Lifetime drivetrain warranty offered by local dealer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cocephus, Aug 24, 2021.
  1. Aug 24, 2021 at 7:29 AM
    cocephus
    cocephus [OP] Well-Known Member
    Joe
    2021 Cement Tacoma TRD Sport
    So, to add to to the title:
    Must be maintained within 500 miles of scheduled mileage. Must be done by ASME qualified persons and documented.
    When I questioned the ability to replace needle bearing I was told it would void this offer. So, I assume MT accumulator delete will also void this warranty.
    Has anyone ever heard of this kind of offering? And what has your response been?
    A 2/1 level may require a needle bearing replacement. And while I can live without accumulator delete, it would be nice. It is worth noting, all Toyota factory warranties are still applicable.
  2. Aug 24, 2021 at 7:36 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    I'd want proof that an ASME certified technician checked my washer fluid, wiper blades, or coolant level...
    I'd say there are likely so many conditions and subject-tos on it that you'd probably never get anything from it.
    BkerChuck, fczabala, BSFord and 9 others like this.
  3. Aug 24, 2021 at 7:48 AM
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    A lot of those BS "lifetime powertrain" warranties that are free or "included" by the dealer are just marketing to keep you going to them for maintenance. Also, they usually only cover lubrication related failures, which are pretty much non-existent if you do the bare minimum for maintenance. they also exclude a ton of shit too, such as differentials, driveshafts, u-joints, cv joints, etc... so it is a warranty that will cover lubricated components of your engine, transmission, and maybe the transfer case if the failure is the result of improper lubrication. Coincidentally, these components are probably the least likely to fail items on any modern vehicle that isn't being abused and neglected for it's entire life.
    BSFord, cocephus[QUOTED][OP] and gwiz like this.
  4. Aug 24, 2021 at 7:52 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    X2 ^
    Blow a motor at 8 years and 200K and see if you've met the criteria for a free replacement.
    OP, this 'warranty' isn't unique to your dealership. The local Ford dealership here is offering the same facade.
    Similarly with our inground swimming pool dealer. Lifetime warranty, surface and structure, with one water test done in house each month, every month.
    Miss one water test or decline a particular treatment and the warranty is voided.
    There's no such thing as a free lunch.
    Kev250R, BSFord, photogr4x4 and 2 others like this.
  5. Aug 24, 2021 at 8:01 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My uncle had one of those lifetime dealer warranties on his Camry, but the fine print required him to have all services done there including buying tires.
  6. Aug 24, 2021 at 8:04 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    They know on average they will make money on selling a warranty, and they control the terms of the warranty to maximize the profit.
  7. Aug 24, 2021 at 8:11 AM
    gwiz
    gwiz Well-Known Member
    Indiana
    2020 Tacoma SR5 4x4 V6
    GFC v2
    Including tires?! Yikes.
    shakerhood[QUOTED] likes this.
  8. Aug 24, 2021 at 8:18 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Yeah those are generally things where you need to keep things as bone stock as possible for it to apply. But that's really no different than them trying to tell you why various things aren't covered under the normal warranty. My local dealership offers a 1,000,000 mile warranty. Given that I didn't buy through them I don't know what the stipulations are but I imagine it is similar.
  9. Aug 24, 2021 at 8:45 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    When I bought my truck the dealer included an unlimited years and miles powertrain warranty from Fidelity Warranty Services, which is the extended warranty company owned by Southeast Toyota Distributors (same company you would buy a bumper-to-bumper extended warranty from - we can't get Toyota factory extended warranties because of SETD). Basically you have to keep the vehicle completely stock - even tire size - and you have to do the maintenance required in the owner's manual. Any failure caused by a non OEM part is out. There is no requirement to have the service done at the dealership, just have to have proof the maintenance was done. Other than that it seems to have the usual exclusions...accidents, falling objects, theft, anything covered by a manufacturer's warranty, etc. I'm sure I paid for this thing somewhere, nothing is "free" at a dealership, but I got a pretty decent deal on the truck so I'm happy.
  10. Aug 24, 2021 at 9:09 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    The 2/1 TRD factory Lift that Toyota sells you does not include needle bearings. That's gotta tell you something....
  11. Aug 24, 2021 at 9:13 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Well there's only one needle bearing in the front diff, and it's already in there so the lift wouldn't include it. There's no Toyota anything that's going to come with aftermarket parts like an ECGS bushing to replace the factory needle bearing.
  12. Aug 24, 2021 at 9:37 AM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    If they have your phone number standby for up selling warranty marketing calls for the rest of your life.
  13. Aug 24, 2021 at 9:38 AM
    cocephus
    Joe
    Thanks for the clarification. I had my skepticism and was probably going to proceed anyways. I wouldn't pay for anything extra through the dealer, you can find everything cheaper elsewhere. It was an idea they brought to my attention after we were already on agreement on the sale, free. But you don't buy a tacoma to be a slave to a warranty, not very free.
    jmneill and skeletron like this.
  14. Aug 24, 2021 at 9:48 AM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    My used taco came with a lifetime powertrain warranty. It covers the engine, transmission, transfer case (all internal parts only), as well as the 4x4 component, drive shaft, carrier bearing, u joints, etc etc.
    The contract says to maintain the vehicle according to manufacturers specs, which I do and have proof of. If one of the covered components ever fails I'm confident that the warranty company will honor the contract.
    The only risk to deals like this (so long as you hold up your end the bargain) is that the company providing the warranty goes under.
    The engines and transmission the these trucks are expensive and it's nice to know I'm covered in the event of catastrophic failure. In addition when I burn out my u-joints and it's time to service the drivetrain I won't have to go underneath there myself, as I've done on two previous Tacoma's (why they would cover a u-joint or carrier bearing is beyond me, but I'll take what I can get when I can get it).
  15. Aug 24, 2021 at 9:51 AM
    BDSKJChris
    Albany, NY
    You got all that in writing? Sounds too good to be true.
  16. Aug 24, 2021 at 9:55 AM
    ToyodaSun
    Parts Unknown
    17' DCLB TRD OR
    I thought it was too, and was worried the dealership would screw me over. But they came through and I have a contract with terms, the whole bit.
    The devil is in the details. Always get a printed contract.
    Again, all good until you've had the truck for ten-twenty years and the company supplying the warranty went out of business.
    FL_TRD Sport likes this.
  17. Aug 24, 2021 at 10:07 AM
    bigmace
    bigmace Well-Known Member
    Salem, OR
    2020 DCLB SR5 4x4
    Lol these "lifetime powertrain warranties" are such a scam. Get one oil change done at the quicklube place instead of the toyota dealership you warranty is invalid.
    OmahTako likes this.
  18. Aug 24, 2021 at 10:23 AM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    And deal with the subsequent markup on each and every one of those tires... :facepalm:
    OmahTako and shakerhood[QUOTED] like this.
  19. Aug 24, 2021 at 7:03 PM
    TRD2021SPORT
    TRD2021SPORT Well-Known Member
    2021 Tacoma TRD Sport AC
    These "dealership" warranties always work in favor of the dealership. They are called dealership warranties because they are backed by the individual dealership which also means you can not have service or repairs made elsewhere.
    As others have mentioned there are too many loopholes to jump through and trust me the dealership will put in the effort to deny the claim.
    And if the dealership for some reason has to pay a claim well all they are doing is using the money they made off of you for all those inspections & service appointments.
    Also what about labor, the OP hasn't mentioned if that is included.
    shakerhood likes this.
  20. Aug 24, 2021 at 7:11 PM
    slowdown14
    slowdown14 Member
    Texas
    2021 LR Pro
    It all depends who’s underwriting the contract and who’s each component is warrantied. I put a transmission in a GM truck that had a lifetime warranty. Truck had 180k on it. Like any other vehicle service contract, it’s all about the fine print. I would take a copy of the contract to someone who knows how to decipher it to see if it’s worth more than the paper it’s printed on. Some dealers are a single transaction company and others want your business for life. Once you figure those things out, then you’ll have your answer.
