License Plate Light DIR for 5th Gen 4Runner?
Discussion in 'FBC Harness Solutions' started by wahoobie, Oct 21, 2024.
  1. Oct 21, 2024 at 12:47 PM
    wahoobie
    wahoobie [OP] TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    I had your setup on my 2016 Tacoma and it was perfect, do you have one for the 4Runner? If not can I help you get one going with any test truck need?
    Thanks!
  2. Oct 21, 2024 at 1:09 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    This has come up a little bit buuuuut, the "trouble" is with the fact that taillights are inside on the T4R so the Taco/Tundra design would thus have trouble exiting.
    A "universal DIR" might be cool though using a T off the 7 pin and I have some spare 7 pin T's w reverse from vled LPX development if you can locate and identify license plate intercepts and/or the bulb adapter connector? We also want to know where to mount the relay and the requisite lengths of the two arms.
    wahoobie[QUOTED][OP] likes this.
  3. Oct 21, 2024 at 1:29 PM
    wahoobie
    chris
    Suffolk, VA
    I am happy to take anything apart. What's step 1?
    - seeing the last connect before the license plate bulb
    - identify mount location somewhere for a standard relay?
    - other/more?
    I am a bit non-electrical but I can be coached
  4. Oct 21, 2024 at 1:32 PM
    daveeasa
    David
    PNW
    I think you summed it up. Some numbers and photos and see if the plate bulb connector has a 5 digit number on it but I might recognize it by photo alone.
    But, thinking about it more, the plate bulbs are in the lift-door right? So, if we did a universal we'd have the opposite problem, sending wire into the cab from outside.
    sigh.
    I think maybe it would require everything inside? I think the taillight is a 6 way unsealed IIRC? But the plate stuff I haven't ever seen a good photo of.
  5. Oct 21, 2024 at 1:43 PM
    wahoobie
    chris
    Suffolk, VA
    Yes, plate is in the hatch. I'll get a few photos as I can and perhaps a solution can come together. Happy to iterate... priority is a new clutch in the Jeep but that shouldn't kill me.
    daveeasa[QUOTED] likes this.
  6. Oct 21, 2024 at 2:02 PM
    daveeasa
    David
    PNW
    Cool, try to document the best path. I do have some unsealed relays. This one doesn't seem quite as clean as others but if there's interest and it's not too much of a pain I can try to slate it into the product pipeline. I forget if I have the taillight connectors or I haven't yet bought them.
    wahoobie[OP] likes this.
