Life span of a 3.4L
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaKid62, Jan 21, 2012.
  1. Jun 28, 2015 at 4:38 PM
    #161
    yf19
    yf19 Well-Known Member
    Phoenix AZ
    1998 ExtraCab Limited V6
    Icon coil overs, Camburg UCA, 1" body lift, lots of trimming, Scion XB seats with Wet Okle covers, Alpine Head unit and amps with RF subs and Polk Momo in doors, and much more.
    Got it new in 1998 with 300 miles from the test drives and salesmen driving it. It's hasn't been my DD for a while now but I take it out every now and then to blow the dust off it. I'll never get rid of it I don't think.
  2. Jun 28, 2015 at 10:38 PM
    #162
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Do you have a newer Tacoma now? Or not trust the old 98 anymore? Still looks like a sharp truck in your sig.
  3. Jun 30, 2015 at 2:24 AM
    #163
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Not the thread jack but what LEDs are you using? Looks great. Thanks!
  4. Oct 8, 2015 at 11:49 PM
    #164
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    No comparison to those getting into 500,000 miles, but I have 270,000, and my little sister has a 97 she bought in 1998 with 15,000 that now has 340,000. I just fixed every oil leak and the thing runs like new, it's because of her truck I bought mine, and neither of us think we'll part with ours.
  5. Oct 12, 2015 at 7:10 PM
    #165
    toyotech2007
    toyotech2007 New Member
    Michael
    1999 Tacoma X-Cab
    Fabtech 3" coilovers in front, 1.5" blocks in rear LC Engineering big brake kit (cross drilled tundra rotors and 4 piston calipers in front, stainless front and rear brake lines)
    1999 with 247,xxx miles, NO problems. Do you oil changes, timing belt every 90k miles, and spark plugs every 30k miles.
  6. Oct 13, 2015 at 8:52 PM
    #166
    lil J
    lil J Well-Known Member
    Jacen
    Louisville
    99 Tacoma 4wd V6 Horizon Blue
    Old Man Emu Suspension
    '99 with 195,000. Still on first timing belt and water pump, 3rd battery, 2nd starter, and 4th set of plugs and wires. All fluids still original other than oil.
  7. Dec 20, 2015 at 6:25 PM
    #167
    Clinthappy
    Clinthappy New Member
    Florida
    2004 Pre-runner
    Just blew a headgasket in my 04 Pre-runner with just under 500k.
  8. Dec 20, 2015 at 6:43 PM
    #168
    2004TacomaSR5
    Jon
    Montana
    Damn the luck! What do you plan to do now, fix it or find another engine?
  9. Dec 20, 2015 at 7:17 PM
    #169
    Clinthappy
    Florida
    2004 Pre-runner
    A new motor. Or at least a newer one.
  10. Dec 20, 2015 at 8:48 PM
    #170
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    It's a shame they crushed all the rusty trucks. We would have been able to get 3 Tacoma engines for each Tacoma still rolling.
  11. Dec 21, 2015 at 6:58 PM
    #171
    2004TacomaSR5
    Jon
    Montana
    Yeah it is, lots of perfectly good parts gone to waste. The whole cash for clunkers program really pissed me off too, many perfectly good and drivable cars were destroyed for no reason at all when they should have either been sold dirt cheap or given to families in need of reliable transportation.
  12. Dec 22, 2015 at 7:47 AM
    #172
    1997tacomav6
    Denver
    image.jpg 490,000 on mine, just blew a heads gasket, but still running.
    And dam engine still doesn't burn any oil.
    I think the 500,000 is a bench mark for the head gaskets to go.
    Fenwick1993 likes this.
  13. Dec 22, 2015 at 7:55 AM
    #173
    1997tacomav6
    Denver
    MAYBE WE CAN START THE 500,000 BLOWN HEAD GASKET CLUB, LOL
  14. Dec 22, 2015 at 7:58 AM
    #174
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    My buddy has a 97 4Runner with the 3.4 in it. It's got like 360k on it, daily driven, and he beats the hell out of it.
  15. Dec 29, 2015 at 10:30 PM
    #175
    chadd925
    chadd925 Active Member
    Bay Area, CA
    Bed Liner, Window Tint, Aftermarket Stereo
    208,XXX and runs like a Kenyan.
    valencia25353 and Fenwick1993 like this.
  16. Mar 12, 2016 at 5:59 PM
    #176
    stumblestacks
    stumblestacks Well-Known Member
    North lake Tahoe
    Beat up 98taco 3.4L limited xtracab TRD
    Finally blew the motor at 230,000, sprung for a Jasper with 100,000/3 year warranty. The birdpig has a new set of wings! OME heavy load lift kit, Dakar leafs w/AAL, frame mounted energy suspension 4.5" bumpstops, 882 coils, nitrocharger sport shocks, trail gear sliders, addicted offroad front bumper, KC 130w daylighters, Warn M8000, 31" BFG KM2's, custom dents and Nevada pinstripes.
    I blew my 3.4 in December at 230,000. I bought the truck new in 98' and it's been a dd, landscaping truck towing a work trailer, towing a camper, camping/wheeling almost every weekend from spring through fall with an annual 4 week wheeling trip, several cross-country road trips, and commuting 90 miles with two trips over an 8900' pass every weekday for the last 3 years. I got a Jasper engine with a 100,000 mile/3 year warranty, and I'll get a new motor when this one dies. I'd get a new Tacoma if they weren't so damn big. They're pretty but they wouldn't fit down most of the trails I run.
  17. Mar 12, 2016 at 9:55 PM
    #177
    2004TacomaSR5
    Jon
    Montana
    Yeah, it sucks they're so big now. Might as well just get a full size because they are about the same size. I remember when Toyota Pickups were so small you could practically drive one into a full size truck bed and carry a spare truck around with you. Whatever happened to the true compact trucks like that? Bring them back, Toyota!
  18. Mar 14, 2016 at 7:01 AM
    #178
    Fenwick1993
    Not Fenwick
    Chesapeake, VA
    :amen:
  19. Mar 14, 2016 at 7:24 AM
    #179
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    Sitting right at 461k on dad's 01
  20. Mar 14, 2016 at 7:27 AM
    #180
    Fenwick1993
    Not Fenwick
    Chesapeake, VA
    This truck is now having it's engine rebuilt. The guy that owned the truck before my buddy pretty much never did an oil change, so even though my friend changes it religiously, the damage was already done. We went to replace the valve cover gasket on the passenger side, because it was leaking badly, and some trash fell out and blocked a channel or something, because the oil light came on not even an hour after getting it on the road again. We planned on rebuilding it this summer anyways, so it's not too much of a bummer to be doing it now. It still ran strong as all get-out, right up to the end.
