lg cell phone low volume on auxilary
Discussion in '2nd Gen. Tacomas (2005-2015)' started by naf116, Nov 29, 2011.
  1. Nov 29, 2011 at 5:25 PM
    naf116
    naf116 [OP] New Member
    atlantic beach, fl
    2009 tacoma tacoma prerunner
    I have low volume when play Sirius radio from my LG phone (virgin mobile) plugged into my aux imput. It's so low, there is no base. It's pretty bad. Yes, I do have my stereo volume turned all the way up, and I have my cell phone media and ringtone volume turned all the way up. I used my fiance's iphone and it's better, still lower than it should be though however I'd be happy with that.
    Is it my phone possibly? It's a virgin mobile so not super high end.
    Maybe it could be the aux cable, would it help to get a better one. Mine has silver connectors. If so, any suggestions? Thanks,
    Nick
  2. Nov 29, 2011 at 5:37 PM
    Large
    Large Red
    When I use xm, it's normal, radio is normal, my music on my iPhone from my library is normal but when I use pandora or xm mobile the quality is really terrible and the volume is only half at max, if that makes sense. So it's probably the app.
  3. Nov 29, 2011 at 6:57 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    The radio doesn't amplify the auxiliary input enough. It's a toyota thing. Doesn't matter what I plug into it; whatever it is needs the volume of the device at maximum, and the volume of the radio at 40+. FM/Radio is good at volume level 15 or so.
    Definitely not just a Taco thing either. Same in the Corolla, same in the Tundra.
  4. Nov 29, 2011 at 9:02 PM
    Goober
    Goober Earthlings are fun to watch!
    Utah - Why just have only one?
    '11 TRD Off-Planet AccessCab
  5. Nov 30, 2011 at 1:57 AM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    The mobile app for Sirius is weak it has this issue on more radios than just Toyota .
  6. Nov 30, 2011 at 5:12 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    anybody use a GPS puck and if so can you recommend one for the iphone/ipad?
  7. Nov 30, 2011 at 5:21 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    Super Bro lift!
    yes I agree.
  8. Nov 30, 2011 at 6:16 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Using the Aux input is not the best method sound quality wise. Unfortunately the manufacturers stuck with it a little too long before switching to a USB port.
  9. Nov 30, 2011 at 6:40 AM
    ZZT
    ZZT Member
    Almost all radios have the same problem. Quite a few new head units have a separate volume adjust for the AUX input.
    Here is what Bose had to say about the topic on their FaceBook page about a year ago.
    "Thanks for your question. What are experiencing is normal operation. Because the aux connection on the back is typically used with third party products, we can never be absolutely certain of the strength of the incoming signal. To ensure high sound quality, we "pad" the incoming signal. This just means that we lower the volume of the incoming audio to make sure it doesn't overload the input. Without this pad, products that have a higher than expected audio output may cause audio distortion. As a result, you may have to compensate by turning up the volume a little higher for sources connected through the aux jack."
  10. Nov 30, 2011 at 7:37 AM
    Goober
    Toyota over did the "padding", the Honda Element I had would about blow the doors off while using the aux input and that was a stock system.
  11. Nov 30, 2011 at 8:12 AM
    upthemaiden
    upthemaiden Well-Known Member
    Josh
    Pittsburgh PA
    06 Access cab SR5
    Just bought it!
    Do people have the same issues with the aftermark aux inputs? I ordered a Grom adaptor but haven't installed it yet. Hopefully it works a little better.
  12. Nov 30, 2011 at 7:09 PM
    Goober
