License Plate Light Not Working...save me from a ticket!
Discussion in 'Lighting' started by lonzorizo, Aug 20, 2011.
  1. Aug 20, 2011 at 10:23 PM
    lonzorizo
    lonzorizo [OP] Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Got pulled over the other day b/c my license plate bulbs weren't working...got a warning. So I ordered some led's from superbrightled's, popped em in today...and the license plate lights still dont work! Checked the 10a tail fuse and everythings good. What else should I check? Any other fuses?
    Seems that i've had re-occuring bulbs burning out...when I first got the truck in march a headlight went out, couple weeks later a tail light, then half the dash went out, and also a climate control knob light burnt out. And now the tail light bulbs?! Anybody have any idea whats up?
  2. Aug 21, 2011 at 5:56 AM
    jsutter
    jsutter Well-Known Member
    Jim
    Southeast Ohio
    08 Reg. Cab 4cyl 2wd
    cruise and intermittent wipers
    Is any power going to the LEDs? Stick a volt meter in there and check.
  3. Aug 21, 2011 at 6:35 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Some times the circuit ampacity wont support an LED bulb, or the stock plug has opposite polarity than the LED bulb and will not power it. If you don't have a multimeter, your next step is to purchase the OEM bulbs and replace them, then go from there.
    If you do have a multimeter, test DC voltage at the plug like Jsutter said. I would also measure resistance to ground.
  4. Aug 21, 2011 at 8:49 AM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Ill try and have someone get me a multimeter today...there's nowhere to buy one in town lol. What does measuring resistance to ground do?
  5. Aug 21, 2011 at 6:17 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Measuring resistance to ground tells you wether or not your circuit is shorted to ground. For example, if you have a worn or bare +12v wire that is touching the frame, you'll measure 0hms to ground, demonstrating a short.
    You can get a cheap, basic multi-meter supporting all the features you need to work on a 12v DC circuit at Autozone or Advanced Auto Parts.
  6. Aug 21, 2011 at 9:05 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    So I borrowed a multimeter...got power. Then put the bulb back in and checked once more...and the light came on? So I pulled the other bulb out and started bending the metal pins a bit and put the bulb back in and after some wiggling it came on. Sweet! lol thanks everybody.
