Lifetime alignment, Where? How much?
Discussion in 'Southern California' started by Relik, Mar 12, 2011.
  1. Mar 12, 2011 at 11:52 AM
    Relik
    Relik [OP] Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Hey y'all
    I just wanted to get some recommendations on where a good place to get a 1/2/3 year or lifetime alignment deal for my truck. I think I'll want to do it here an there as I do lift options and occasionally off-road. I got the TSB leafs and I believe the dealer jipped me of an alignment...
    I'd still need this eventually tho... I heard about a Firestone $150 deal once but figured some of you prolly shopped around and can Lead me in the right direction...
    Thanks
  2. Mar 12, 2011 at 2:37 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Firestone $179 lifetime
    Customer service is good. The probably hate seeing me pull in, I have had it for like 3-4 months now and used 4 times :D
  3. Mar 12, 2011 at 2:39 PM
    Bmxcast00
    Bmxcast00 Well-Known Member
    Raymond
    Exeter Ca
    09 PreRunner Reg. cab.
    Black headlight mod, powdercoated stocks, leveling kit, debadged
    I got a life time alignment from Expert Tire here in Visalia, CA. I want to say it was about $179. So far I've used it 4-5 times.
  4. Mar 12, 2011 at 2:39 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Firestone $120
  5. Mar 15, 2011 at 10:02 AM
    Relik
    Eddy
    Thousand Oaks, CA
    I called firestone and they confirmed it's $179. I'm sure when I get it they won't like me either ;)
    Thanks guys....
  6. Mar 15, 2011 at 10:06 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    firestone turned me away... my truck scared them, but $179 for lifetime alignements is a good deal for sure
  7. Mar 15, 2011 at 10:07 AM
    rcfreak201
    rcfreak201 Well-Known Member
    ive heard everyone goes with firestone, ill prob do that too
    after that jump in your sig im sure you'll need some alignment;) that shits massiveeee haha
  8. Mar 15, 2011 at 3:23 PM
    BBBsti LTD
    BBBsti LTD Well-Known Member
    Irvine, CA
    2010 TRD Off Road 4WD
    If you keep flying in your truck like you did on your signature picture, I am sure you will get your money back!!LOL
    Nice pic, BTW!
  9. Mar 15, 2011 at 10:26 PM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    I have it.
    $140 Even.
    I've used it 6-7 times already. You'll need them to check it after its done. They seem to get mine wrong sometimes. ​
  10. Mar 17, 2011 at 12:38 PM
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    Thanks for the info, gents. I used to get lifetime alignment back in the day, but didn't think such an animal still existed. I'll have to check out Firestone, now that I have a 4x4....
  11. Mar 18, 2011 at 9:15 PM
    Relik
    Eddy
    Thousand Oaks, CA
    Hm I got to see if I can push them down to that, maybe cash will do ;)
    How do you check it after? Their readings from the alignment?
  12. Mar 18, 2011 at 10:32 PM
    rmdesigns
    rmdesigns Active Member
    Orange, CA
    '11 DC SB TRD
    Debadged - TC Upper Control Arms - Method Wheels - 285/70/17 Terra Grapplers
    United Automotive, in Orange, does them for $80. As long as you don't alter your suspension.
  13. Mar 26, 2011 at 4:54 PM
    Manwithoutaplan
    ID
    Trucker tire in azusa will do aligment for 50 bucks and 12 bucks for rotating tires.
