LifeTime LED Headlights??
Discussion in 'Lighting' started by Chris24, Nov 27, 2013.
  1. Dec 3, 2013 at 3:28 PM
    #61
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    So where's the pics. Very interested in this.
  2. Dec 3, 2013 at 3:40 PM
    #62
    ambiguous
    ambiguous Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    Lexus was actually the first to introduce LED headlights for low beam use.
    I can't imagine an LED bulb used in a halogen specific reflector housing to have better output than an HID projector retrofit. LEDs without proper optics produce a lot of glare and don't focus the light where needed.
    I would love to see output shots of these new LED H4 bulbs next to one of my retrofits.
  3. Dec 3, 2013 at 8:33 PM
    #63
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    Honda Accords even have LED headlamps, and they are retarded bright... but led retrofit sounds impossible to improve actual light output
  4. Dec 3, 2013 at 10:10 PM
    #64
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    As the few sets ive sold the LEDs are not as bright as the HIDS retrofit or not. These are made for something that is a good bit brighter than stock and is more focused in a drop in application. And yes with the sets ive been testing on a few truck, they are that.
    Instead of running a drop in HID kit, the alternative is to a bitchin instant on LED kit that doesnt have the problems that HIDs do. No relay harness to deal with. These are straight plug n play. These look very similar to the ones I carry, and if they are then the its are definitely as advertised. I can only talk about my kits, but these are definitely great.
  5. Dec 3, 2013 at 10:25 PM
    #65
    kd8bao
    kd8bao Well-Known Member
    Henry
    Cleveland
    2000 Excursion 7.3L - Ex '11 Taco DCSB
    Mine will be here in a couple days so I will try and do a detailed write up as soon as possible. But h here is a screen shot from the manufacturer
    These are different than HID drop ins. The focalpoint should be the same as a halogen but I will compare that when they come.
  6. Dec 4, 2013 at 9:59 AM
    #66
    Chris24
    Chris24 [OP] Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    I have a very hard time believing these are DOT certified. It would be great if it's true though.
  7. Dec 4, 2013 at 1:20 PM
    #67
    BamaToy1997
    Bill
    Navarre, FL
    If you look up the Honda Accord, the LEDs are actually just the DRLs. The headlights are projector beam Halogen still.
  8. Dec 4, 2013 at 1:45 PM
    #68
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    2014 Corolla's have LED headlights and they are pretty bright. I have not pulled them out yet to take a look though but they use a projector to focus the beams.
  9. Dec 4, 2013 at 2:20 PM
    #69
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    I have a Fenix TK35 I'll put up against any small handheld flashlight. Light output is impressive. I am skeptical of an LED headlight retrofit, but for flashlights they're doing quite well.
  10. Dec 4, 2013 at 3:58 PM
    #70
    Chris24
    Greensboro, NC
    I have a flashlight that will throw about 400 meteres. Youd be surprised what LEDs can do.
    In case you're interested -
    http://budgetlightforum.com/node/3246
  11. Dec 4, 2013 at 4:24 PM
    #71
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I should clear-up/rephrase what I said to "shitty" LED flashlight.;)
    I'm just trying to say most anything can put a good light output at whatever shorter distance it was to the garage, I want to see the output AND pattern at a distance.
  12. Dec 4, 2013 at 6:51 PM
    #72
    Chris24
    Greensboro, NC
    I can't believe people are pre ordering these with no beamshots :/
  13. Dec 4, 2013 at 7:18 PM
    #73
    JdevTac
    Josh
    MD/GA
    2nd gen
    Blindly walking into a new $150 item seems silly to me too, but I guess someone has to be the first one in. I would've figured a retailer would've posted up some new pics by now if they really wanted to push these.
  14. Dec 4, 2013 at 7:21 PM
    #74
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    There are pictures all over their facebook and southeast overlands facebook. lots of Q&A too
  15. Dec 4, 2013 at 8:55 PM
    #75
    JdevTac
    Josh
    MD/GA
    2nd gen
    I've seen the ones SE Overland posted. All I could find are the shots of the pattern against the garage door. I really want to see one on road.
    I didn't see anything in the comments that gave definite answer on range...all I found in a reply by SE overland on FB was:
    "LEDs don't penetrate like HIDs but on low beams and at 55 mph or more on a back highway that is pitch dark I feel totally fine."
    So it sounds like they light up things just fine, I just can't picture it in my head on how it compares to stock bulbs. I am guessing a midway point between halogens and HID's.
  16. Dec 4, 2013 at 9:06 PM
    #76
    Shaggs
    NorCal
    The DRLs are normal bulbs on all models... Touring have LED running lamps and high output LED headlamps. Bright a f*&k. I own multiple accords, the 13-14 have LED headlamps
  17. Dec 5, 2013 at 10:15 PM
    #77
    kd8bao
    Henry
    Cleveland
    Here are some videos. Got them today
    [Video]https://www.youtube.com/watch?v=WEcZBzUPxss&feature=youtube_gdata_player[/video]
  18. Dec 5, 2013 at 10:43 PM
    #78
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
  19. Dec 6, 2013 at 6:39 AM
    #79
    BamaToy1997
    Bill
    Navarre, FL
    Not trying to be a dick, I promise. If you go to both the Honda and Toyota websites and look at the details under equipment options, it specifically states on both of these vehicles "LED Daytime running lights" and either "HID headlights" or "Halogen projector headlights". They do not have LED headlights. You can't even find them as "optional equipment". Now if you can actually find IN PRINT from either of these companies that you can get HEADLIGHTS in LEDs (Not just DRL) then I will happily concede, but Directly from Honda and Toyota, the only LED lights available are the DRLs.
  20. Dec 6, 2013 at 6:47 AM
    #80
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
