Life of the factory leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danteisme, Jan 31, 2012.
  1. Jan 31, 2012 at 8:02 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    how long should these springs last? i walked out to my truck at work and noticed the back is squatting a bit. i then looked at my springs, they are starting to get negative arch... its a standard cab 4x4 with the 3 leaf leafspring. i have about 84K miles on them, is this when they should be about done? i cant compare apples to apples, but i never had negative arch on my s10 with 130K miles on it...is it because this system is a 3 leaf?
  2. Jan 31, 2012 at 8:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Life depends on use. Some never have to change them out, others can be shot after 60k miles.
  3. Jan 31, 2012 at 8:18 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Good mornin' Chris! Ordered my BackRack yesterday...be here in 5 to 10 days. Found vendor in Wasilla...saved needing to drive into A-town (I avoid that as much as possible!). :cool: :)
  4. Jan 31, 2012 at 8:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :woot: Lemmie know when you get it!!
  5. Jan 31, 2012 at 8:21 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :thumbsup:
    EDIT: Sorry for:threadjacked: OP. :eek: Back on topic...My truck sagged in the rear (stock 3 leaf springs) when I loaded my ATV in the bed ('bout 625 lbs)...I added a set of Firestone Ride Rite Air Bags last Spring. Solved the problem for me ... air up for carrying loads...keep them at @ 9 psi for DD duties. Gives it a slight lift in the rear and stiffened it up a bit. I'm happy with it so far and they seem to be holding up well. FWIW...I don't off-road in my truck...just dirt/gravel roads to get to where I off-load the ATV for fun or hunting.
  6. Jan 31, 2012 at 8:51 AM
    danteisme
    South Western PA
    mine is now starting to sag empty. i can't say how it was used previous to me buying it (i bought it at 39K miles) but its only ever really hauled something maybe a handful of times a year and i never really been off-roading, just access roads and such for work. at the beginning of october i put a set of hellwig helper springs on.
  7. Jan 31, 2012 at 8:58 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    I considered an AAL (Add A Leaf), but went with the air bags because I wanted to be able to air up when I put the load on ( dozen times or so a year ). For what you're describing, an AAL might do the trick. Do a search and you should find some info on it. I didn't have any noticeable sag unloaded.
  8. Jan 31, 2012 at 8:58 AM
    acdronin
    acdronin Well-Known Member
    IMO the leafs are one of the few weak points on these trucks, i have a cap and heavy rack, plus tools and materials so mine were pretty well shot a 60k, ditto on the airbags, i have a set of firestones on mine and love them, if you don't want to spend the $ and time for new leafs, an Add-A-Leaf, good shocks and airbags sovled the problem for me:D
  9. Jan 31, 2012 at 9:00 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :thumbsup: .... and a Good Morning to you, SF Chris! :cool:
  10. Jan 31, 2012 at 9:02 AM
    danteisme
    South Western PA
    i have a toytec AAL, i decided not to lift my truck so i put them up for sale. i may just keep them now, i'm just worried with the addition of the AAL it will give me crazy rake in the rear. i do not want to lift my front, i've read too many threads about the front diff issues. i may just try to find a set of used (better than mine tho) leaf springs. 3 leaf 4 leaf whatever
  11. Jan 31, 2012 at 9:05 AM
    Cowboyz
    Cowboyz Membor
    Luke
    Southern Utah/Las Vegas
    07 DC LB TRD Sport
    6in Pro Comp stage 2 lift, 2.75in ProComp Coilovers, Rear MX6 adjustable shocks, 35in Nittro Trail Grapplers, 17 in XD Spys, URD intake, URD MAF Calibrator, Flowmaster 40 Series, AMP Power steps, debadged, blacked out tail lights, Blacked out headlights w/ Mini H1 Retros and halos, JVC KW-AVX840 7" Double-Din, Viper 5704 2way alarm/remote start, LEDs in Dome, Maps, and license plate lights, short black antenna, 5% Tint, removed sway bar
    So mine are not "sagging" yet but they seem like they are right about flat. I dont need any additional lift in the rear, so what is a good replacement?
    btw im right at 75k with a 6in pro comp stage 2 lift
  12. Jan 31, 2012 at 9:08 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    I haven't looked at it lately, but I think you might be able to combine AAL with some Bilstein 5100s set to level things out. Might talk to the Downsouth Motorsports folks...let me check if they are still a vendor here. I'm keeping them in mind for when my stock shocks need to be replaced.
    Yep: http://www.tacomaworld.com/forum/downsouth-motorsports/
  13. Jan 31, 2012 at 9:13 AM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    I had a slight negative arch. It was more like a very flat "w". I changed them out at 175K. I replaced them with Wheeler's four-leaf leaf springs (stock lift) and used new poly bushings, greaseable main eye bolts, and greasable shackle. The new shackle moves a lot better than the ultra stiff old one.
    You should look into changing them. On the older Tacomas, the leaf springs were made of crappy steel that wears out faster.
  14. Jan 31, 2012 at 9:18 AM
    acdronin
    Runnin off to Oakland, be back later
  15. Jan 31, 2012 at 9:18 AM
    danteisme
    South Western PA
    yeah i have the AAL for the rear, and bilstein 5100's all for all 4 corners in a box at my house. i'm reluctant to add the AAL. its advertised as a 1.5" lift, i'm not sure how much it will lift a bad leaf spring, and i'm reluctant to lift the front even on the .85" setting after reading through the various threads about the front diff issues that are occurring. some of them even at the .85" setting.
  16. Jan 31, 2012 at 9:22 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Hmmm...yeah hadn't considered that on the front...and I just had my front diff replaced! ... Now you have a conundrum my friend. Good luck...I'll stay sub'd to see how it resolves...if anything comes to mind, I'll pipe up with it. :cool:
  17. Jan 31, 2012 at 9:22 AM
    acdronin
    I would say that if you can determine how much it has sagged, 1.5 on the AAL would probably get you back to stock height or close too it, BTW, the AAL and 5100's were a WORLD of difference in how the truck felt
  18. Jan 31, 2012 at 9:24 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Stop that! :p You're putting ideas in my feeble old mind that are giving me a pain in the wallet area of my a$$. ;) Not to mention placing me in jeopardy with my wife. :eek:
  19. Jan 31, 2012 at 9:57 AM
    danteisme
    South Western PA
    thats true, i could do that. i may still opt for a replacement set of springs as long as they are from a new truck. i'd be worried i'd put the AAL on and it would only be a bandaid for a while and then the problem would be back again.
  20. Jan 31, 2012 at 11:19 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Exactly what I was told.
    60k miles for the OE springs.
    I used airbags to regain some rear spring.
    Bilstein 5100's won't cure what Toyota couldn't do right, but they are an awesome upgrade from the shit that Toyota spec'd.
