Lift 2.7 Tacoma
Discussion in '4 Cylinder' started by Ghost Rider, Nov 15, 2009.
  1. Nov 15, 2009 at 4:03 PM
    Ghost Rider
    Ghost Rider [OP] Well-Known Member
    Quebec Canada
    Tacoma Sr5 4x4
    Excuse my english :rolleyes:
    I would love to lift my futur 4 cyl 4x4 Tacoma.
    When you lift 2.5 inch in front how much do you need to lift the back of the truck 2.5 inch to ???
    Thanks
  2. Nov 15, 2009 at 5:31 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    You are excused. I think a 2 inch add a leaf would be ideal, it would level out the truck a bit while still leaving the rear slightly higher than the front.
  3. Nov 16, 2009 at 9:20 AM
    Ghost Rider
    Quebec Canada
    Tacoma Sr5 4x4
    So just a 2 inch lift in front will level the truck and be ok ?
  4. Nov 16, 2009 at 9:27 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i lifted the front of my reg cab 4cyl 2" and it sits perfectly level now, no lift in the rear, but i plan on getting the 1.5" rear lift pack and good rear shocks as i do alot of offroading
  5. Nov 16, 2009 at 9:51 AM
    Ghost Rider
    Quebec Canada
    Tacoma Sr5 4x4
    Ok 2 inch in front and 1.5 inch in the back i like that.
    Whow sell those parts ?
  6. Nov 16, 2009 at 10:32 AM
    Yoytoda
    Roland
    completely stock
    there is probable 20 different ways to do it. Allpro.com is a good place. Toyteclifts.com
  7. Nov 16, 2009 at 7:39 PM
    willis
    willis Well-Known Member
    keith
    birmingham
    09 prerunner
    not enough!
    i am running the daystar 2.5" front lift on my 4cylinder prerunner ...
    with the back still stock you can see that the front sits higher now ... my measurements say a 1" rear lift will level the truck, but i plan on adding a 1.5" block for just a tiny bit of rake, hopefully soon :eek:
    ... and here is the link to the daystar spacers:
  8. Nov 19, 2009 at 1:48 PM
    Ghost Rider
    Quebec Canada
    Tacoma Sr5 4x4
    Nice Truck.
    Its very confusing there a lot a of lifting kit out there.
    Do front and rear kit that goes togeter exist ??
    One kit that include the front and the back ?
  9. Nov 19, 2009 at 3:43 PM
    alteredillusions
    alteredillusions Well-Known Member
    Wichita KS
    SR5 2.7 manual
    Look here depending on your year
  10. Nov 21, 2009 at 6:05 PM
    Reaper22
    Reaper22 Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    This is what my reg cab 4cyl. looks like 2.5 front and 2" rear..
  11. Dec 26, 2009 at 11:18 AM
    CHEEZYTACO
    CHEEZYTACO Member
    Southern Oregon
    09 SR5 4x4 acc cab 2.7l
    ToyTec 2.5"spacer/AAL w/265-75-R16 tires, future heated mirror mod, temp/compass mod, black wheels mod, and foglamp mod
    I hope the pictures come through. :pray:Sorry about the dirty truck, but I had to post these asap. This is a very budget minded lift. Toytec was easy to order online from. The components are a 2.5" spacer and 2.5 AAL that cost about $230 with shipping. I put on Firestone winterfoce 265-75-r16 studded and on the stock steel wheels. The tires were about the cheapest out there, check tirerack.com. Then I got my buddies at the dealer to put it all on for me. Keeping the stock wheels, I have no rubbing issue for a 32' tire. The ride is nearly stock but I wont be scraping my front diff crossmember going into the Klamath River Canyon anymore!!:D All of that for under a grand!!:cheers:
  12. Feb 11, 2011 at 6:36 PM
    jdeutsch
    jdeutsch Member
    21’ OR / DC / 4x4 /Cement
    Do you think it would be weird looking to do what you did, except I have 265/70/16 on my Tacoma. I want to rise 2.5, but I have new yoko A/T at 70 instead of 75, due to stock height.
  13. Feb 12, 2011 at 11:02 PM
    4cyltacoma
    4cyltacoma Well-Known Member
    Reagan
    Fresno, Ca
    06 Tacoma SR5 4Cyl 4x4
    AFE CAI, Black Housed Headlights, In Channel Window Visor, Bug Deflector, Black Side Step Tubes, Blacked out emblems
    i have a 06 2.7 4x4 also. im at a 2.5 in the front with 1 inch block for the rear and its sits nicely. pretty level.
  14. Feb 13, 2011 at 4:06 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    My truck is 2.5" front (ToyTec coil-over) and 1.5" rear (TSB w/ProComp AAL) 5100's all around
  15. Feb 13, 2011 at 4:17 PM
    HomeGrown
    HomeGrown Well-Known Member
    Bill
    South Bend, IN
    2014 Reg Cab 4WD
    I'm confused... some clarification, please? :)
    I'm just starting to look into small lifts (under 3") for the front.
    Does your 2.5" front lift come primarily from the ToyTec coil-overs, or the 5100's?
    I thought you were supposed to be able to gain up to 2.5" with the 5100's alone. :confused:
  16. Feb 14, 2011 at 1:28 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    toytec utilizes a bilstein 5100 shock in the coil-over setup. when you order them you can tell them what you want the lift to be ie:2.5,2.75,3.00 and they will preset them for you so that all you have to do is drop the whole unit in. They do supply two spanner wrenches so you can tweak it or raise or lower it.
  17. Feb 14, 2011 at 5:45 PM
    HomeGrown
    Bill
    South Bend, IN
    2014 Reg Cab 4WD
    Ok, thank you for that clarification, definately helpful! :)
    Your 2.5" front lift looks a little more believeable than some I've seen pics of who claim they have a 2.5" lift, but barely looks taller than stock.
  18. Feb 15, 2011 at 3:03 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    If you measure from the ground to the fender well with the tape measure cutting the wheel in half it is exactly 2.5 inches higher than a SR5 4x4. For me and my purposes its a perfect lift.
  19. Feb 16, 2011 at 4:04 PM
    CHEEZYTACO
    CHEEZYTACO Member
    Southern Oregon
    I run that size (the stock trd size BFG) that I acquired for cheap just to run the miles out in the summer. It looks OK but not as good as the 265/75's just because the wheel well isn't as filled up. If you have a nice tire that you are happy with, I say run it until you run them out!
  20. Feb 24, 2011 at 4:48 PM
    TacomaTK
    TacomaTK Member
    Justin
    Winchester,VA
    2.7 4x4
    3" lift, tinted windows, BFG MT 255/85/16
