LifeTime LED Headlights??
Discussion in 'Lighting' started by Chris24, Nov 27, 2013.
  1. Nov 1, 2014 at 12:49 PM
    #541
    Chicane
    Chicane Well-Known Member
    So Cal(Huntington Beach)
    14 DCSB TRD Sport
    I know this is a lifetime led thread, but I don't mind taking some flack. With all the issues you guys seem to have with these, has anyone tried Vleds headlights? I'm looking to add some more white to my headlights and may go with Pee Runners route due to all the issue I hear in this thread.
  2. Nov 5, 2014 at 3:53 PM
    #542
    mfdchief
    mfdchief Well-Known Member
    Louis
    Rhode Island
    Well what do you know another set of lifetime LEDs has failed!! I think I'm on set number four or five bye now. Best part was my passenger side low beam started to flash like a strobe light next thing I know I get pulled over. Luckily I did not get a ticket however I had to spend 30 minutes pulling the bulb out to determine whether it was a bad bulb or ballast.
    I'm hoping the warranty is at least as good as the nine lives my cat has because hopefully by set number nine I will be rid of the truck and I have to worry about it anymore.
  3. Nov 5, 2014 at 5:24 PM
    #543
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    There seem to be a lot of these stories with these (type) of bulbs
  4. Nov 5, 2014 at 5:43 PM
    #544
    ThomasMore66
    Dallas/Fort Worth & Durango
    I was excited when these came out and quickly started following along. They are just like this cool flexible collapsing life time garden hose I have. I've only bought two, but I've owned six. They are crap, but it fits in a little pot by my back door and is handy for watering my plants. Now, I think changing the bulbs is a bit more complicated than swinging by Home Depot and getting a hose.
  5. Dec 18, 2014 at 12:17 PM
    #545
    jc1980
    jc1980 Well-Known Member
    MGM 4x4 TRD Off-Road (Extra Value Package II)
    See build link in signature or public profile.
    I have had mine for a little over a year. First led light driver failed right after install. Then the second led light driver has failed on me 2 days ago. Contacted Lifetime LED about the issue the same day. No reply back as of yet. I just swapped back to the stock headlight bulbs since those are a lot easier to swap out whenever they go. I suggest not purchasing these unless you like having one or more lights out at a time while you wait for Lifetime LED to get back to you and hopefully send you a replacement.
  6. Dec 24, 2014 at 9:17 AM
    #546
    PeachEater81
    PeachEater81 Well-Known Member
    San Gregorio
    2005 Tacoma DCSB TRD Sport 4x4
    Icon C/O, Icon 2.0 Resi's, LR UCAs, Alcan 8 leaf pack, Aero 2525XL, Michelin LTX MS2, Lifetime LED heads and fogs (bad company and product - don't buy), aFe Pro Dry filter, Weathertech mats, Best Top, Hybrid Audio, Arc Amp, Arc Sub, Ram matting, Core/Hurst Short Throw Shifter, OEM Bed Mat, Antenna X....
    I had a headlight flicker and then go out. They sent we a new set (2) and the return shipping label. Easy folks to deal with.
  7. Dec 26, 2014 at 7:51 PM
    #547
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    Dude!!! Same thing happened to me. After a year my original set crapped out, and was cutting out completely while driving. I put the updated 35w ones in, and noted they are smaller fans, but same ballasts. I'm waiting on set #3 but will upgrade to the 70w versions. The set #2 was DOA brand new. Flickered high beams outta the gates. The Jeep has had no issues with the original set yet. It does suck because if they quit while wheeling or out in the middle of nowhere you are screwed without backup set of lights.
  8. Dec 27, 2014 at 5:57 PM
    #548
    GTSJames
    GTSJames Well-Known Member
    Leveling kit, Rigid grill & 20" SR2 light bar, Rigid SRM2 diffused backup lights, Katzkin leather interior, Weathertech floormats, custom stereo integrated with factory headunit, N-Fab steps
    Second set burned out on me last week. Guess I'll just keep having them replaced under warranty until they find a version that works :(
  9. Dec 27, 2014 at 6:23 PM
    #549
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    I hope that doesn't mean mine are next...:eek:
    Seriously though, I actually got mine from AutoAnything marketed by Plasmaglow before I saw them on here. I've had them close to a year now with no problems. I did get my fogs from Lifetime and they're still going strong too. Good luck with yours. :cool:
  10. Jan 9, 2015 at 11:53 AM
    #550
    InTheRough
    InTheRough Well-Known Member
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    Just a little update.
    The driver side bulb of my second set just went out last night. I already emailed them for a replacement.
    My original purchase was mad on 2/14/2014
    The first replacement set was sent 7/7/2014
    Like GTSJames says, I will just keep getting them replaced under warranty.
  11. Jan 9, 2015 at 11:59 AM
    #551
    Anzy
    Anzy Well-Known Member
    Eric
    Pennsylvania
    Are you guys using the 1st gen or 2nd Gen bulbs?
    I upgraded mine to the 70 watt version and have had no problems. Quality seems a lot better
  12. Jan 9, 2015 at 12:08 PM
    #552
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    If they want to send me the upgraded version then I would be totally find with that but I am not going to spend more money on bulbs that are going to keep going out.
    My first order was the 1st version (small fan housing) but the replacements were the 2nd version (large fan housing).
  13. Jan 9, 2015 at 12:10 PM
    #553
    T4RFTMFW
    T4RFTMFW Well-Known Member
    This is what keeps me from LED bulbs. Warranty replacement is a pain in the ass, and a product that consistently fails isn't going to keep that warranty in business too long.
  14. Jan 9, 2015 at 12:14 PM
    #554
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    I totally agree with you. There is no way that this company is going to be able to keep up their lifetime warranty program but, since I already paid for them, I am going to get it warrantied as many times as they go out.
    I do have to say that their process is not too bad. I used their "contact us" to give them my order number and date and they were pretty quick about getting back to me with a response.
  15. Jan 9, 2015 at 12:24 PM
    #555
    T4RFTMFW
    For sure, ride it until the wheels fall off. Glad to hear it's pretty streamlined.
  16. Jan 9, 2015 at 12:33 PM
    #556
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
  17. Jan 9, 2015 at 12:44 PM
    #557
    T4RFTMFW
    They have their own thread, questionable presence here though with possible dupe accounts. Similar issues with failures, FWIW.
  18. Jan 9, 2015 at 1:14 PM
    #558
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    There is another brand that has had better results but I'll have to look them up when I'm not on my phone.
  19. Jan 9, 2015 at 1:40 PM
    #559
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    So I could be very wrong about this company... here is the conversation.
    Me:
    My original order number was XX-XXXX placed on 2/14/2014. I had a replacement sent to me under case number XXXX around 7/7/2014 because I was having issues with flickering before the bulb went out. Two days ago I noticed that my driver side bulb started flickering like it had before I received my replacements. Last night the bulb went out completely.
    I have these installed on my 2008 Toyota Tacoma double cab short bed.
    Please let me know if there is any more information that is needed for another replacement to be sent out.
    Lifetime LED:
    Could you swap the drivers to see if the problem moves with the driver or stays with the bulb, then we will know what part is needed.
    Me:
    I did as you asked and swapped the drivers. The same bulb (driver side) was still out so it's obviously the bulb itself.
    Lifetime LED:
    The bulb will have to be sent in for repair, if it is unable to be repaired then a replacement will be sent. Reference EMA*07-010915*on or in the package with a copy of your original invoice. Our shipping address is
    Off Road Industries
    224 S Main St
    Canandaigua, NY 14424
    Me:
    I am expected to have kept my invoice from nearly a year ago?
    Will I be receiving a shipping label or are you expecting me to return your defective product at my expense?
    Also, during the time frame that your defective product is being repaired what am I expected to do for a headlight?
    Up to this point I have been assuring people in my off road community that your product was quality and your service was seemless in the instance of issues. If this is how your customers are being treated then I may have to re-evaluate my way of thinking.
    Why should your customers have to pay for your product mistakes? Am I expected to pay for shipping and go without a headlight every 6 months or so? That seems to be the trend.
    Please let me know so that I can make other arrangements for lighting and let people know how your company really is.
    ... awaiting a response...
  20. Jan 9, 2015 at 1:42 PM
    #560
    T4RFTMFW
    Sinking ship, perhaps. Hopefully you don't get boned, or they save your respect and bone the next guy.
