Life with Duratrac's.
Discussion in 'Wheels & Tires' started by Bluegrass Taco, Sep 6, 2015.
  1. Sep 30, 2016 at 9:41 AM
    #101
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I wouldn't use P-rated tires on rocks either. From what I can tell, the Duratracs seems to be a soft compound as I can see the sidewalls can get scratched easily. Don't know if I'd use them for rocks either.
  2. Sep 30, 2016 at 9:48 AM
    #102
    AmorPatriae
    AmorPatriae Well-Known Member
    12 DCSB SR5 4x4
    TRD Sport Hood, Truxedo Lo Pro Tonneau cover, OEM Bed Extender, SOS Front Bumper, SOS Rear Bumper, Pro Comp 84 Series Vapor, Goodyear Wrangler Duratrac
    Thank you folks for your input. I figure I'll go with the P, have a full size spare and the warranty in case anything happens.
  3. Sep 30, 2016 at 9:54 AM
    #103
    Bluegrass Taco
    Bluegrass Taco [OP] Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I beat and banged around on quite a few trails with my Duratracs. We have a lot of slate and shale in this area. It can be like razor blades. Not one single cut, scrape or abrasion that I can find. I destroyed a set of Goodrich KM2's on a Dodge 3/4-ton in this stuff.....The duratracs seem to be holding up just fine.
    syswalla and DriverSound[QUOTED] like this.
  4. Sep 30, 2016 at 5:11 PM
    #104
    Markc1024
    Markc1024 Well-Known Member
    For on-road mostly use, I think you'll find that a P rated tire of the same size has greater load capacity than a C. Not saying they are better for off-road, but if weight and towing are your focus, you should be fine.
    AmorPatriae likes this.
  5. Oct 2, 2016 at 4:54 PM
    #105
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Glad I found this thread. I raised the pressure in my Duratracs to 37-38 psi. HUGE difference! Even though I had the tires road force balanced,there was still a shake after 60mph. After raising the pressure,the shake was barely noticeable. I'm due for a rotation soon,and will have them balance out at current psi.
    Bluegrass Taco[OP] likes this.
  6. Oct 3, 2016 at 4:38 AM
    #106
    Bluegrass Taco
    Bill
    Mt Washington Ky
    I've heard several interesting theories as to why this is so. The most common one is that these tires aren't 100% "round", instead having a few flat spots when left at lower pressures. Inflating them to above 35psi sort of rounds them out better. While this sounds kind of bogus, the reality is, they simply ride smoother and wear better when inflated to 37/38psi. Another theory is, the outside row of cleats on the tread are where the vibrations are created. Inflating to a higher pressure keeps the tire from riding on the outer ends of those cleats, resulting in smoother operation. Either way, or even if it's another reason, my results seem to prove 37 to 38 psi is where I need to be for highway use.
    The last trip to get my tires balanced, the work was performed by a tech who at first wasn't so "confidence inspiring". My initial impression was this kid wasn't the brightest crayon in the box....He had a shadetree mechanic persona...and I was doubtful. The first thing I noticed was he put a great deal of effort into getting all 4 tires inflated to EXACTLY 40 psi. THEN he balanced them. He also used a slightly different rotation pattern than is normal for radial tires. He brought rears to front on same side, but took left front to right rear and right front to left rear. After that, he adjusted air pressures back to the 37 I had 'em at. 5000 miles later, even better. Tires have ZERO tread feathering, EXACT same tread depth measurement tire to tire, and the truck simply rides and drives better than it had before. His efforts resulted in the best balanced set of tires this truck has seen.
    Apparently this kid knows something I didn't.
  7. Oct 28, 2016 at 5:35 AM
    #107
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Back again! We just completed the 2nd annual TacomaWorld Black Mountain Week after the Fall Crawl Meet. 5 Tacoma's and 7 people total. We hope to increase numbers for next years run.
    This is a true tire test! 225 mile highway sprint to Harlan, followed by 2 days on rocky, slick, sometimes wet terrain, covering roughly 48 miles of trails, then 225 miles back to home base! This year, an added feature that wasn't in last years agenda. I have an ARB tire deflator and a CO2 inflation rig. Tires were @ 36 psi upon arrival, aired down to 18 psi on the trails, then re-inflated to 36 psi for the trip home. The equipment worked to perfection. So did the tires! Duratracs @ 18 psi would grip ANYTHING!
    It rained a BUNCH on the way down. Not only did I get to see how Duratracs with 33,000 miles did on wet roads, we got a look at sloppy wet trails first thing on Saturday morning. BOTH instances, the tires performed to perfection! The trails dried up as the day went along.
    On the highway, NO vibration...NONE. I've heard people say Duratracs have inherent issues with road vibration. Balanced correctly and inflated correctly, that is simply NOT true. The 450 miles of highway driving saw 22.75 mpg average. You simply will NOT get that sort of mileage out of a 4.0/auto Tacoma unless the tires are top shelf.
    On the trails, my Duratracs held their own against a brand new set of Goodrich KM2's....AND a set of brand new Cooper SST Pro's......The ride quality on rocks and hard packed trails is incredible with air pressure @ 18 psi.
    Finally, as mentioned, I'm at 33,000 miles. Wear is minimal. (4/32nds wear) No uneven wear, no feathering, and most of all, not one single scuff, abrasion, chunking, or cut. Sidewalls are unscathed. These tires are tougher'n a $2 steak! I would not hesitate to put another set on the next go round!
    Marty65, DriverSound and Sna like this.
  8. Nov 24, 2016 at 5:05 AM
    #108
    Bluegrass Taco
    Bill
    Mt Washington Ky
    35,000 mile mark! The Duratracs are still performing as well as any off road capable tire I have ever owned. They are starting to show wear, but not anything substantial. From new, they've given up 7/32nds, pretty evenly on all 4 tires. Balance is staying great once I went back with clip on weights again. I do NOT care for sticky weights....
    Job bonus is due in a couple months. I'll probably buy new tires then, while these are still good enough to sell. I'd like to go bigger, maybe 285/75/16's, but it'll be tough to go away from what I KNOW works well.!
    Sna and Marty65 like this.
  9. Nov 24, 2016 at 10:02 AM
    #109
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    My Duratracs have been good to me but I'm seriously considering going 255/85-16 for my next set of tires. Since the Duratracs don't come in that size I'll probably go with Cooper ST Maxx in that size. Decisions...decisions...
  10. Nov 24, 2016 at 3:56 PM
    #110
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Also on my short list. May do KM2......? Choices in that size are very limited.
  11. Nov 24, 2016 at 6:54 PM
    #111
    Monkeybutt2000
    Was talking to a buddy the other day who owns a 13' F-150. He runs Duratracs (not sure of size) and got 70k out of the set.
  12. Dec 25, 2016 at 6:20 AM
    #112
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Just about to hit 40K! They show some wear, but FAR LESS than I would have guessed at this point. Unless I'm badly fooled, they're good for another 25K before sipes start to wear away. This set will probably be swapped for new one's in about 2 months. I'll be getting my performance bonus @ work about then. Seems like a good opportunity to put new tires on! The current Duratracs will be sold. I've got a standing offer from a friend for $350.
    In the past 2 weeks, we've been on 4 different long road trips (funerals, Christmas visits, etc) The ride is still great and I'm getting north of 21mpg on 70mph+ interstate highway trips. One trip, just over 550 miles round trip, we saw 22.6mpg. That was 75mph most of the way. Bad tires won't do that.
  13. Dec 25, 2016 at 6:30 AM
    #113
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    I would think a Heavy Duty gas shock would be better than the OEM Tokico shocks, if your stock suspension and not looking to lift the truck Bilstein 4600 HD is the way to go.
  14. Dec 25, 2016 at 6:48 AM
    #114
    NM Lance
    NM Lance Well-Known Member
    Old post, I know... What did those TRD center caps come off of? I would really like to get a set.
    I like the Duratracs too, I am on my second set. For anyone not impressed with them, take them through some deep snow, you will be amazed. I had over 70K on my first set (gen 1), but they became a pain to keep balanced because they started to chunk as they aged.
    syswalla likes this.
  15. Dec 25, 2016 at 9:29 AM
    #115
    Bluegrass Taco
    Bill
    Mt Washington Ky
    FJ Land Cruiser Trail Team wheels. I'll dig around and see if I can find the link. Will post here if I can....
    NM Lance[QUOTED] likes this.
  16. Dec 26, 2016 at 12:24 PM
    #116
    Mickeydog
    Mickeydog Well-Known Member
    Dave
    West Michigan
    2020 TRD Sport, Cement DCSB
    Pro wheels with 265-70-17 Goodyear UT. Pro skid. Pro tail lights. OEM tailgate power lock.
    I just put 265-75x16 Duratracks on my Taco about 3 weeks ago. We've had some pretty good snow here in MI.
    And these tires have worked great, both on the road and in 18" of snow on fire service two tracks.
    I looked at Falken, but they only had 13/32 tread compared to Duratracks 18/32 tread.
    Very happy with my decision.
  17. Jan 19, 2017 at 8:00 AM
    #117
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    just got a rotate and balance over at discount yesterday. i am running duratracs in 265/75/16 Load C. I have been super pleased with performance, on and off road. I air down to about 18 when off the pavement. although the need balancing readily, I get them done every 5-7K, free at DT. I have put about 35K on mine, and are wearing very well. I run about 38-40 PSI, I do a lot of highways miles. they measured out at 14-15 / 32s, I believe they started at 19/32s. I might could get 60-70K out of these, but wanting to go to a 255/85/16 tire soon, (ST Maxx, maxxis bighorn ? ) so I might not make it, might sell them while they still have some value to someone.
    JohnLin15 likes this.
  18. Jan 30, 2017 at 4:20 AM
    #118
    Bluegrass Taco
    Bill
    Mt Washington Ky
    @ the 45,000 mile mark. Still good! PLENTY of tread left. Just a guess, but I'd say another 30,000 of good life left. Had balance checked last week. One tire needed 1/4 oz weight removed. Other 3 were still spot on. Fuel mileage still @ 20+ on winter gas. Noise level relative to air pressure. Lower it and they get louder. @ 34, not bad at all!
    Oh how I wish these were available in 255/85/r16's.....
  19. Jan 30, 2017 at 8:20 AM
    #119
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I find the noise level the same at either 34 or 38. Just different pitch.
  20. Feb 20, 2017 at 6:39 AM
    #120
    88nitro305
    88nitro305 Well-Known Member
    Tom
    Vermont
    2012 white DCSB TRD OR
    Thanks for the awesome review and updates! Right now I'm stuck between KO2 or the Duratracs both 265/75r16. The issue is 4wheelparts have them both but the KOs are about $90 less, which doesn't seem like much but when you told your wife you would buy tires for around $200 over it becomes an issue kinda.. she said to get whatever but I know her.. maybe I'll keep looking and can come across a better price for the Duratracs
