Lifetime Capacitor, battery combo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scotkw, Mar 30, 2019.
  1. Oct 23, 2019 at 8:49 AM
    #41
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    It’s not the electrocution hazard that I’m considering, it’s the discharge through a conductive item like a dropped wrench. That’s a hazard that is not a function of voltage or the resistivity of one’s skin.
    A 6V short circuit can be as explosive as a 69,000V short circuit depending on the energy reserve in the source.
    This a subject I endlessly consider in my career.
  2. Oct 23, 2019 at 8:52 AM
    #42
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Very good point. I have a few scarred wrenches myself. I wonder what would happen here with that much current, but only 10 watt hours of energy.
    :welder:
    Stocklocker[QUOTED] likes this.
  3. Oct 23, 2019 at 9:05 AM
    #43
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I equals V divided by R.
    I've been whacked by HV RF amplifier capacitors that were not discharged. Less than 1amp at 4kv and for 2 days my hand felt like it got whacked with a sledge hammer.
  4. Oct 23, 2019 at 9:12 AM
    #44
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    It's aluminum, seems better than plastic, until it's not.
    wahoobie likes this.
  5. Oct 23, 2019 at 9:14 AM
    #45
    Nu2taco
    Nu2taco Well-Known Member
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    can the alternator put out enough voltage to keep Lifepo4 batteries charged and healthy? I know 3rd gen alternator voltage output isn't enough for AGMs
  6. Oct 23, 2019 at 9:59 AM
    #46
    Grossomotto
    2017 4WDV6LB6MT
    I’ve got an AGM and thought about this. Even if the alternator charged the battery to 14.7V (it can’t) what benefit would it be for the truck?
  7. Oct 23, 2019 at 10:01 AM
    #47
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Human skin offers almost no resistance above 200v.
  8. Oct 23, 2019 at 10:04 AM
    #48
    golfindia
    Yes.
    pickup truck
    Straight from alternator, no. But you should use some sort of charge controller anyway, unless you have one with built in BMS. Not hard to make a voltage converter, or use a DC-DC charger similar to what the RC car folks use.
    You can't parallel a LiFePo4 battery with a SLA anyway....
    I put a 100w solar panel on the roof, never have to charge the battery....
    Grossomotto likes this.
  9. Oct 23, 2019 at 10:11 AM
    #49
    Stocklocker
    17TRDORDCSBAT
    Again, I’m not discussing electrocution, at all. I’m discussing arc-flash / explosive hazards due to short circuiting a system with a metallic object. Nothing to do with the body.
    GreyBaldTaco and shakerhood like this.
  10. Oct 23, 2019 at 10:16 AM
    #50
    golfindia
    Yes.
    pickup truck
    No benefit to the truck, but the battery life will be reduced significantly by charging it only with the alternator (constant current).
    AGM batteries have finicky charging cycle requirements. They need bulk charging to a certain point, but then need to be floated. If you just connect it to your alternator, this isn't happening.
  11. Oct 23, 2019 at 10:18 AM
    #51
    golfindia
    Yes.
    pickup truck
    Relax, boss. I didn't intend to compare it to the body. Arc, flash, explosion, fire, electrocution, whatever. My point is it's all ohms law.
  12. Oct 23, 2019 at 10:27 AM
    #52
    Grossomotto
    2017 4WDV6LB6MT
    What if you put it on a 7 stage charger once a month to 14.7V?
  13. Oct 23, 2019 at 10:47 AM
    #53
    golfindia
    Yes.
    pickup truck
    Alternator will still be too much voltage for floating. That's why AGM batteries aren't used in cars. Nominal alternator voltage is too low for bulk and too high for float.
  14. Oct 23, 2019 at 10:52 AM
    #54
    scotkw
    scotkw [OP] Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    FWIW, this blue/red LiFePo4 does have it's own internal BMS. Its Recommended to be kept under 15v (16v cutoff) for maximum life. My alt seems to put out 14v on cold days, 13.7 when warm. For last few months, the batt reading is always above 13.1v after sitting overnight or for many days. So alternator charges lifepo4 fine. Another FWIW, lithium iron is the safest of the LI batteries. Basically Is no chemical run away fire hazard like a tesla. lol.
  15. Oct 23, 2019 at 11:25 AM
    #55
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
  16. Oct 23, 2019 at 11:58 AM
    #56
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    I got one too. Totally unnecessary, but what the hell
    I loved how the sticker came unstuck on backing so you could get it how you wanted. I also enjoyed the large sheet of Japanese characters
    Grossomotto[QUOTED] likes this.
  17. Oct 23, 2019 at 12:09 PM
    #57
    Grossomotto
    2017 4WDV6LB6MT
    It was $10 defintely worth it’s weight in metal
