Levelling the rear
Discussion in 'Suspension' started by RyanK1, Feb 4, 2012.
  1. Feb 4, 2012 at 7:30 PM
    RyanK1
    RyanK1 [OP] Well-Known Member
    Penticton, British Columbia
    2006 Tacoma TRD Sport
    Bilstein 5100's @ 2.5, TSB rear with block spacer, Procomp ES9000's, CBI Moab 2.0 front bumper, swaybar removed, DIY HiLift mount, Rear diff breather mod, ABS Kill Switch, Flowmaster 40 series muffler, Superwinch 8500
    Hey everyone,
    Front: Billies @ 2.5, stock coils
    Rear: 4 leaf pack and 2 inch revtek block, ranchos I believe, cant tell too rusted. White with red boot.
    I recently purchased a canopy, approx weight 200-250 lbs and noticed that I am not sitting level, bro lean going on. I want to remove the block and add a 2" aal, but am worried that I will still be in the same position. Any suggestions? New shocks, new leaf pack?
  2. Feb 5, 2012 at 11:50 AM
    RyanK1
    Bump, really nobody?
  3. Feb 5, 2012 at 11:55 AM
    Appljaxx
    Appljaxx He said "Member," ahuh huh
    Jeremy
    Albuquerque, NM
    '12 4x4 DCSB
    OME Nitrocharger front, 5/8 front spacer, 885s, OME N182s rear, dakar leafs, Diff Drop, TRD exhaust, Blackout emblems, 20% tint, Hi-Jack bed mounted, Dwreck sliders on order :)
    TRD window washer fluid reservoir will help balance out the load.
  4. Feb 5, 2012 at 11:57 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    a 2" AAL from toytec should liven your rear up! Don't forget the longer u-bolts
  5. Feb 5, 2012 at 11:59 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    AALs are a far better lift solution than blocks, but trading 2" blocks for 2" AALs won't change your height by any appreciable amount. Shocks won't provide any kind of rear lift either.
    New leafs are probably your best bet. I'm sure there are a number of options available, but OME Dakars should do the trick.
  6. Feb 5, 2012 at 12:06 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Yes you need those.
    With shell a full 3" lift front & back on mine with 885s up front & Dakars in back. Rides great on & off road.
  7. Feb 5, 2012 at 12:14 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2^^
    New leaf packs are the way to roll but if your only at 2.5" up front a 2" AAL "should put you level with the topper....you'll probably have a little rear rake without the topper on.
  8. Feb 5, 2012 at 6:34 PM
    RyanK1
    Thanks everyone for the responses. I was hoping that an aal would be enough to level me out, but I may have to look in to some dakars. Wife wont be too happy about how much Im going to spend, but it needs to be done. Once again thanks for the info you guys.
  9. Feb 5, 2012 at 9:05 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Ya dude maybe just try that 2" AAL 1st. It should make you level since your at 2.5 up front :cool:
    worse case scenario, pull the 2" AAL, sell it to a guy on here and buy your Dakars. But i'm about positive that the 2" AAL will work :cool:
  10. Feb 6, 2012 at 4:29 PM
    RyanK1
    Thanks Colt, my wife will like the sound of that, I'll keep everyone posted.
