Life span of a 3.4L
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaKid62, Jan 21, 2012.
  1. Jan 27, 2015 at 6:05 PM
    #141
    hurley842002
    hurley842002 Well-Known Member
    Dan
    Thornton, Colorado
    02 SR5 TRD
    Bone stock (for now)
    This is where I'm at, and still running strong.
  2. Jan 30, 2015 at 4:23 PM
    #142
    David 1480
    David 1480 New Member
    David
    Cayuga ontario canada
    03 Tacoma 4x4
    I can see mylast post .I have 565,000k on my 03 taco
  3. Jan 30, 2015 at 4:24 PM
    #143
    David 1480
    David
    03 Tacoma 4x4
    Im meant I cant see my last post Im new to this
  4. Jan 30, 2015 at 10:15 PM
    #144
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    171k. Has a valve tick. Oil is starting to ooze past the pan gasket. Other then that, engine runs good. Truck has a few more problems
  5. Jan 31, 2015 at 6:39 AM
    #145
    EdFlecko
    EdFlecko Well-Known Member
    Ed
    Sacramento, California
  6. Jan 31, 2015 at 9:50 AM
    #146
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    Mine has 127k and runs great. From what I read toyota did not make the 3.4L engines some company called hino industrial manufacture of engines.
  7. Jan 31, 2015 at 1:13 PM
    #147
    usptwins
    usptwins Well-Known Member
    Trey
    Louisiana
    Taco SR5 Stock stock stock
    Kyb shocks/struts, Nitto Terra Grappler G2's in 285/70R17.
    I have a 96 tacoma with 376k miles and its still drives great. I get about 20-22mpg doing 60-70mph.... Motor is original as far as i know. Bought it with 296k miles with no leaks. Now i had to rebuild the trans because i drowned it, and have a samll oil leak coming from my valve cover seal i believe. When this motor quits, idk if i want to swap in a 2jz or a UZ engine.
  8. Jan 31, 2015 at 9:48 PM
    #148
    dellxps01
    dellxps01 New Member
    nj
    96 tacoma extended cab sr5 v6
    got a 96' 4x4 sr5v6 with 402,000 was got brand new, lov it
  9. Feb 1, 2015 at 4:34 AM
    #149
    tacotacoburrito95
    tacotacoburrito95 New Member
    dylan
    okanagan
    very clean 95 tacoma low kms.
    I have 240xxx on mine timing belt and regulat oil changes is all. Starts nice every time even those -40 alberta mornings. Anyway when i bought mine the toyota dealership had one they couldnt sell because of kms. they just plowed the lot with it. 800 and something on it and still going strong.
  10. Feb 2, 2015 at 11:04 AM
    #150
    yf19
    yf19 Well-Known Member
    Phoenix AZ
    1998 ExtraCab Limited V6
    Icon coil overs, Camburg UCA, 1" body lift, lots of trimming, Scion XB seats with Wet Okle covers, Alpine Head unit and amps with RF subs and Polk Momo in doors, and much more.
    lonzorizo and Sicyota04 like this.
  11. Feb 2, 2015 at 12:45 PM
    #151
    I has a ark
    I has a ark Member
    Noah
    Tulsa, ok
    99 tacoma 4x4 TRD manual with 300,xxx miles
    Got 312 thousand on my tacoma bought it with 300 tousdand and I've had a few leaks but other then that no big problems except for a new clutch and some cosmetics. Best truck I think I've bought
  12. Feb 2, 2015 at 7:30 PM
    #152
    hughesjrm
    hughesjrm Well-Known Member
    Michael
    Florida
    2003 Tacoma DC TRD
    Just Starting
    I am going on engine number three and still have not broke 115k.
    Engine #1 went out with 112k on it after 7 years. Had regular oil changes and routine maintenance. Timing belt pully sheared off after the cam shaft seized.
    Engine #2 was a rebuilt long block with a three year 100k warranty. Just went out two weeks ago with only 56k, had a bad #3 cylinder. Only had 30psi of compression. I will eventually have this motor rebuilt.
    Engine #3 should be here Thursday. I bought a used JDM motor with 32k. Figured what did I have to loose.
    Moral of the story is I love my Tacoma truck, and will keep putting motors in until the frame rots away.
    Roadeater likes this.
  13. Feb 2, 2015 at 8:52 PM
    #153
    yf19
    Phoenix AZ
    "Moral of the story is I love my Tacoma truck, and will keep putting motors in until the frame rots away."
    That's what I thought too when I broke 100,000 miles many years ago but this mule is stubborn and keeps on going. Let's see how long my Chevy lasts.
  14. Feb 3, 2015 at 7:13 AM
    #154
    smmarine
    Melbourne FL
    Sounds like you're rough on engines lol. JDM engines are known and bound to have issues. Good luck
  15. Feb 4, 2015 at 10:29 AM
    #155
    hughesjrm
    Michael
    Florida
    2003 Tacoma DC TRD
    Just Starting
    Actually to the contrary I'm not. I put an average of 12-14 thousand miles on a year. I very rarely go over 75mph, and all scheduled maintenance is done on time. Since I've been in Florida, I have been unable to do any wheeling. I guess that is what makes this so baffling.
    Most of what I had read was JDM motors were pretty good. Regardless if it last me a year or ten. My plan is to have engine #2 rebuilt and standing by.
  16. Feb 4, 2015 at 1:11 PM
    #156
    WilliamJackII
    WilliamJackII Member
    FL Panhandle
    Black TRD Limited xtracab 4x4 Supercharged
    Supercharger, Xtang flares, bedliner
    2000 TRD 4x4 Limited Xtracab ordered new. S/C, headers and cat back exhaust @1000 miles. Installed Underdog Racing S/C upgrades with bigger injectors, Fuel mgt. module and bigger fuel pump. Gets 17 to 18.5 mpg on hwy. Replaced timing belt @ 100K along with water pump, belts, hoses.
    Rebuilt S/C nose cone once, front rotors and pads replaced. ABS pump failed @ 150 and I have left it that way. I think I like it better without it. Just have to watch out for the rear end on wet roads.
    Castol GTX til 100K then Castol High mileage semi-syn since. Changed between 5-6 K.
    Now 175K and runs as good as new. Getting a slight driveline vibration which I think is a u joint wearing.
    1st generation Tacomas are the Best truck or vehicle I have ever owned. Drove a 95 Tacoma SR5 4x4 until it was totaled by my wife @ 100K. Ordered this one to replace it.
    Don't plan on ever selling it. Just the paint on the hood and roof need a re-do because of the sun.
    If you take care of them, the large majority of them last almost forever.
  17. May 30, 2015 at 12:23 PM
    #157
    ShepDaddy2284
    ShepDaddy2284 Member
    1998 Toyota Tacoma
    2inch Supreme Suspension Leveling kit 33x10.50R15 BFG Mud Terrains Cobra 29 Chrome CB Custom Bedliner
    My 98 Tacoma has 325,000 miles on it. Owned it since it was brand new. This truck has had a hard life, pulling equipment everyday. For the past two years i have used it has my hunting truck and it has been rode hard. Just a testament to how great these trucks are. Everything is original.
  18. May 30, 2015 at 12:36 PM
    #158
    Clearwater Bill
    Billy
    Largo Florida
    Curiosity question.............
    Is there really any difference in this particular Toyota JDM and N American engine, in terms of design and build? Or are you just importing a low mile engine?
  19. May 30, 2015 at 12:52 PM
    #159
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    88,424 miles on my 3.4 as of today, zero problems with it since I got it 14k miles ago. Best Tacoma I've ever owned, had a 2.7 4 cyl 2nd gen before and it was a great engine too, just underpowered for my tastes, went V6 and never looked back! Don't miss the stick shift either.
  20. May 30, 2015 at 12:55 PM
    #160
    2004TacomaSR5
    Jon
    Montana
    You sir hold the record for highest mileage Tacoma on this whole forum I think. How long have you owned that bad girl? I can't imagine getting that many miles on mine, I know it can, but it's going to take a long long time to get there! I don't drive as much as I'd like to. If money wasn't a concern I'd roadtrip all over the country in my Tacoma and never stop. I love to travel. Wife and I are going to FL for our honeymoon in July, sadly we are flying, but I'd much rather drive! Be a 3000 mile road trip from MT to FL but what a blast it would be! My Mom and her husband are on a 3 week cross country roadtrip around the USA right now, they took her 2004 Chevy Silverado and I am so jealous haha.
