Levelling Kits
Discussion in 'Suspension' started by sbrates, Apr 12, 2021.
  1. Apr 12, 2021 at 1:07 PM
    sbrates
    sbrates [OP] New Member
    Good afternoon,
    I'm pretty new to the world of trucks, but I was hoping someone would be my guide to levelling my 2016 Tacoma TRD. I was debating between a lift kit and a level, but I think that a level and beefier tires would be the better route for me.
    What type of level kit would you recommend? Tires? I really have limited knowledge on the topic, so I'd appreciate helpful answers and opinions. Cheers!
  2. Apr 12, 2021 at 1:09 PM
    scottstrong89
    scottstrong89 AhsokaTaco
    Carlsbad | CA
    2021 Tacoma SR5 2.7L DCSB Black (Sold 6-2-21)
    Bilstien 5100s- front 2.5inches Bilstien 5011s - rear extended HeadStrong OffRoad progressive AAL Manga flow muffler Aftermarket Powder-Coated Black Tip BFG KO2s- 265/70/17 Method Wheels Double Standard 17” Prinsu Cab Rack w/ Plano Rife Cases Yakima Awning Tacoma_Twins Paracord Handles TRD Pro Grille w/ Raptor Lights Laminx Fog Light Vinyl Yellow Me-So Customs Flip Fob Me-So Customs Gas Hole AJT Designs Emblem Overlay Black Me-So Customs Method Wheel Caps Screen ProTech 3 Piece Protector Kit Bumper Shells Bumper Caps Black tttacodan Bed Stiffeners TRD Pro Skid Plate TVD Vynil Decals Chrome Delete Hondo Garage Mounts w/ Ram Mounts RCI Adjustable 12” Bed Rack RotoPax Lox Mounts RotoPax WaterPax & Storage Pack Yakima Skyrise RTT WaterPort Shower Baja Born OffRoad Rock Sliders XBull Recovery Boards Al Off-road Trailgate Panel ataco4x4 Grille Emblem Desert Armor Ultra4 Ditch Light Pods Cali Raised LED 40” Light Bar Cali Raised OEM Style Switches
    You might want to look into doing Bilstien 5100s in front instead of a spacer to level. Worth the extra money.
    Superdave1.0 likes this.
  3. Apr 12, 2021 at 1:25 PM
    sbrates
    Hi Scott, thank you for your quick response. Would that mean that I would still need to put a spacer in the back? My end goal is to be able to take it off-roading with confidence but I'm a bit overwhelmed with all of the information out there.
  4. Apr 12, 2021 at 1:32 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Leveling is the exact same as lifting except it's specifically the amount of lift needed to "level" the front and rear. Some leveling kits only lift the front to bring it level with the rear. Others lift the front and rear but by amounts which level the ride height. My truck had a 3" front / 1" rear "leveling" kit and IMO it was actually higher in the front. You do not need to lift the rear in order to level the truck.
    You can lift and/or level using spacers/blocks or by replacing the shocks/springs. Typically, we all agree that spacers/blocks are not as good, but they have their place for some people or some situations.
    Contrary to popular believe, lifting doesn't really provide extra clearance for bigger tires. There are other, more important, factors at play than ride height.
    Since you're new, I'd get out there and start using the truck, then decide what needs to be improved. Your stock truck will be very capable off-road and you probably won't run into any issues unless you find yourself needing more ground clearance for larger obstacles.
    sbrates[OP] and LC7 like this.
  5. Apr 12, 2021 at 1:40 PM
    scottstrong89
    Carlsbad | CA
    If you’re wanting to just level, no you can leave the rear stock. You would just be getting new struts up front to pair with your stock coils and set them to raise the front end a tad to match the rear.
    sbrates[OP] likes this.
  6. Apr 12, 2021 at 2:20 PM
    sbrates
    Hi Colin, thank you for your response, super helpful answer! I've taken the truck up a few FSRs and I noticed that I was scraping the bottom of the truck on several cross-ditches and larger rocks/ obstacles which is why I've been playing around with the idea of lifting my truck :)
  7. Apr 12, 2021 at 2:27 PM
    clenkeit
    Colin
    Lakewood, CA
    Looks like you'll definitely want some lift then. Depending on where you're scraping that'll help figure out how much lift and whether you need front and/or rear lift to accomplish the clearance you need.
    Bigger tires are a no brainer as well. 265-75-16 fits easily, generally referred to as the largest size you can go without any trimming or cutting. But, you can get some other, taller tires to fit depending on the width of the tire and offset of the wheel. I opted for that tire size but am now considering going bigger. Check out the "skinny" tire threads in the wheel/tire section. Many people are getting a 32-33" tire to fit without any rubbing issues.
    You may also want to consider skid plates if the scraping is bad enough.
    sbrates[QUOTED][OP] likes this.
  8. Apr 13, 2021 at 9:20 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    OP Look into Bilstein 5100’s or eibach great budget lifts for weekend warrior camping and everyday driver. IMO stay with 2” - 2.5”. You may or may not need UCA for alignment and caster adjustment.
