Life Expectancy of OME Shocks?
Discussion in 'Suspension' started by 53flattie, Apr 6, 2015.
  1. Apr 6, 2015 at 6:02 AM
    53flattie
    53flattie [OP] Well-Known Member
    Upstate, SC
    2006 DC
    2.5" OME
    I have an OME lift with the Dakar rear springs. It was installed at around 40K miles and my truck now has 178K miles.
    I recently bought a new camper that has a hitch weight of about 350lbs. I'm running a WD hitch and I know it's set up correctly, I still get a fair amount of rear end "reverberation", if you will (not sure if that's the right term or not). Basically, when you hit a dip in the road, it takes a while for the shocks to bring the rear back under control.
    Is it possible that the shocks are past their useful life expectancy? I'm asking for opinions because I'd hate to spend the $$ on a new set, only to find that the shocks weren't the problem. If it's just something that is to be expected with a 4K pound camper, I'm fine with that too. It's not unbearable or unsafe - just noticeable.
    Thanks!
  2. Apr 6, 2015 at 6:18 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Hitch weight of 350 isn't bad. I'd say that you're well overdue for shocks. In general, any brand of shocks I've had over 100k miles on were worn out noticeably.
    I have OME/Dakar rear.
    Recently hauled ~800lb of gravel in bed with another 800lb on trailer (very low tongue weight though). Rear didn't bounce around too much. My shocks have 50k miles on them and still do well.
  3. Apr 6, 2015 at 8:37 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Your OME shocks have enjoyed a long life. Put them to rest and get some new ones. You'll probably notice a HUGE difference in how the suspension feels.
    I'm thinking about getting a full OME suspension soon, so it's nice to know they can last a long time. :)
  4. Apr 6, 2015 at 7:05 PM
    53flattie
    Upstate, SC
    2006 DC
    2.5" OME
    Thanks for the replies. Guess I'll start looking at shocks.
    Is there something that's a slight step up from the OME Nitro Chargers, but not all the way to the $250/ea range?
  5. Apr 8, 2015 at 9:40 AM
    Taco Mark86
    Taco Mark86 Well-Known Member
    Mark
    NC
    09 DCSB with some mods
    Magnaflow, Fox RR/ Camburg UCA up front, Bilsten 5100 and some kind of AAL/ leaf pack in the back?, Light bar w/ Hella, and an air freshener
    Fox 2.0 smooth bodies are around $350/ pair I think, just make sure you get the right length for your lift
  6. Apr 8, 2015 at 9:42 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Longest ive ever run any shocks or struts was around 75k miles.. they were toast.
    I typically replaced every 2 years after that cause of leaking or lack of compression anymore.
    I only buy re build able and re valve able shocks and coil overs now.
  7. Apr 9, 2015 at 9:16 AM
    MTyota
    MTyota Well-Known Member
    Bozeman, MT
    05 Tacoma 2.7 5spd SR5 4x4
    ABS switch, tailgate lock, factory fogs, tonnopro loroll, icharger aux cable, 10mm hex oil plug swaps
    The warranty is 3yrs or 60,000km so i would say they are toast. billys are lifetime!
  8. Apr 9, 2015 at 9:23 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    X2
