Life changes… considering a 2023 i4 double cab SR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toyko Joe, Apr 19, 2025.
  1. Apr 20, 2025 at 1:05 PM
    Toyko Joe
    Toyko Joe [OP] Here for the pictures
    This is the lowest price 2023 within 500 miles that I have found that hasn’t been in an accident or already had 3 owners, I have been shopping around a lot to even pull the trigger to have it shipped here for a test drive.
  2. Apr 27, 2025 at 5:42 AM
    Toyko Joe
    I’m checking out the truck today. I ran the vin on Toyota website. It came back an SR5 trim not an SR.
    It also says it has a Limited Slip Differential; I thought that only comes on the TRD sport trim level. IMG_2794.jpg
  3. Apr 27, 2025 at 6:02 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It's electronic I'm pretty sure. They stopped doing mechanical LS back in the 2nd gens if I recall correctly.
    Toyko Joe[QUOTED][OP] likes this.
  4. Apr 27, 2025 at 6:18 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Every Toyota & Lexus sold in the US for the past 16 years has "limited slip differential"; it's electronic, brake-based.
  5. Apr 27, 2025 at 6:27 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The 2.7L got dual-VVTi for 3rd gen, so it isn't entirely the same as before. Listen for cold start timing chain rattle. Seen a few reports of this on this forum.
  6. Apr 27, 2025 at 6:30 AM
    Toyko Joe
    This was my thought too, but it clearly stated limited slip differential not Auto-LSD or eLSD. I’ll look carefully at the brake actuator I don’t know why Toyota would list electric brake actuated traction control as limited slip differential, seems like false information.
    Again I don’t know for sure I’m just looking at the option list online, and trying to understand what exactly is the configuration.
    A little deeper it is clear it is AutoLSD. That is fine and actually a feature I was concerned it might not have. Given the boat ramps I will be frequenting I want to be sure I at least have some sort of multi-wheel engagement.
  7. Apr 27, 2025 at 9:25 AM
    pbdude123
    pbdude123 Member
    I have a 2022 Tacoma SR double cab 2wd with the 2.7 liter I4 engine. It has plenty of room for the family. The back seat easily fits 3 teenagers. Now I have 34k miles on it, and it's been very reliable for the 3 years I've owned it. Bought it new in 2022. I plan to keep it for at least 10 years/200k miles. It's not as fast as the V6 model, but it seems fast enough around town. I don't use it for towing. It has to shift to lower gears going uphill, but it doesn't struggle. The 6 speed auto trans works very well with the 2.7 liter engine. Sometime it shifts a little rough into 4th gear when it's cold, but no problem once it's warmed up. I was averaging 25mpg on the highway and 22mpg in the city, until I put larger all terrain tires on it. Now gas mileage is more like 23mpg on the highway and 18mpg in the city with 265/70R16 all terrain tires. Stick with 245/75R16 highway tires if you want better gas mileage.
    Toyko Joe[OP] likes this.
  8. Apr 27, 2025 at 10:00 AM
    yotadust
    yotadust Well-Known Member
    2TR-FE (4-cylinder):
    • Reliability:
      The 2TR-FE is a well-regarded engine known for its strong performance and reliability.
    • Durability:
      While generally durable, it may not have the same longevity as the V6 engine.
    • Mileage Expectations:
      Many owners report reaching 200,000 miles and beyond with the 4-cylinder, but the V6 is often associated with even higher mileage potential.
    2GR-FKS (V6):
    • Reliability:
      The 2GR-FKS is considered a very reliable engine by many, with some owners reporting 200,000+ miles and even 300,000+ miles on a single engine.
    • Durability:
      Its robust design and high-quality materials contribute to its strong durability.
      Toyota's V6 engines, including the 2GR-FKS, are known for their longevity and ability to reach high mileage with proper maintenance.
    In Summary:
    While both engines offer reliability and durability, the V6 (2GR-FKS) generally has a reputation for being even more durable and capable of reaching higher mileage compared to the 4-cylinder (2TR-FE).
  9. Apr 27, 2025 at 10:09 AM
    yotadust
    got a link to the Carfax?? That is a must have before buying used especially if you arent going to have a trusted mechanic do a used car inspection.
  10. Apr 27, 2025 at 10:13 AM
    yotadust
    there is a lot of squirrely stuff with the vins on these trucks as they were closing out the 3rd gen in 2023 you really have to know what you are looking at on the 23s. Some SRs are even marked TRD and such when you lookup the VINs.
  11. Apr 27, 2025 at 10:15 AM
    Toyko Joe
    Carfax is clean, it was a fleet truck maintained, on schedule as it shows. No issues with floor or accident.
    Price is at $29k which is much lower than other 2023 SR5 I have seen even for the 4cyl. I am not sure what to make of it. The truck is a WANT right now not a need. So I am looking at the lowest cost and mileage newest 3rd gen I can find.
  12. Apr 27, 2025 at 10:25 AM
    yotadust
    that a pretty good price depending on the miles for around here in south Florida anyways. Any factory powertrain warranty left Incase some engine trans issues arise after purchase?
  13. Apr 27, 2025 at 10:34 AM
    TacoDell60
    TacoDell60 Well-Known Member
    No 3rd gens have a mechanical LSD dude... get a 4x4 if you need traction.
  14. Apr 27, 2025 at 10:39 AM
    TacoDell60
    Bro WHAT NONSENSE IS THIS :rofl:
    The 2GR-FKS has the reputation for leaking from every orifice, grenading a cylinder on steep inclines, the rear plastic coolant bypass pipe will 100% fail at some point, the issues go on and on and on.
    I've never seen a million mile 3.5, but plenty of million mile 2.7's.
    The 2tr-fe has been around for 2 generations while the 3.5 was scrapped ASAP because it's such a pos.
    You're out to lunch dude
    BillF1564 and 09 Redneck like this.
  15. Apr 27, 2025 at 10:42 AM
    #35
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    We've used my double cab as a road trip vehicle but it's cramped. I'm the tallest at 5'8." In a few more years when our 13 year old gets a bit taller it'll be miserable.
  16. Apr 27, 2025 at 11:11 AM
    #36
    yotadust
    2.7s had a cake life due to payload and tow restrictions. they aren't being worked. what do you think will last longer a semi without a trailer going back and forth across the country or one always pulling 80k lbs regularly.
  17. Apr 27, 2025 at 11:16 AM
    #37
    TacoDell60
    dude lol just quit while you're ahead
    BillF1564 likes this.
  18. Apr 27, 2025 at 11:16 AM
    #38
    SpicyTaco612
    SpicyTaco612 Active Member
    Taylor
    2020 Spicy TRD Sport
    After having driven cross country for a snowboarding trip as a solo occupant. I would advise against a long term hold of a Tacoma if you intended to use this for any form of long distance travel as a family of 4.
    Jesse H and TacoDell60 like this.
  19. Apr 27, 2025 at 11:18 AM
    #39
    yotadust
    2.7s all day long I remember
  20. Apr 27, 2025 at 11:20 AM
    #40
    yotadust
    3rd gen is good for about a 1hr round trip lol. 4th gen might get you an hour and a half lol
