Lift 3 inch front 1.5 rear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Erick villatoro, Mar 30, 2025.
  1. Mar 30, 2025 at 12:10 PM
    Erick villatoro
    Erick villatoro [OP] Active Member
    Erick
    2022 Army green taco TRD off road 4X4
    If I lift my Tacoma 3 inches front and 1.5 rear live seen that it gives it a stance what would let me make it look leveled and if I install 285/75/17 or 285/70/17 would it rub at all and if it does what would be the best size tires so I can get away with no rubbing
  2. Mar 30, 2025 at 12:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    2.5 up front is considered tops to avoid wear problems.
    Wheel specs are critical for rubbing issues as much as tire size.
    Literally hundreds of threads on the topic, some searches will give days of reading
  3. Mar 30, 2025 at 12:34 PM
    Erick villatoro
    Erick
    Well the wheel would be 17X9.0 -25 and up front would have 2.5 Fox and Total Chaos control arms just. I’m just trying to see what may occur and what problems could come up
  4. Mar 30, 2025 at 5:48 PM
    Wick
    Wick Active Member
    I thought of doing a 3" lift on the front of my Taco until I dug a little deeper. I would say 2" max to keep troubles at a minimum.
    Chew and Erick villatoro[OP] like this.
  5. Mar 30, 2025 at 6:27 PM
    Erick villatoro
    Erick
    Well yea I’m thinking either that or 2.5” lift because they say anything over can mess u a lot so that’s what I’m with at the moment but still trying to learn more and then I’m trying to see what the best wheels would be without trimming or trimming a lot
  6. Mar 30, 2025 at 6:31 PM
    MGMDesertTaco
    Keep the negative offset wheels if you like them. 285/70/17 is a decent tire with 2-2.5" of lift. You'll need to do a cmc and pinch weld mod.
    Some adjustable uca's or even JBA's will help.
  7. Mar 30, 2025 at 10:51 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    A 4" lift would clear the 285/75R17s (on 0-offset wheels) and also eliminates the CV joint risk you'd have with a 3" lift (4" kits have drop-down brackets to correct the CV angles and other aspects of the suspension), however it still doesn't avoid taking a Sawzall to your truck (instead of cutting your fenders and cab mounts, one of the crossmembers on the frame has to be cut to install the new crossmember the kit provides).
    If you'd rather avoid the Sawzall entirely (and not rub), then 265/70R17s will be your biggest safe choice.
    I think a few here have also successfully squeezed 275/70R17s under there without any cutting, but those may be hit-or-miss, depending on brand of the tires and manufacturing tolerances on your truck. You'll need to play with the wheel alignment if they are to clear (pushing the caster as far forward as possible using the LCA cam bolts). Zero (or slight positive) offset wheels will be required.
  8. Mar 30, 2025 at 11:14 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Lifting is great, but eventually you’ll compress your suspension, you’ll be back to stock height. You need to trim for your tire and wheel setup. A 8.5 inch wheel with 0 or -10 is a lot easier to fit a 285 70 17, you’ll definitely be doing some cutting with a 285 75. It’s not hard to fit though, a cmc is quick and cheap, trim some plastic. Get a good alignment at an off-road shop.
