Lift kit and UCA's to by 2011 Tacoma DCLB TRD.
    All was great until i drove it. Under braking the truckl is dipping on the front passenger side.
    I looked underneath and found that the dealer has compensated for the lean by adjusting the driver's side coilover quite abit. The passenger side has 6 threads showing on the coil over and driver's side has 11-12! Therefore the drivers side spring is under alot of compression all the time and is not compressing under braking.
    Hows the best way to deal with this? I will return her to the dealer's to fix but i want a solution to argue with if they bullshit me.
    Im thinking, adjust the drivers side back to the same as the passnger side and then check the lean, measure it and get the toytec spacer kit to level her out.
    What do you guys think?
    Richie
  2. Jun 28, 2011 at 7:46 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get the 1/4 lean spacer for the driver's side
  3. Jun 28, 2011 at 7:49 PM
    Thesilversurfer
    Rich
    2017 TRD Long Box
    get the spacer and then adjust the coilovers to the same amount?
  4. Jun 28, 2011 at 7:58 PM
    OZ-T
    Peter North
    British Columbia
    Yes
  5. Jun 28, 2011 at 8:01 PM
    Thesilversurfer
    Rich
    2017 TRD Long Box
    Thank you mate. Thats great. I cant believe it been left like that but thats life I suppose.
    Thanks again
  6. Jun 28, 2011 at 8:03 PM
    OZ-T
    Peter North
    British Columbia
    Did you have the spacer and they just didn't install it ?
  7. Jun 28, 2011 at 8:46 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    You don't need a spacer, it just needs to be adjusted with the spring collars. They should fix it since they installed it. However, would be nice for you to know what to do in the future and when it settles. It's real easy man!
  8. Jun 28, 2011 at 8:51 PM
    OZ-T
    Peter North
    British Columbia
    Isn't that precisely the issue he is complaining about ?
  9. Jun 28, 2011 at 8:54 PM
    OZ-T
    Peter North
    British Columbia
    That's what this is for
  10. Jun 28, 2011 at 9:50 PM
    OZ-T
    Peter North
    British Columbia
    Oh , and :canada:
  11. Jun 29, 2011 at 8:49 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    The ultimate kit is an adjustable coilover and can be adjusted for height with the spanner wrench. No need to add a spacer to it. That would be for springs that are not adjustable.....eibach, ome etc.
  12. Jun 29, 2011 at 9:08 AM
    Thesilversurfer
    Rich
    2017 TRD Long Box
    Its just the adjustment so far has made the suspension on the drivers side so firm it's not flexing under braking. I spoke to Toytec and they say spacers cannot be used on coilovers.
    Confusing
  13. Jun 29, 2011 at 10:06 AM
    OZ-T
    Peter North
    British Columbia
    I must be incorrect then , I always thought that the 1/4 spacer was used with the Toytec set-up on the drivers side as well .
    My apologies OP
  14. Jun 29, 2011 at 10:10 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How much lift are you running? Cranking up the driver's side to make up for the lean shouldn't make that much of a difference. The dealership may have just been careless with where they set the collars. I'd take it back to them and ask why they set it the way they did and maybe they can back it off some on the driver's side.
    I'm not sure how much distance 6 or 12 threads is but there should only be about 1/8" - 1/4" difference in the threads side to side.
  15. Jun 29, 2011 at 11:14 AM
    Thesilversurfer
    Rich
    2017 TRD Long Box
    I thought the same. Make no apologies.
    Here's a question. When setting the coil over up for the lean, how much fuel should be in the truck? I had three quarters of a tank in the truck when then set up the suspension.
  16. Jun 29, 2011 at 11:58 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Should be sitting around 38-38.5" from ground to fender for a typical 3" lift. They will be firmer and prob won't compress that much from braking. As long as the measurements are close that height both sides. I'm sitting 38.5" but have 33" MT's.
  17. Jun 29, 2011 at 12:41 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    i just cranked mine until it looked level.
