Lifetime LED Fog lights
Discussion in 'Lighting' started by shad951, Oct 1, 2014.
  1. Oct 1, 2014 at 5:32 AM
    shad951
    shad951 [OP] Member
    '19 Cement TRD Sport
    Looking at the Lifetime LED fog lights for my 2012 Tacoma. Any good or bad feedback on these would be appreciated.
  2. Oct 1, 2014 at 7:22 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    I have the fog lights as well as the headlights. I could not be happier. :D
    Easy plug-n-play installation, nice bright white light, lifetime replacement guarantee...even though I have had these for a long time and have not seen any problems.
    I would suggest a couple things if you do get these or the headlights:
    First, where the driver (ballast/power supply) plugs into the factory harness, apply plenty of dielectric grease to the electrical connections.
    Second, where the driver connects the bulb, also apply plenty of dielectric grease, but also insert a small O-ring where the connectors screw together. This will do two things. One, it will help seal up this connection if you go through some high water. Two, it will add a little tension when you screw the connectors together to prevent them from coming loose.
  3. Oct 1, 2014 at 7:32 PM
    Chicane
    Chicane Well-Known Member
    So Cal(Huntington Beach)
    14 DCSB TRD Sport
  4. Oct 2, 2014 at 7:48 AM
    shad951
    shad951 [OP] Member
    Thanks for the reply and good to know you are happy with them. I was looking at the ones from TRS but could not the TRS rep here to answer 3 PM's I sent with questions about their fogs:confused:
  5. Oct 2, 2014 at 9:45 AM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    PMs are not good for product questions, as mentioned below my user name as well. Sorry for the confusion!
    Please email us or post in the relevant thread with any inquiries.
  6. Oct 2, 2014 at 4:59 PM
    shad951
    shad951 [OP] Member
    Sorry, I did not realize you had your PM's turned off sir.
