Life span of a 3.4L
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaKid62, Jan 21, 2012.
  1. Aug 16, 2017 at 11:25 AM
    #221
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Wow, there are some pretty high mileage rigs with the 3.4 Toyota engine on this thread. This is the last thing Toyota wants to read about. They don't want to hear about an engine they engineered that goes for 500,000 miles. This kind of engineering prevents us all from purchasing new Tacomas.
    1997tacomav6, Sodom and Tacofire98 like this.
  2. Aug 21, 2017 at 5:32 PM
    #222
    Jonhin
    Jonhin Member
    I bought a 1996 T100 3.4 V6 new . Had 3 miles on it . I drove it all over and back again. NEVER left me anywhere except once and that wasn't her fault . Filled up late one night , only place open and got a tank of water . I sold it a good while back to a kid (4500$) down the road with 368985 miles on it . I see it every day still hauling butt and he drives it a lot harder than I did .
    Replaced it with a 1999 Taco 2.4 l , got it from original owner with 89000 on it . (5800$) . Sold it yesterday with 168486 on it .
    Replaced it with a 1999 Taco Prerunner 2.7 l . Got it from original owner with 88000 on it . (8500$) . Gonna tweek it out a little . Hope to ride to the sun and back again , if the moon would get out of the way !
  3. Aug 21, 2017 at 6:53 PM
    #223
    Danno1985
    Danno1985 Well-Known Member
    Milwaukee
    2003 Prerunner TRD Off-Road (RIP)
    I've learned the hard way that some legendarily-reliable cars were more hype than reality, but the Toyota 3.4L has been the real deal for me. 273K and some change on the 3.4 in my '96 4runner when I sold it. The damn thing leaked a little out of the valve cover gaskets but didn't burn a drop, never left my stranded other then the one time the alternator died at the end of long trip but waited until I was about a hundred feet from my house to completely crap out :), and it still had good power and still pulled around mpgs on the freeway, loaded up with camping gear and a canoe on the top. My Taco has 213K, I bought it with around 200K and had no qualms whatsoever. I plan on doubling it at the least. The 5VZ-FE is just one of the all-time reliability home runs.
    Hamer95USA, Wulf and TacomaJunkie8691 like this.
  4. Aug 24, 2017 at 5:52 AM
    #224
    Chuck85
    Chuck85 Well-Known Member
    brad
    utah
    01 trd
    sased,dual cased, dual locked, supercharged, a bunch of other stuff
    I have a 01 runner with 230,000 and runs smooth
    Dalandser likes this.
  5. Oct 28, 2017 at 7:08 PM
    #225
    tacoboat
    tacoboat New Member
    2004 Tacoma SR5 PreRunner 2WD
    04 Tacoma PreRunner 2WD 234,000 miles on it and not a sputter 3.4L is the business
  6. Nov 10, 2017 at 7:50 AM
    #226
    Mojave4x
    Mojave4x Active Member
    98 SR5 4x4 extended cab 3.4 5speed & 08 limited 4Runner 4x4 4.0
    Detroit TrueTrac both diffs, re-gear 4:30, Wheeler's 8 leaf, OME 881, JBA UCAs, Bilstein 5100 all 4 corners, All new u-joints & ball joints, new LCA bushings
    98 3.4 with 356k, regular maintenance, timing belt replacement and synthetic oil are key. It’s starting to lose some power but I’m not disappointed, been very very reliable. I bought new, have replaced the radiator that blew at about 300k, 1 Fuel injector went bad, a couple clutches, brakes. Built at the now defunct Fremont California plant, and kept mostly stock. Will rebuild for reliability as it’s going to be for overlanding.
    1997tacomav6 likes this.
  7. Nov 10, 2017 at 9:06 AM
    #227
    archerm3
    archerm3 Well-Known Member
    Nebraska
    97LX (sold) 15DCSB BRM MT OR(RIP) 09 Tahoe
    Brake controller, Snugtop, Hellwig981, Gentex, custom frame bending and body removal by red light runner.
    242000 when I sold mine and didn't use a lick of oil.
  8. Nov 10, 2017 at 3:17 PM
    #228
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Well... they build Teslas there now
  9. Nov 10, 2017 at 5:27 PM
    #229
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    258,000 miles on my 2002 3.4
    Bought it with 86,000 miles on it. Had to replace an O2 sensor at about 150,000, changed the timing belt at about 200,000 and just changed the spark plugs (literally) like 2 weeks ago. (To resolve a misfire code/check engine light). Other than routine maint, like oil changes, that is all I have ever had to do to it.
    TacomaJunkie8691 and Des0911 like this.
  10. Nov 10, 2017 at 5:33 PM
    #230
    Gigawatts
    Gigawatts Well-Known Member
    SRunner
    This is good stuff. I guess that's why Toyota didn't have a problem including the supercharger in the factory warranty.
  11. Nov 11, 2017 at 1:08 AM
    #231
    bowhunter62986
    bowhunter62986 New Member
    Greg
    98 Ext cab SR5 4wd Tacoma 5spd
    Bigger wheels and tires rock/body guards SkidRow off road skid plates
    My 98 currently has 310,000 & still going strong it's also my daily driver & now days i drive avg of 2500 miles a month no leaks or warning lights I love my truck
  12. Dec 2, 2018 at 3:54 AM
    #232
    rugerm44
    rugerm44 Member
    Bought mine new . synthetic oil only.Blow head gasket at 144000.Both heads are cracked between valves.Answer your question
  13. Dec 2, 2018 at 4:00 AM
    #233
    1997tacomav6
    Denver
    That sounds like maybe the engine was overheated at one time ???
  14. Dec 2, 2018 at 4:07 AM
    #234
    rugerm44
    rugerm44 Member
    Never was kept up maintenance from day one.New thermostat every 5 years. Owned them since 86.I have auxiliary gauges that are more accurate than factory.Cyl walls look like 39,000 miles instead of 144,000.Over 100000 is hyw miles.My luck . Friend works on a lot of different vehicles. Seen several with cracked heads same spot.Casting is really thin between valves.Putting new heads on it and see if I can get another 144000 out of it.Its a really nice truck . seats had covers on since day one
  15. Dec 2, 2018 at 4:10 AM
    #235
    1997tacomav6
    Denver
    Wow, that’s strange,
    I popped a head gasket at 489,000 and was boosted from day one and I run th e hell out of it.
  16. Dec 2, 2018 at 4:21 AM
    #236
    rugerm44
    rugerm44 Member
    I ran it for a while trying to figure out what was causing miss at start up once every few weeks.Then one day going to work starting running like plug wire off . parked it.Ran at idle blowing coolant out tail pipe . like I said. Never overheated and rarely pulled anything over 2500 lbs.Oh well
  17. Dec 2, 2018 at 4:29 AM
    #237
    1997tacomav6
    Denver
    What do new heads run?
    And labor?
  18. Dec 2, 2018 at 4:39 AM
    #238
    rugerm44
    rugerm44 Member
    Factory with valves only parts 2200 fir both. Doing myself cant say for labor. Aftermarket bare head 456 a piece
  19. Dec 2, 2018 at 4:48 AM
    #239
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    A flip of the coin with the six's. Personally,,all these first gen six's should have been a proven 300hp and the 4 bangers a true 250hp. More power equals MUCH better parts on the average. Toyota could have easily done that, with atmospheric pressure,, with all of the very old school TRD assets at there disposal. Instead,,we tentatively bought disposables. Buggers!!. I love my truck,,but so much more room for improvement,,even now.
  20. Dec 2, 2018 at 4:57 AM
    #240
    rugerm44
    rugerm44 Member
    Bought 06 new.Kept the 02 and sold it.Good eng piss poor body
