Life time alignment?????
Discussion in 'Wheels & Tires' started by Toyota Truck, Nov 23, 2012.
Should I get a life time alignment?
Poll closed Dec 23, 2012.
  1. Get the alignment
    14 vote(s)
    70.0%
  2. Don't get the alignment
    1 vote(s)
    5.0%
  3. Too stoned to care
    3 vote(s)
    15.0%
  4. Go TEXANS!!!!
    2 vote(s)
    10.0%
  1. Nov 23, 2012 at 5:58 AM
    Toyota Truck
    Toyota Truck [OP] Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Should I get the lifetime alignment? I can get it for $100 bucks. I don't need it now, but its a good deal.
  2. Nov 23, 2012 at 6:58 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I've used it three times in one year. Make sure they give you a printout of the values, or else they will only adjust toe.
  3. Nov 23, 2012 at 7:33 AM
    chrisman8995
    chrisman8995 Well-Known Member
    Newnan, GA
    05 PreRunner Double Cab
    ^X 2
    Hell i do this on my truck and my wifes lifted 4runner. I drop them off at least once a month while we eat breakfast, however make sure you ask for the initial readings and the final results. skytower is right they will try and only adjust the toe to make it quick and easy. I take full advantage of the lifetime deal
  4. Nov 23, 2012 at 7:51 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    It is about $70 for one alignment, which you will probably need at least once over the life of your truck (assuming you hold onto for more than just a couple of years), so for $30 bucks more just to be able to have it looked at with every little curb you hit, worth it. Do you need your truck looked at after you hit curb, not necessarily, but if you could why not.
  5. Nov 23, 2012 at 7:56 AM
    Large
    Large Red
    This is true. Can't tell you how many times their printer is 'broken.' Do it yourself too, everytime my old lady gets an alignment they give her the run around.
  6. Nov 23, 2012 at 7:57 AM
    Large
    Large Red
    Assuming you are referring to Firestone :p
  7. Nov 23, 2012 at 8:49 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Ok so I went ahead and bought the lifetime alignment and balance for $150 at FIRESTONE. When I tell them to print out the "values" what am I lookin for?
  8. Nov 23, 2012 at 9:40 AM
    Large
    Large Red
    Caster 2.5
    Toe 0
    Camber 0
    Where at in Texas? I can recommend a few firestones to stay away from in the south Houston area.
  9. Nov 23, 2012 at 10:01 AM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    I have dropped $210 on alignments since I got my truck. Once by Firestone after my lift for $60 than I installed UCA's took it back to Firestone and they either could not read directions or were to lazy to do the alignment correctly. I did not have to pay that time. I ended up having to take it to 4 wheel parts for $150 but it was done correctly. So I would ask questions what they are willing to do on the lifetime alignment. A lot of techs are lazy and don't want to do the actual alignment they just want to adjust toe and move on.
  10. Nov 23, 2012 at 10:50 AM
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    Ya I got the Firestone lifetime alignment for $80.00. Befor I purchased it I told the manager that I was lifting the truck about 2 inches "no problem" - PROBLEM!!! Dip shits here in Ohio don't have a clue how to align a truck with LR UCA's even after I told them how to do it, even after Chris from Specialty Products Corp. spoke directly with the tech. They couldn't - wouldn't get it right so they refunded my money. GOOD LUCK with Frickendrones.
  11. Nov 24, 2012 at 9:21 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Thanks Rep for you.
    Firestone Complete Auto Care Store
    23828 Southwest Fwy
    Rosenberg, TX
  12. Nov 24, 2012 at 9:28 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    I told them before I made the appt. that I had aftermarket UCAs. They told me no problem..... More room to play with. :eek:
  13. Nov 24, 2012 at 9:34 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Find a good firestone and you'll be more than pleased. I used my liftetime 7 times last year. got it realigned after each big wheeling trip. they've gotten to know my truck, and know that i tip pretty good for a job well done, so they don't mind me bringing it in all of the time. just have to find a good shop and build a decent relationship with it.
    and congrats on getting a good deal!
  14. Nov 24, 2012 at 9:37 AM
    TacoTony
    TacoTony Well-Known Member
    tony
    san antonio
    single cab rado
    Maxtrac spindles
    I work at a Firestone, my manager doesn't let us do lifted vehicles. So sometimes it's not that the techs are lazy, I would actually like doing lifted trucks
  15. Nov 24, 2012 at 9:47 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Well my cousin works there am hoping he takes good care of me.:)
  16. Nov 27, 2012 at 8:19 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Well I just got back from FIRESTONE. Turns out I didn't need an alignment. At least I don't have too pay for one again...THE BAD NEWS is I had to get a refund on the balancing of the tires because the techs couldn't get the tires off. The manger told me the lugs were either seized which they could turn up the impact and free it, but if they were CROSSED THREADED it meant they would risk breaking the wheel studs and lugs. I made a appt at NTB for a tire rotation ( free since I purchased the tires there) so if they tell me the same thing I will tell them that's their responsibility since they were the last ones to mount/dismount my tires.
  17. Nov 27, 2012 at 9:20 AM
    TacoTony
    tony
    san antonio
    single cab rado
    Maxtrac spindles
    Haha I used to work there too!! They should replace them tho, it's a bitch to get those off
