Life expectancy of 2nd gen AC Compressors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hexnutter, Jun 27, 2021.
  1. Jun 30, 2021 at 11:25 AM
    #41
    jorgem
    jorgem Well-Known Member
    252,000 on my 2006. Its been on full blast permanently here is south florida since 2006.
    I dont have any other settings anyways, resistor is bad. LOL
    I hope I didnt jinx it
  2. Jun 30, 2021 at 3:24 PM
    #42
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Uh-Oh!
  3. Jun 30, 2021 at 4:01 PM
    #43
    GerTaco92
    GerTaco92 Active Member
    Gerry
    GA
    My buddy recently acquired this Taco project with a clutch and AC issues. The owner didn't bother to get it fixed after the high price quote from the local shops. It also some squeaking noise so we'll check that out after the installation of the new set of tires from 4Wheelonline. Might try the cheap fix first and see.
  4. Jun 30, 2021 at 4:09 PM
    #44
    verlaryder
    verlaryder Well-Known Member
    have a '93 toy pickup R12 system. 169,000 miles and still going strong. Just added 1/4 of a can top off of R12 refrigerant a couple times over the years. Secret to long life is to run system 5 minutes a couple times a month during the winter. keep system fully charged. And after a period of non-use, only start system when engine is at idling speed.
    EricT likes this.
  5. Jul 22, 2021 at 9:50 AM
    #45
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    51k miles on my 2015. A clattering noise from the compressor/belt tensioner, especially shifting from P to D with the air conditioning on. New Denso compressor and new belt tensioner going in... $$$, and not the life I usually expect from my Toyotas and Tacomas.
  6. Jul 22, 2021 at 10:58 AM
    #46
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    The compressor is engaged any time you have the windshield defrost setting On. Going out of your way to run the A/C is just wasted time/effort, though if it helps you sleep better at night then have at it.
    I had a '93 Toyota pickup too; 22RE, 5spd, with A/C...it was a good truck.
  7. Jul 22, 2021 at 11:21 AM
    #47
    hexnutter
    hexnutter [OP] Well-Known Member
    doug
    Tacoma
    That sucks, do you live in a cold climate and dont use ac 6 months say out of the year?
  8. Jul 22, 2021 at 12:04 PM
    #48
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    I felt the same way when my power steering rack blew out at 60k miles. Gotta remember for these parts theyre made by third parties usually, and stuff happens. Bad run of parts, factory issues, etc. I like my tacoma but its not perfect, no vehicles are.
    Just learned via a Scotty Kilmer vid that the same transfer case in the Tundra is in the new fords and dodges as well. Go figure.
    blu92in99 likes this.
  9. Jul 22, 2021 at 12:33 PM
    #49
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I got an 06 coming up on 350,000. The only issue I've had with the AC was the expansion valve.
    SR-71A likes this.
  10. Jul 22, 2021 at 2:14 PM
    #50
    hexnutter
    doug
    Tacoma
    My bench seat is made in Mexico out of straws and piano wire. Sometimes I think it would be better to have an American truck (weight I do), but then would they go to 350,000 freek'n miles.
  11. Jul 26, 2021 at 10:20 AM
    #51
    4xdog
    Santa Fe, NM
    No, I'm in the center of the country. The AC might go three months without being used (or rarely used) but the rest of the year it runs regularly.
    My current 2003 Gen 1 has about 180k miles on its original AC system, and the 2001 Gen 1 before that had almost 140k miles when I sold it. So I'm probably due for a luck-of-the-draw failure.
    EricT[QUOTED] likes this.
  12. Jul 27, 2021 at 6:50 AM
    #52
    hexnutter
    doug
    Tacoma
    Yea its gotta be AC was never really used as its cold as hell here, except 2 months out of the year.
    Might have to go with out it don't feel like doing the job, maybe clutch but still will cost a lot.
    It seems like all the people who were using their ac regularly have theirs still working.
  13. Jul 27, 2021 at 6:51 AM
    #53
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    285k on my stock ac and it's never been serviced. Im in tx though so it gets used frequently
