licence plate lights
Discussion in 'Lighting' started by bobtackett, Feb 17, 2015.
  1. Feb 17, 2015 at 8:20 PM
    bobtackett
    bobtackett [OP] Well-Known Member
    chicago heights,illinois
    4x4 trd offroad package
    3inch suspension,side steps,westin brush guard,carbonfiber hood w/scoop
    i have an 07 tacoma that just recently had one of my 2 plate lights burn out.ya think that would be simple.8pm,dark and 3 towns away from my safe zone.i work for the water dept and know all the cops in my town .anyway i get a phillips from the autozone dude and pull the bad bulb out.thats when my other plate light went out AND my running lights. I have brake lights, turn signals but no running lighs,i hate my life.are the plate lights and the running lights connected somehow.i checked the fuses as best i could.there is nothing that i saw that refers to running lights or licence plate light.any help would be greatly appreciated.i have a really good recall story to tell when i am done with this.thanx
  2. Feb 17, 2015 at 10:00 PM
    theblindchicken
    theblindchicken Well-Known Member
    Christian
    Long Beach
    '74 K10
    HID's, LED Dash swap, LED reverse lights, 15"x10" 5 slot mags, sliding rear window, 20gal aux. DS fuel tank,
    You blew a fuse. Check the one for the running lights. It may not appear to be blown until you pull it and check.
  3. Feb 18, 2015 at 4:42 AM
    bobtackett
    i couldnt find the fuse that said "running lights" on the lid of the fuse box.
  4. Feb 18, 2015 at 4:43 AM
    bobtackett
    thanx for you reply by the way
  5. Feb 18, 2015 at 4:51 AM
    Reeeno403
    Reeeno403 hammerdownson
    Calgary
    06 Tacoma
    Not a Stocko Taco.
    Are the sockets clean and in good shape?
  6. Feb 18, 2015 at 5:05 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    It sounds like you might have a short. When you pulled out the license plate light socket and the others died, there might have been a one-time short because of the way it was handled, or there is something loose that might cause it to short out again. Other than finding and replacing the fuse, I would check for a short at or close to the socket also.
  7. Feb 18, 2015 at 6:10 AM
    bobtackett
    i did get a little spark,if it had been daylight idont think i would have noticed it,when i pulled the dead bulb out.I has hoping it wasnt an issue.Apparently it must have been
  8. Feb 18, 2015 at 12:24 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    Have you gone offroading in rough areas? have you been rear-ended?
  9. Mar 24, 2015 at 10:27 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Old thread, but this happened to me too; left the lights on to check the new bulb worked ok, pulled ou the socket fm the bumper and pop out they went; turns out the harness is real short and when getting the socket in position to pull the bulb, the harness extends from the loom and scrapes the bumper metal just enough to penetrate insulation.
    Fuse 3 behind the dash board for a '12 prerunner; use spare from the underhood fuse panel cover. 10 amps.
