LFaub's 4x4 conversion/camper build
Discussion in '1st Gen. Builds (1995-2004)' started by Lfaub03, Mar 4, 2016.
  1. Oct 31, 2022 at 8:21 AM
    #321
    Lfaub03
    Lfaub03 [OP] 4wd wannabe
    Logan
    Flagstaff, AZ
    2003 Prerunner TRD
    4wd conversion
    Wrapped up the rear bumper this weekend. Huge thanks to @snowsk8air2 for helping with the welding and letting me use his garage.
    Bumper is a weld-together kit from Coastal Offroad, and uses a much beefier 4xInnovations swingout kit.
    Dalandser, Slashaar, Phessor and 3 others like this.
  2. Oct 31, 2022 at 8:27 AM
    #322
    Lfaub03
    Logan
    Flagstaff, AZ
    2003 Prerunner TRD
    4wd conversion
    For anyone who wants to do this setup: the coastal bumper won’t allow the 4x swingout unless you find a way to make the tailgate clear the latch pin. I opted to notch the bumper about 2 inches to allow that pin to clear. Hope this can be helpful for anyone else’s future projects!
    We ended up welding the latch pin to this new tab, allowing the tailgate to drop open all the way
    Slashaar, Phessor and snowsk8air2 like this.
  3. Nov 2, 2022 at 6:54 AM
    #323
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Nice work! Looks like it came out clean!
    Wish mine came out this nice. I need to work on my welding skills some more.
    Lfaub03[QUOTED][OP] likes this.
  4. Sep 29, 2023 at 4:52 PM
    #324
    Lfaub03
    Logan
    Flagstaff, AZ
    2003 Prerunner TRD
    4wd conversion
    Apparently I haven't posted on my own thread in almost a year. Whoops.
    Here's last year in review:
    Did plenty of trail exploring to check out all the lakes we suddenly had after last year's winter
    My girlfriend moved in and we did a lot of trail runs around the San Fransisco Peaks
    Went to @snowsk8air2's Labor Day run which was a blast
    and while I was there, I tried camping in the rain, which required a little help from an EZ-UP, but it kept me dry! Slept through a thunderstorm that dumped on Northern Arizona most of the weekend
    I'm very happy with my current setup though. Tempted to do a bed box to get me above the wheel wells, but beyond that, I'm very happy with my camping setup. The stability and wind protection beats a rooftop tent any day, if you ask me!
    Hopefully I'll remember to post more. If not - see y'all in a year!
    Bandido, Slashaar and Phessor like this.
  5. Sep 29, 2023 at 6:24 PM
    #325
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    They’re pricey and you can probably build something of the sort way cheaper. But the decked storage systems are pretty nice. That would put you sleeping above the wheel well and have some nice storage still.
  6. Nov 20, 2023 at 6:23 AM
    #326
    Gen1OldSchool
    Gen1OldSchool Member
    2003 Tacoma Prerunner 2x4 Xtend Cab
    Hey @lafub03
    If you ever get a chance, I would love to see how you routed the wiring for your ditch lights, and the antenna cable off to the back antenna. Also, how you routed power up to the lights on top of the camper shell. Thanks!
    PS: this write up was HUGELY helpful to me.
  7. Dec 10, 2023 at 8:50 AM
    #327
    Lfaub03
    Logan
    Flagstaff, AZ
    2003 Prerunner TRD
    4wd conversion
    Glad to hear my write-up came in handy!
    I routed my ditch lights up and around my hood hinges. The clearance looks a lot tighter than it is, and I've never seen any signs of the wires getting pinched. I wired the two lights parallel with each other, and routed my passenger side light through the cowl at the back of the hood.
    as for the rack lights and radio antenna, there's a pass-through in the storage compartment in the back of the cab on your driver's side - should have your emergency bottle jack in there. That pass-through goes straight to the bed, where I've fished my wires around the bedliner and to the rearmost driver's-side corner of the truck. From there I put my antenna cable to a homemade bracket on the back of the truck, and my lights are wired through a hole I drilled in the top of the camper. I've got those lights on a plug so I can disconnect them easily if I ever need to take the camper off.
    Slashaar likes this.
  8. Mar 13, 2024 at 9:52 PM
    #328
    Memeplayer1
    Memeplayer1 Lifted beetle
    Omar
    Sacramento, CA
    2003 Black PreRunner, AT, 3.4l
    Flowmaster muffler, 1.5 inch lift kit, SPC UCAs, Magnecor 7mm Plug Wires, NPBoosted Coil Packs, 4.56 ratio change
    How easy was it swapping the electronic valve body into the A340F tranny? Did you run into any issues at all? and were you able to reuse your original wiring harness? I'm currently in the same boat. I have a 4X4 tranny with a kick down for my '03. Thanks for the help.
  9. Mar 31, 2024 at 11:24 AM
    #329
    Lfaub03
    Logan
    Flagstaff, AZ
    2003 Prerunner TRD
    4wd conversion
    Wasn't too bad so long as you don't mind smelling like ATF for a couple days lmao. I really didn't run into anything that would give cause for alarm, main thing was just that the bolt lengths didn't match my Haynes Manual, but the transmissions at least matched each other so I was still able to write down where each bolt came from. With this kind of work it pays to mind the details, so just be sure to take your time and keep yourself organized.
    Regarding your question on the wiring harness, you'll have to swap that too, but only the small harness for the throttle valve system. Toyota really did just replace the mechanical cable with an electrical system, and they did it as cheaply as possible by changing as little as necessary, which works in our favor! Swapping the harness is as straightforward as pulling the grommets out and feeding the wires in through the exact same hole that you'll pull the throttle valve cable out of.
    Looks like you found my write-up thread, which I'm glad to see! It's been a few years since I've done it, but if you have any other questions or want to know any details let me know and I'll answer what I can!
  10. May 19, 2024 at 4:37 PM
    #330
    John-Doe
    John-Doe Member
    I wanted to check in to confirm that everything is working properly.
    I am starting to compile parts for my own 4x swap and like you I have an 03. I would rather swap the valve body & Torque converter then the other option of swapping the output shafts.
    Thank you for documenting your efforts.
