Life span of a 3.4L
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaKid62, Jan 21, 2012.
  1. Mar 24, 2016 at 10:17 AM
    #181
    AZTacoSupreme
    AZTacoSupreme Well-Known Member
    Anthony
    Chandler, AZ
    2006 LS430/ 2004 Sequoia 4X4
    I got it with 140k on it and I'm up to 161k and this thing still runs great. No ticking or leaks. Motherfucker is bulletproof
    68dave likes this.
  2. Mar 24, 2016 at 12:27 PM
    #182
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    Sold my 95.5 with 160k. Aside from a minor oil leak, which i had fixed, and a starter go out around 100k I never did a single thing other than scheduled maintenance. I have no doubt that if I still owned it I would still be going strong with around 300k miles. Selling that thing was a huge mistake
  3. Mar 26, 2016 at 4:05 PM
    #183
    Tonkkids
    Tonkkids 2001 Taco PreRunner V6
    Bubba
    Thomaston GA
    2001 Prerunner SR5 V6
    Got 298K+ on mine. Fixin to join the 300K club. Oil change every 5000 with Castrol GTX, timing belt/water pump every 100,000 (3rd one coming up), and I had to put a battery in it last summer. Hot heat, cold A/C. TANK
  4. Apr 7, 2016 at 7:08 PM
    #184
    Prerunner punk
    Prerunner punk Member
    02 auto 3.4 trd
    Deck plate
    122000 on my 02,auto. I use max life hm and Walmart ST trans fluid with drain and fill every summer. Still a juvenile.
  5. Apr 7, 2016 at 9:44 PM
    #185
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    currently at 322,000+ on my 2001
    QMEDJoe likes this.
  6. Apr 8, 2016 at 10:53 AM
    #186
    MattFL
    MattFL Well-Known Member
    S. Florida
    1999 Tacoma V6 4x4 TRD Extended cab
    188k on my 1999 5-speed v6, lots of towing and still going strong. Oil changes every 5k miles with Mobile 1 5-30 synthetic and OEM filters. Tranny, TX and diff oil changes earlier than recommended with Valvoline 80-90 gear oil.
    How many of you high mileage guys tow regularly, and how much weight? I'm hoping a lot of you high mileage guys also tow on regular occasion. :)
  7. Apr 9, 2016 at 9:17 AM
    #187
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I just bought this 1 owner 04 tacoma TRD last Saturday with 475k miles. Seller told me it's the original drivetrain. It ran & drove great during the 2 hour trip home!
  8. Apr 9, 2016 at 10:01 AM
    #188
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    The previous owner of my truck had the original motor in the truck up to 340k and then replaced it.
  9. Apr 9, 2016 at 10:02 AM
    #189
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    @68dave jus picked up an 04 Taco with over 475k still going strong. Insane
  10. Apr 9, 2016 at 10:03 AM
    #190
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Beat me to it!
    68dave[QUOTED] likes this.
  11. Apr 9, 2016 at 12:05 PM
    #191
    tbr3345
    tbr3345 Well-Known Member
    Tom
    Sacramento, CA
    2010 TRD Sport DBL Cab Silver Streak Mica
    My 02 Double Cab V6 has 153K on it run like a dream no problems or issues just maintenance, replaced Valve cover Gasket, plugs and wires a month ago new radiator and Windshield, shocks and Struts and new tires did it all myself. except tire and windshield. Bought it new the day I retired and at almost 74 it will probably last me as long as I want and can drive. The to one of the Grandsons
    Tom
  12. Apr 10, 2016 at 5:44 PM
    #192
    Aufmitdemspiel
    Aufmitdemspiel Member
    98' 4wd V6 Tacoma
    x2; 5VZ is 5VZ, no?
  13. Apr 11, 2016 at 7:44 PM
    #193
    dirtyharry
    dirtyharry New Member
    1995 California Edition SR5 Tacoma
    My 95 SR5 just rolled over 330K. Everything original other than replacing the timing belt at 200K as a preventative maintenance issue, and some U-Joints.
    The Garage that did the drive shaft U-joint replacement didn't keep the shaft timed, and it vibrated badly when it was reinstalled. Spent a ton of time sending it to some places that balanced driveshafts, but found out they only spun it up to 500 rpm. Found a shop in San Antonio that builds drive shafts for dragsters, and spins them up to driving speed. They got it right.
  14. Apr 11, 2016 at 7:51 PM
    #194
    TallTallPines
    TallTallPines '10 Barcelona RC
    Opelika, Alabama
    Have had my '02 3.4 in the family for almost all 185k miles and it has towed all sorts of stuff. Cars, trucks, moved countless times, pulled stumps, been borrowed by Tom, Dick, Harry, AND Jane. Not been kept up maintenance wise unfortunately but it still drives very solid and runs like a scalded cat on the original timing belt.
    It's been said "In the end, there will only be cock roaches and Toyota 5VZs".
    Obsessed2000 likes this.
  15. Apr 24, 2016 at 12:22 AM
    #195
    95babybluetaco
    95babybluetaco Active Member
    Joe
    Beavercreek, Oregon
    1995 Toyota Tacoma 4x4 3.4
    18 inch Magnaflow muffler 31" BFG KO2's
    It's nice to see people with the 95-97 3.4 engines getting 250,000+ miles without head gasket trouble. I'm at 160k and I keep worrying if my 95 may run into the problem in the future. It seems like the earlier motors that were under the head gasket recall are more prone to HG failure than the 98+ years once the trucks get into the higher mileage range.
  16. Apr 30, 2016 at 2:00 PM
    #196
    2wireguy
    2wireguy New Member
    South Mississippi
    96 stock-taco
    Dents & holes , inner fender / mudflap delete
    My buddy's mom's 98 4Runner had 575k last time I looked and it has had a rough life
    68dave likes this.
  17. Nov 2, 2016 at 9:46 AM
    #197
    Steeleygreg
    Steeleygreg New Member
    Greg
    Steele
    None
    I've got a 96 4*4 5 speed stick Tacoma with the 3.4 Liter engine. No mods done. Outside of changing the oil and transmission fluid, I've replaced the alternator, power steering pump, and the exhaust system. Due to my lack of regular maintenance, I had to clean the MAS airflow assembly and replace the PCV valve. No other engine parts need to be replaced. Currently I've got 359 K miles. Engine still starts and purrs like a kitten. Outside of a somewhat squeaky throw-out bearing, I'll replace that when the original clutch goes bad.
  18. Nov 19, 2016 at 7:35 PM
    #198
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    My wife and I have a 1999 Tacoma with the 3.4, and it has 165,000 miles on it. We have used Castrol 5W-30 full synthetic since it has had 90,000 miles on it. The old Tacoma runs like a dream. It is our fixer upper house fix it truck. The Toyota 3.4 V6 is an amazing engine.
  19. Nov 22, 2016 at 8:14 PM
    #199
    1997tacomav6
    Denver
    512,000 miles, original 3.4 engine got a head gasket leak at 485,000 and was supercharged the whole time. Replaced it with a 2004 motor with 100,000 on the new motor,
    A bulletproof engine
    Tyler Lacasse likes this.
  20. Nov 22, 2016 at 9:50 PM
    #200
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    3 words.
    Million Mile Club
