Life span of a 3.4L
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaKid62, Jan 21, 2012.
  1. Aug 5, 2019 at 4:54 PM
    #301
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    323k on my 1998 and still truckin!
    TacomaJunkie8691, Fred d and GQ7227 like this.
  2. Aug 5, 2019 at 8:17 PM
    #302
    Dammmm
    Dammmm Well-Known Member
    martin
    1999 toyota tacoma v6 3.4l rwd extra cab per runner
    I guess the bottom manifold gasket leaking coolant. Where is there a good place with prices for the bottom gasket please
  3. Jan 17, 2020 at 6:51 PM
    #303
    Arfnog
    Arfnog New Member
    Theo
    2000 Tacoma
    My 2000 Tacoma has 485000km just services them regularly and will run for ever. We have a 2000 Camry has over 700000km
    TacomaJunkie8691 and GQ7227 like this.
  4. Jan 18, 2020 at 9:28 AM
    #304
    techfinsoup
    techfinsoup Well-Known Member
    Sacramento
    1996 Tacoma 4x4
    1996 with 308k, runs like a champ!
    Paseo and GQ7227 like this.
  5. Jul 5, 2020 at 12:00 PM
    #305
    Rhecclark
    Rhecclark New Member
    Aaron
    2002 Toyota Tacoma 4x4, 3.4l v6
    Leveling kit, 20x10 xds on 32s
    2002 4x4 with 165k just blew my second one yesterday, 6k on the new engine and boom 3rd times the charm right?
  6. Jul 5, 2020 at 12:13 PM
    #306
    jpstrong
    jpstrong Member
    Jon
    95 with 213k still runs strong
  7. Jul 5, 2020 at 2:35 PM
    #307
    rickyg2008
    rickyg2008 Well-Known Member
    Mine went out at 130k . Motor ran for 17 years so longevity was there . I was the 3rd owner .. I put a new oem short block ...hoping I won’t have to buy a new one for another 17 years
  8. Jul 6, 2020 at 1:16 PM
    #308
    Morden
    Morden Well-Known Member
    Cali Central Valley
    2002 Tacoma TRD PreRunner
    2002 w/180k (give or take) and still runs like a champ.
  9. Jul 6, 2020 at 6:49 PM
    #309
    TacoMan2001
    TacoMan2001 Active Member
    Tyler
    Silver 2001 Tacoma extended cab TRD
    3 in lift and a lot of wax, but never enough to prevent people from hitting my car :(
    how much money did it cost yah?
  10. Nov 27, 2021 at 8:07 PM
    #310
    nptesta16
    nptesta16 Active Member
    Nick
    Berkeley, CA
    El Guaco Taco: Silver 2001 Tacoma Prerunner V6 TRD off-road
    My 2001 3.4 V6 Prerunner is at 308,000, but it's required some love. The guy who dumped it on me regularly towed at its capacity, which I believe led to some of the issues I'll mention later. He did change the struts and coilovers, radiator, upgraded air intake. When I got it, the only obvious issue was leaking valve cover gaskets, concurred upon by a mechanic I took it to for a pre-purchase inspection in the town where I bought it. The previous owner claimed he'd done extensive maintenance, and that "there may be some minor cosmetic issues, but you couldn't ask for a more mechanically sound first gen taco".
    So far I've replaced the passenger door handle, driver's window motor, xtracab window latches, passengers' headlight, all exterior bulbs, some arbitrary rattles, battery, fuel filter, brake pads, brake fluid, engine and transmission mounts, engine oil and oil filter, whole rear diff/axle assembly, steering rack, sway bar links, and ball joints. I also did the driveshaft carrier bearing and u-joints as formalities. I still have to do the front lower control arm bushings and now that I've changed the rear diff it's obvious that the transmission's an issue too. Call me crazy for doing all this maintenance at such high mileage but I can guarantee that the engine is pristine; my friend who is a Toyota mechanic came by and confirmed this when I was doing the VCGs (not the mechanic who missed all the initial red flags). I feel like I'm too deep now to quit so we'll see where things go :) Besides, cars are in such short supply these days because of the supply chain issues so I've been more able to justify fixing the thing up.
    elw00d likes this.
  11. Nov 27, 2021 at 8:18 PM
    #311
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    got 300 out of 2 diff trucks. have one currently with 260 and I bet the sh!t out of it... Change the oil and they last for a while. Oh yeah, keep a clean air filter too.. NO filters with OIL!!! kills the rings!
  12. Nov 27, 2021 at 8:25 PM
    #312
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    why would k&n filters kill the rings?
    bgrant570 likes this.
  13. Nov 27, 2021 at 8:27 PM
    #313
    Woodini
    Woodini Well-Known Member
    Ray
    Daytona Beach Shores
    89 Pickup 22RE 4wd
    LCE i/h/e OME susp (install soon) 17” fn counter steer, gonna buy new rubber
    1989 22RE 4wd, 184,xxx mi.
    still fresh (;
  14. Nov 27, 2021 at 8:31 PM
    #314
    Yota X
    NW New Jersey
    1st gen
    I mean, Im not 100% sure that it was the cause but I just bought a 2004 with a bad motor and the intake and throttle body was caked with oil and sand basically... The k&n filter was in the truck still and it looked like the kid just kept oiling it instead of cleaning it... Anyway, the cylinders had like 30, 60, 90, 110 compression and when I pulled the motor and checked the valves they were totally fine.. I did the oil test and it brought the compression up to 130-140...
    So, I basically decided that the sand that escaped the filter with the oil ruined the motor....
  15. Nov 28, 2021 at 5:12 PM
    #315
    SteveW504
    SteveW504 Active Member
    '96 4WD
    Body lift by previous owner. Rear welded locker by same fool.
    318,000 miles and counting on my 4x4, 3.4 '96 SR5. If yours is a 4x4, I'll buy it from you today. 65k is barely broken in.
  16. Nov 28, 2021 at 5:22 PM
    #316
    FinsFan909
    FinsFan909 Well-Known Member
    1996 4x4 Tacoma V6
    My dad had a 93 Toyota pickup over 450000 before it was stolen and then bought a 2003 Tacoma and got it up over 400000 before someone blew a red light and jackknifed my brother in an accident 2 years ago. Other than maintenance my dads never replaced an engine or replaced the clutch as far as I know.
  17. Nov 29, 2021 at 10:59 AM
    #317
    nptesta16
    Nick
    Berkeley, CA
    Uhh the guy who had mine before installed a K&N oiled filter... what do I do? Stop oiling it and just clean? Change back to stock intake?
  18. Nov 29, 2021 at 11:08 AM
    #318
    skusty
    skusty Well-Known Member
    Sam
    San Diego
    2003 Tacoma TRD
    182k on my 03, hoping to double that!
  19. Nov 29, 2021 at 6:10 PM
    #319
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    Get a dry air filter like the AEM Brute filter if the diameter is the same, you may want to verify
  20. Nov 29, 2021 at 6:42 PM
    #320
    Milor
    shaun
    thats abuse by the previous owner... plus if your doing heavy sand driving the k&n filters need a bag/cover over them. my motors at 263k I just replaced my valve covers and the cams & valves looked great. most of its life its had a k&n... the pcv system on these trucks puts oily air right back through the throttle body. If you want the intake to stay clean get yourself a catch can system for the valve cover breathers & pcv .
    bgrant570 and Akkording like this.
