Levelling kits?
Discussion in 'Suspension' started by jillryan, Jun 27, 2011.
  1. Jun 27, 2011 at 7:07 AM
    jillryan
    jillryan [OP] Member
    PEI Canada
    Toyota Tacoma 4x4 TRD
    2.5" leveling kit
    I'm wanting to lift my truck about 2" wondering what you guys recommend? I don't want to put a lift kit on it just thinking on putting a levelling kit on it. Wondering how much and what kind to get? Thanks
  2. Jun 27, 2011 at 7:28 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    If you want to just lift the front end, the cheapest route is spacers. A better method is Bilstein 5100 adjustable struts, even better is aftermarket coils. Depends on your price range and how well you want it to ride when you're done. Welcome to TW by the way!
  3. Jun 27, 2011 at 6:52 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Go for the Bilstein 5100's. That's what I did. They're set at .85". This way you also have the option of adding an add-a-leaf to the back and adjusting the Bilsteins up higher if you want a little lift (also what I'm about to do).
  4. Jun 28, 2011 at 4:25 AM
    jillryan
    PEI Canada
    2.5" leveling kit
    Thanks! Are they hard to install? How much are they?
  5. Jun 28, 2011 at 5:59 AM
    Pugga
    Massachusetts
    The install isn't terrible but good tools and an extra set of hands wouldn't be a bad idea. Air tools are great if you have access to them. Check out the link below, that's an Old Man Emu install and his struts were pre-assembled. If you bought new coils, you might be able to get them preassembled with the strut. If not, you'll need a spring compressor to re-use your stock coil.
    http://www.tacomaworld.com/forum/su...talls-full-ome-kit-rear-brake-lines-pics.html
    Check these guys out, they sell the adjustable 5100 strut.
    http://www.tacomaworld.com/forum/downsouth-motorsports/
    I'm running the 5100 strut, set at the 0 (stock height) setting with a set of Eibach coils. The Eibach coils provide 1.6" of lift and are a little stiffer than stock coils. Toytec sells the Eibach coils as well as the 5100's if you want to look into them also.
  6. Jun 28, 2011 at 7:02 AM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    So, I am assuming you are stock in back (no AAL, and stock suspension)...are you completely level at .85", or still a little high in the rear?
    Thanks!
  7. Jun 28, 2011 at 2:57 PM
    90YotaPU
    Union County, NJ
    I'm stock in the back and am about 1/4" to 3/8" higher in the rear still. I understand the next setting would put me nose high so I stuck with .85. I'm very close to putting in the AAL though. Was happy with level for a while. Now I want more.lol That's why I think it's great to do it this way, it's kind of progressive so you don't really waste anything but don't spend more than you need to. If you're happy at level, than you have minimal outlay.
  8. Jun 29, 2011 at 9:02 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Cool...I was hoping it was a wee bit high in the rear for loads. I will do the same, then, but most likely wait until my shocks are due for replacement.
    Thanks for the reply!
  9. Jun 29, 2011 at 7:13 PM
    pollock21
    pollock21 Well-Known Member
    Brian
    Cornelius, NC
    '11 Tacoma DC, TRD Sport 4x4
    If you decide to do spacers, pm me. I bought a set of above coil spacers but dsm got some 5100's in stock so I went that route as well.
    There's a lot of info on here, pros and cons of spacers vs shocks. If you're not gonna do a lot of hardcore offroading, and you really just want to level the truck, then just go with spacers. Cheaper and easier. I'll give you a good deal on the spacers if you decide to go that route.
  10. Jun 29, 2011 at 7:26 PM
    neoflex
    neoflex Well-Known Member
    I'm guessing you don't have the TSB springs correct? Just wondering because I think most guys with 5100s up front and the TSB are going to 1.25 to be level.
  11. Jun 30, 2011 at 8:43 AM
    jillryan
    PEI Canada
    2.5" leveling kit
    I think I'm probably going to go with 5100's for the front and back.
